Old 09-09-2013, 07:28 AM   #1 (permalink)
Default Kosmik 200 Burn down...Diabolo
Crashed my Diabolo this weekend, loss power in flight doing a stall turn, saw some smoke and just watched helplessly as the heli fell to the ground from about 100 ft up under no power.
See pictures of the carnage below. The ESC is a total loss, the Pyro 750-56 motor appeared to be fine, but now only rotates in one direction. $638 in damage to the helicopter including $120 blades and $250 special Diabolo canopy..not a good weekend.
I was able to recover the micro sd card and view the log for the flight, nothing out of the ordinary as far as I can see.
snipealot is offline        Reply With Quote Quick reply to this message
Old 09-09-2013, 07:41 AM   #2 (permalink)
Damm Snipe that sucks big time buddy, I am really sorry to see that!!! I crashed my Diabolo once and I still remember that sick feeling. This is just the kinda thing that has me scared of a Kosmik, I want to get one for my Banshee but, this is exactly what I am afraid of WOW!!!
Helicopters Don't Fly - They Beat The Air Into Submission
Logo 500SE
Minicopter Diabolo 700
Banshee # 45 700 LE and 850
jcflyer is offline        Reply With Quote Quick reply to this message
Old 09-09-2013, 07:46 AM   #3 (permalink)
Antonio…
Totally sorry for the loss... F'en sucks big time!
Can you post the logs for us to take a look at? I would PM the K-US rep to and ask him for some assistance getting the equipment analyzed and replaced ASAP!
Synergy N5c TT | JR Forza 700 | Bell 430 Turbine
rdavis is offline        Reply With Quote Quick reply to this message
Old 09-09-2013, 07:49 AM   #4 (permalink)
Sorry to see that damage. Here a heli pilot hurts the heart.
Strange.., strange, the point where it burned in the KOSMIK.. Looks like the (+) came into contact with ground. How is the LiPo?
Tom (j-log.eu)
dl7uae is offline        Reply With Quote Quick reply to this message
Old 09-09-2013, 08:10 AM   #5 (permalink)
please pm Charles (Kontronik USA) or I the Log file so we can take a look at it. Also either Charles or I will let you know if we need you to mail it to Kontronik USA the address used for service and if Charles doesn't respond on here i will notify him. He will probably want both the speed controller and motor.
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 09-09-2013, 08:22 AM   #6 (permalink)
Yeah it makes me sick to my stomach, but the Kosmik 160s that I have on my 7HV and Logo 800 have been flawless.
Originally Posted by rdavis View Post
Antonio…
Yes, pulling the data logs now.
The lipo appears fine, the positive lead on the esc and the positive on one side of the battery connector actually came unsoldered from the heat it appears...very strange
Will-do. Thanks!!
Old 09-09-2013, 08:25 AM   #7 (permalink)
In the attached picture the BEC lead appears to have some marks that appear to be from the pinion on them. if this is the case this could have been the source of the issue.
Richard Zappe
Old 09-09-2013, 09:05 AM   #8 (permalink)
The pinion never contacted bec lead, the braiding is melted from the heat, the bec wires under the braiding is 100% intact; the bec wires were routed and secured far away from the pinion so there was no chance the pinion could contact it. I saw smoke in the air and then moments later lost all control of the helicopter, it was dead in the air.
I am unable to attach the log file because it's telling me invalid format?
Old 09-09-2013, 09:25 AM   #9 (permalink)
make it a .txt or .jpg file and attach it that way.
Richard Zappe
Old 09-09-2013, 09:29 AM   #10 (permalink)
That worked, here you go!
Old 09-09-2013, 09:32 AM   #11 (permalink)
ill take a look at it when i get home don't have log view at work.
Richard Zappe
Old 09-09-2013, 09:37 AM   #12 (permalink)
I am also going to reiterate here that the factory recommends the use of the fuse provided with the Kosmik. It would have prevented all damage to surrounding components. It is also recommended that a small buffer pack be used in the case of a failure to guarantee that radio control is still maintained.
Richard Zappe
Old 09-09-2013, 09:58 AM   #13 (permalink)
Is there any feedback from the other burnout a couple of months back - the G770 that burned a Kosmik?
thefrog is offline        Reply With Quote Quick reply to this message
Old 09-09-2013, 11:57 AM   #14 (permalink)
Nothing to be seen.. except of the FET temperature: 200°F is already rather high - but still OK.
(In the absence of other information: RPM is 2-pole-normalized here, as the KOSMIK records it. So pole count and ratio ignored.)
$1;1;275.490;157024;43.8;9;3.44;11;47;95;82;7.4;9. 6;82;77;77;18;0
$1;1;275.500;156847;43.8;9;3.44;12;50;94;82;7.6;0. 7;81;77;77;18;0//RPMcontrol
$1;1;275.510;156710;43.9;9;3.44;12;48;95;82;7.5;5. 1;82;77;77;18;0
$1;1;275.520;156711;43.9;9;3.44;12;47;94;82;7.6;1. 9;81;77;77;18;0
$1;1;275.530;156797;43.9;9;3.44;11;49;94;82;7.6;2. 0;82;77;77;18;0
$1;1;275.540;156809;43.9;9;3.44;12;45;94;82;7.6;0. 7;81;77;77;18;0
$1;1;275.550;156628;43.9;9;3.44;12;50;94;82;7.6;3. 8;82;77;77;18;0
$1;1;275.560;156539;43.9;9;3.44;11;46;94;82;7.7;2. 2;81;77;77;18;0
$1;1;275.570;156417;44.0;9;3.44;11;51;94;82;7.6;0. 5;81;77;77;18;0
$1;1;275.580;156524;43.9;9;3.44;12;46;94;82;7.6;0. 5;81;77;77;17;0
$1;1
ID:	449601   Click image for larger version
ID:	449602   Click image for larger version
Tom (j-log.eu)
Old 09-09-2013, 12:27 PM   #15 (permalink)
Is that the file I attached? Here is a screenshot of my graph, the flight was 3m 17s.
Name:	Kosmik 200 Diabolo.jpg
Old 09-09-2013, 12:30 PM   #16 (permalink)
It looks the same as the one Tom posted.
Old 09-09-2013, 12:38 PM   #17 (permalink)
4:35, but spoolup was at 1:20.
Tom (j-log.eu)
Old 09-09-2013, 12:52 PM   #18 (permalink)
I must be doing something wrong then, when I look at that file in Logview the table data ends at 3m 17s.
Name:	kosmik diabolo.jpg
Old 09-09-2013, 12:57 PM   #19 (permalink)
https://www.helifreak.com/showthread...=530574&page=3
xioxia is offline        Reply With Quote Quick reply to this message
Old 09-09-2013, 01:01 PM   #20 (permalink)
Was this latest firmware ?, curious as the previous documented meltdown was, no others on earlier software i know of
Tdr quantum 4530 1.4 yy h/ jive120 beastx, Vibe e 8 12s mx 700 1.32yy vbargov fusionhawk, Banshee nr 36 kosmik 200 pyro 800 1.4yy 455kv 14s beastx, xtreme 700 pyro 850 1.5yy 14s kosmik 200
Stolla is offline        Reply With Quote Quick reply to this message
