700 Class Electric Helicopters 700 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
04-22-2011, 06:48 PM | #1 (permalink) |
What Tail Blades is Best?
Im going to be using Edge 693mm Flybarless for my main blades and was thinking of going with RotorTech 115mm for tail, I've heard from a lot of people that RotorTech is best for tail and that's about it, so will this be a good combination, Edge Main, Rotortech Tail? Ill be using the V-Bar on my T-Rex 700E
04-22-2011, 07:14 PM | #2 (permalink) |
Yes the RT tails are nice, well balanced and work well for sure so no worries on your selection there.
...Once upon a time there were Nitros, flybars & frequency pins...Shawn |
04-23-2011, 07:25 AM | #4 (permalink) |
I also had good experience with Edge and actually even Align did OK.
Currently I am running ZigSaw 115 mm tail blades. They are a bit more stiff and extreme light weight. Seem to work pretty good. |
04-23-2011, 07:35 AM | #5 (permalink) |
I have to give edge tails a. I had edge 115's on my 700e and had this tail vibe on the bench and a bad flutter in the air coming off of pitch. Switched to edge 105's and had a little less vibes and a little less flutter. Switched to kbdd's and no more vibes and no more flutter. However I don't like hard stops on the kbdd's. I think I'll try rotor techs if I can ever find them in stock next. I've always had good luck with the align and radix 105's too.
-Phillip Johnson, AMA #954735 |
04-23-2011, 08:30 AM | #6 (permalink) |
I was running EDGE 115s and got a nasty resonance above 2000 HS. Switched to Rotortech 115s and I can run 2200 smooth as can be! Also they are very light and perfectly balanced out of the package.
+1 Rotortechs
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR |
04-23-2011, 04:46 PM | #7 (permalink) |
agreed with the edge blades I was getting bad vibes above 1900 ish but with the RT smooth up to 2150 : ) great blades you can run the 120 if you mod your tail fin.
TRex-800E /Scorp 5035-478 5+5YY 1.8mm/VBar Blue Full 5.2Pro /CC Hv160/WR-Herc Super BEC/RJX 810mm 3D /RotoTech 115 + QuickUk Tail/ Hitec 7940th HV/TP 5000 65c |
04-23-2011, 05:56 PM | #8 (permalink) |
Do you guys balance your tail blades by just weighing each on a scale and making sure they're the same weight, or do you do something more elaborate?
04-23-2011, 06:50 PM | #9 (permalink) |
I balance mine using a blade balancer, but there really isn't an elaborate setup on them like you must do on the main blades.
If it can be done wrong, I will find a way to excel at it. |
04-23-2011, 07:38 PM | #10 (permalink) | |
paying good money for thos "cord and CoG matched blades" so why should I have to suffer from something you said you have all ready done? of course a quick throw on the balance or cog check to make sure its not my heli but ya..
04-23-2011, 07:44 PM | #11 (permalink) | |
04-23-2011, 09:05 PM | #12 (permalink) |
I just throw mine on a scale and make sure they are the same weight. Nothing other than that.
04-26-2011, 06:37 PM | #13 (permalink) |
the rotor tech's dont seem to be in stock any where does any one know where to get them
04-26-2011, 06:49 PM | #14 (permalink) |
I ordered two pair from rcecho.com on ebay. Took about 10 days from Taiwan, but I got them. Also they are Carbon Tech instead of Rotortech but they are identical blades, I'm sure they're both made at the same factory and one or the other is private labeled.
04-26-2011, 06:57 PM | #15 (permalink) |
Century...
I'm thinking that Century are the same ones too.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=180620330874
AMA 373608 |
04-26-2011, 07:54 PM | #17 (permalink) |
no century is an authorized dealer of RT blades
http://www.centuryheli.com/products/...?currentid=137
04-26-2011, 08:05 PM | #18 (permalink) |
I think they are the same!
04-26-2011, 08:15 PM | #19 (permalink) | |
04-26-2011, 08:23 PM | #20 (permalink) |
I'm sure they are OEMd for Century. Either way, they are the same thing as RT and fly just as good!
Both balanced at 5g on the nose!
