Old 07-26-2012, 10:27 PM   #41 (permalink)
Originally Posted by JustPlaneChris View Post
...I will be adding a 300X to my fleet within the next few weeks...
Good to hear!
That means I'll soon be able to listen to you guys talk about it on the show, which means more good listening material while I mow my lawn.
Hope you like it!
jaydekay is offline        Reply With Quote Quick reply to this message
Old 07-28-2012, 05:37 PM   #42 (permalink)
Received my Scorpion 2208-24 V2 today. I am VERY happy to report that it fit without any modifications what so ever. It is a tight fit though. With the Scorpion 11T pinion, clearance to the elevator link is slightly less than stock. I will keep an eye on that link. There are virtually no vibrations with the Scorpion motor installed as shown in this video.
[ame]http://www.youtube.com/watch?v=1AaoVooWemY[/ame]
As you may remember... here is the video of the stock motor to compare it with.
[ame]http://www.youtube.com/watch?v=A65gIZzp9bk[/ame]
Name:	Scorp V Stock (800x600).jpg
ID:	336070   Click image for larger version
Name:	Scorp (800x600).jpg
ID:	336071   Click image for larger version
Name:	Scorp02 (800x600).jpg
Ivan
9sec240 is offline        Reply With Quote Quick reply to this message
Old 07-28-2012, 05:40 PM   #43 (permalink)
And now on to the important part.... Does the tail still kick randomly as it did with the stock motor?
[ame]http://www.youtube.com/watch?v=kr-PwIdxhPA[/ame]
Not even a quiver. It looks like I can increase the tail gain too. Need to get it out in the open to find out.
Ivan
Old 07-28-2012, 05:41 PM   #44 (permalink)
But first... the HDX blades... Nice and quite too.
[ame]http://www.youtube.com/watch?v=JRFSyKiFJ8s[/ame]
Ivan
Old 07-28-2012, 06:12 PM   #45 (permalink)
Excellent
Can you measure the rpm with the Scorpion & 11T pinion ?!
Hubschrauberpilot is offline        Reply With Quote Quick reply to this message
Old 07-28-2012, 06:22 PM   #46 (permalink)
Night and day differnce there. Good work
MSH Protos Max V2 - Gaui X5/Hurricane 550 - Trex 500/450xl - Blade 300x/230s/mcpx bl
ukpaul is offline        Reply With Quote Quick reply to this message
Old 07-28-2012, 06:48 PM   #47 (permalink)
Originally Posted by Hubschrauberpilot View Post
Excellent
Working on that now. Do you happen to have stock motor head speeds at different throttle percentages?
Ivan
Old 07-28-2012, 07:27 PM   #48 (permalink)
Straight 75% throttle curve is 2900 RPMs
Straight 85% throttle curve is 3140 RPMs
Anything higher than 85% is essentially the same.
Put two packs through it. Very smooth. Tons of power. No tail issues. Slight bobble on cyclic on hard pitch changes. Other than that, flies much better than before. Flip and roll rate is almost too quick now. Might back it down just a little. I wish this heli would have come from the factory like this. (ie balanced motor and quality blades)
Ivan
Old 07-28-2012, 07:44 PM   #49 (permalink)
happy to hear that and good news to everyone!
whats your conclusion on this? everyone who has misaligned magnets should call HH for replacement? and most vibes issues are gone? maybe even the broken main shafts + servo link grinding? have u any slop up/down on your new motor?
thx.
affiliated with my wallet.
BLHeli with locator beacon now!
honkytown is offline        Reply With Quote Quick reply to this message
Old 07-28-2012, 08:03 PM   #50 (permalink)
Ivan, out of curiousity, what QC # do you have (small round sticker on frame)?
mixfisto is offline        Reply With Quote Quick reply to this message
Old 07-28-2012, 08:04 PM   #51 (permalink)
My conclusion is that my motor was built so poorly that it caused vibrations that effected the BX.
I would suggest that calling / emailing HH would be appropriate if you have heavy vibrations from your motor that cause issues with the BX.
Broken main shaft issues... can't really comment on that. I do think that a 2mm hole in a 4mm shaft is asking for troubles.
Links rubbing seems to be a combination of servo position, motor vibration, head vibration and possibly frame flex. I have checked mine and do not have rubbing issues. I am not a smack down 3D pilot though.
I have not received my new motor from HH so I can't comment on up and down movement.
Ivan
Old 07-28-2012, 08:05 PM   #52 (permalink)
Mine has a PASS QC12 sticker.
Ivan
Old 07-28-2012, 09:17 PM   #53 (permalink)
Just got done charging the two batteries I got to fly today with the Scorpion motor. 683mA and 712mA went back in the two. The flights were both somewhat easy 5 min test flights with lots of flips and rolls, full collective upright and inverted punchouts, full collective rainbows and just some regular circuits. Looks like the Scorpion motor is pretty efficient too!!
Ivan
Old 07-28-2012, 09:35 PM   #54 (permalink)
3100rpm at full throttle/0 pitch is a bit less than stock, my data logs show 3100 average, 3400 max with a V-curve and stock motor/pinion. Never checked full throttle at 0 pitch.
Of course youll have longer flights with less power than stock
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote Quick reply to this message
Old 07-28-2012, 10:10 PM   #55 (permalink)
RPMs were checked with an optical tach while hovering and not zero pitch. While the head speed may be lower than stock, it felt like it had more power. I would guess the Scorpion motor bogged less at full collective / cyclic.
Ivan
Old 07-29-2012, 03:31 PM   #56 (permalink)
Nice work Ivan!
Old 07-30-2012, 09:28 AM   #57 (permalink)
Nice work, i read there is 2 years warranty on the scorpion motor.
But they say you have to oil the bearings each 5-6 flights.
How do you oil the bearings of a BL motor?
Sounds stupid but i didn't know it needs that much oil.
DX6i, blade 450 3D, mcpx c05m, mcpx v2 stock. 2 x blade 300X, 1x 450X, 130X stock (for now) .
kvandenbroucke is offline        Reply With Quote Quick reply to this message
Old 07-30-2012, 09:49 AM   #58 (permalink)
How to vid.
http://www.youtube.com/watch?feature...&v=dRYdArrKMVI
Old 08-03-2012, 05:12 PM   #59 (permalink)
After unpacking I thought, That scorpion is not gonna fit in there,... But it does !!
Just love the great sound my 300X now has.
Old 08-04-2012, 10:26 PM   #60 (permalink)
What tooth pinion did you go with? I love how glass smooth the motor is!!
Ivan
