Outrage 550 Outrage 550 Helicopter Factory Support Forum |
01-09-2011, 07:19 AM | #281 (permalink) |
Lazor: I read lots of threads on servos and decided on these because of response time and price. I was planning on getting an external BEC anyway. I think having these servos just means I need one that can handle the power draw.
Is that what you're referring to?
T-Rex 250; T-Rex 450 Pro w/ Hitec HS65s and Futaba tail; Outrage 550 with Neu 1907, spartan quark, DS610 and 650 servos; Outrage Velocity 50 on the bench |
01-09-2011, 11:39 AM | #282 (permalink) |
Lazors comment is about it being WRONG to put Align parts on an Outrage... Like putting Chevy parts on a Ford.
01-09-2011, 12:24 PM | #283 (permalink) |
I meant you don't have to have anything that says align on your heli lol. They are good servos but they are rebagged Savox. The Savox look cooler and you can probably find them cheaper (unless you buy the aligns used or something) and they have a better wire color IMO. Savox also makes Spektrums new servos, so there the same. (not the crappy clear ones).
In short Savox 1258TG are the ORIGINAL servos align and spektrum just rebranded them (align ds610, not sure The spektrum number) and 1290MG are the same as the ds650. Take a look at them if you havn't bought the aligns yet. I am using the 1258TG on cyclic. And FYI, dodge>chevy>ford
Lincoln #HIGHONHELIS ):> Pull Hard RCHO Flying Field, Knightdale NC |
01-09-2011, 12:43 PM | #284 (permalink) | |
Tommy
Trex 700E FBL - PowerJive 120HV, 700MX, Fullsize Vbar, Telemetry, WR Super BEC, various KDE Upgrades Outrage 550 FBL w/mini Vbar, NEU 1907H1Y, CC 125A ESC, WR Super Mini BEC Outrage 550 - same as above but with flybar |
01-09-2011, 12:58 PM | #285 (permalink) |
If you look at this post, you will see I agree...
https://www.helifreak.com/showpost.p...6&postcount=18 |
01-09-2011, 01:19 PM | #286 (permalink) |
ahhh!
Got it. If the savox is the same as the align though (and the specs are almost exactly the same) does the savox also pull a lot of power for operation?
01-09-2011, 02:23 PM | #287 (permalink) |
Yes, Savox makes them and sells them as there on, Align & Spektrum get them to make some with there cases on them and then they sell them at a slightly higher cost. (although you can find Aligns pretty cheap in the FS forum and if you use them for cyclic servos and you use the wheels you won't really see Align. But you will on the Tail servo,which is Blasphemy! Just kidding but look,
vs. And vs.
01-09-2011, 05:29 PM | #288 (permalink) |
Sure they look the same, but how do you know that they are the exact same servo? Where are you getting your information?
Tommy
01-09-2011, 08:33 PM | #289 (permalink) |
Oh no I meant look how cooler the Savox look.
But it is known information that Savox makes Align Servos and some of the Spektrum servos. Plus readyheli also states it in the information. http://www.readyheli.com/SAVSC1258TG...o_p_37106.html http://www.readyheli.com/SAVSH1290MG...o_p_37107.html
01-09-2011, 08:41 PM | #290 (permalink) |
Cool...thanks for posting that. I've heard people say that these servos were the same before but I've never seen anything concrete (until now) that stated it.
Tommy
01-09-2011, 08:45 PM | #291 (permalink) |
Yep,
So the point of my original post- If you have yet to buy your servos, I would go for the Savox 1258TG on cyclic, and 1290MG on tail. They are the same as the Aligns, just have cooler looking cases (I have the 1258TG on my cyclics)
02-02-2011, 10:42 PM | #292 (permalink) |
Ok I can't edit my original setup post, it has changed a tad though. Here is the final setup.
Motor: Castle Creations Vertigo 3434-1100 ESC: Castle Creations ICE 100 w/ Castle Quick Link BEC: Western Robotics Super Mini Cyclic Servos: Savox 1258TG Tail Servo: MKS BLS980 Gyro/FBL Unit: Skookum SK-720 Lipos: XPS Platnium Plus 65C 6S 5000mah Pinion: 16T Revco Hard One Main Blades: Outrage CF 550mm Tail Blades: KBDD Orange 92mm Tail blades Rx: 2 JR remote rx's Connectors: Deans "upgrades" Quick UK rocket links all over Fusuno Hi-Vis Orange Fins
02-23-2011, 02:17 PM | #293 (permalink) |
Motor: Neu 1910-H 680KV
ESC: HobbyWing Platinum 70HV BEC: Align 6A Cyclic Servos: Inolab 751MG Tail Servo: MKS BLS980 Gyro/FBL Unit: MiniVbar 5.0 Express Lipos: Turnigy 10S 3600mAh 30C Pinion: 14T Main Blades: Outrage CF 550mm Tail Blades: TIG 95mm Rx: MiniVbar with 1 satellite Connectors: XT-60 The power is awesome. Now I will change the main gear for Fusion main gear mod 0.8. Very nice Thanks
Outrage 550 - Scorpion 740KV - Platinum 70HV - JR 8717 - MiniVbar 5.0 - Turnigy 10S 3600 Synergy E9 - Neu 1920H 510KV - Power Jazz - JR 8717 - Vbar 5.1 - Zippy 12S 5000 Synergy N9 - YS 91 SR- Hatori pipe - JR 8717 - 611 - MultiGov Pro |
