Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Compass 7HV, 7HVU and Chronos
Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion
Old 04-09-2013, 02:56 PM   #1 (permalink)
Default compass motor (KV fault)
i have just replace the magnets to the new one
set 15T pinion to V2 main gear
governor on 97.3% at 100% throttle
and i fill around 2100-2200 HS
i want more
dose any one try to make higher HS with governor ?
is is possible ?
thanks
itay007 is offline        Reply With Quote Quick reply to this message
Old 04-09-2013, 04:56 PM   #2 (permalink)
Something's really wrong with your set up if your only getting 2000-2100 @ 97% 100% throttle.
What esc and FBL and gov are you using?
Your gov should have at least 15% headroom.
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 04-10-2013, 12:10 AM   #3 (permalink)
I do believe the actual kv of the new motors is around 480-490kv. I don't know about your gov, but you should be able to get 2500+rpm with a 15t
Lincoln
#HIGHONHELIS ):>
Pull Hard
RCHO Flying Field, Knightdale NC
lazor 22 is offline        Reply With Quote Quick reply to this message
Old 04-10-2013, 12:15 AM   #4 (permalink)
nothing wrong with my setup
the castle software say that i gonna have 2300-2350 HS
but i had scorpion 5020 before and i know how 2300 RPM should sound like
did some one use fixed endpoint with that motor ?
Old 04-10-2013, 02:22 AM   #5 (permalink)
Not saying your equipment is wrong. More the set up. Like Lincoln said with that motor and pinion you should be over 2500 at 100%
So. Something's wrong with either your end points in the tx. Or low and high throttle calibration or the way you set your gov.
Have you tried it without the gov at 100% throttle?
Old 04-10-2013, 05:20 AM   #6 (permalink)
i didn't try with no governor
i hear that governor give you less 15% KV
what settings you use with your compass ?
Old 04-10-2013, 07:26 AM   #7 (permalink)
Both helis fly on the skookum gov.
1. 520 ultimate. Yge 160 13t pinion idle up 2 @ 2150
2. Compass motor 510kv. Yge 120
14t pinion idle up 2 @ 2150.
Both been tached and confirmed correct.
Heli 1 has been flown without gov @ 100% and gave me 2580 which was mental.
What gov are you using? Maybe your gear ratio is wrong?
Old 04-10-2013, 11:18 AM   #8 (permalink)
Default Re: compass motor (KV fault)
Gear ratio is 8.4
You work with gov in the compass motor ?
Old 04-10-2013, 11:34 PM   #9 (permalink)
I'm using 14T pinion with helical main - V2 SZ motor - run 2000 set rpm Governor mode CC 160a esc
-13 +13 pitch 10 degrees cyclic - 8khz - 18*timing - This setup works for me!
No bogging - 3D is a breeze - nice feel & sounds good.
When the 15T pinion arrives, I will set rpm 2100
Compassmodel / Savox / BavarianDemon / Fusuno / Rotor-tech / Revolectrix / Mks-servo / www.hobbyhangar.co.nz
Raynman is offline        Reply With Quote Quick reply to this message
Old 04-11-2013, 03:13 AM   #10 (permalink)
how many gain ?
can you please give me you full settings ?
thanks
Old 04-11-2013, 11:58 PM   #11 (permalink)
15 tooth Helical is available, is new part?
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 04-12-2013, 01:08 AM   #12 (permalink)
Synergy 15T Helical Cut Pinion Gear fit
Old 04-12-2013, 07:46 AM   #13 (permalink)
Yes it does but is aluminum, some are leary using this with some motors.
