Like Tree4Likes
Old 04-27-2009, 10:16 AM   #101 (permalink)
Team Taco VP
The AR7100 rev limiter works very well.... I would just keep it and use the MPG on your next heli.
Bob
Old 04-27-2009, 01:31 PM   #102 (permalink)
I think the point was that he wanted to use the MGP's mixture control, so it'll be on the heli anyway.
You could still save the MGP for another heli and opt for a CarbSmart on this one.
HeliFreak Support
Graupner MZ-32
Old 05-22-2009, 12:33 PM   #103 (permalink)
with the align sensor does it work ok?
MaSt0RaS is offline        Reply With Quote Quick reply to this message
Old 05-22-2009, 01:23 PM   #104 (permalink)
It should, but you'd have to do some rewiring (swap the + and - leads in the connector, I believe). Personally, I'd use the backplate sensor: you don't need to verify the magnet clearance every time you pull the engine out of the heli and you run a much lower risk of destroying the sensor in a crash.
HeliFreak Support
Graupner MZ-32
Old 05-22-2009, 01:26 PM   #105 (permalink)
i will buy one spektrum sensor but now i dont have it... do i need to do something else on spektrum sensor?
Old 05-22-2009, 01:27 PM   #106 (permalink)
Team Taco VP
That is correct. Swap the red and black wires. You will also need to put on a standard servo connector.
Bob
Old 05-22-2009, 01:34 PM   #107 (permalink)
Bob
yap for sure otherwise i cannot connect it
thx guys i will do it... but pls tell me what to do with the spektrum sensor is there a need to do something or its plug and play?
Old 05-22-2009, 01:44 PM   #108 (permalink)
Team Taco VP
Spektrum sensor is plug and play.
Bob
Old 05-22-2009, 01:45 PM   #109 (permalink)
It's plug and play. Simply remove two of the engine backplate bolts, run them through the sensor bracket, and screw them back into the crankcase. There's also a screw on the bracket to adjust the proximity of the sensor to the backplate. With the stock plastic bracket on my OS 50, I needed washers on the bolts between the bracket and the backplate because I couldn't pull the sensor far enough back to keep the bracket from flexing. You can get a third party aluminum bracket that eliminates the need for the washers and is much more robust than the stock plastic one.
HeliFreak Support
Graupner MZ-32
Old 05-22-2009, 01:47 PM   #110 (permalink)
It's plug and play. Simply remove two of the engine backplate screws, run them through the sensor bracket, and screw them back into the crankcase. There's also a screw on the bracket to adjust the proximity of the sensor to the backplate.
the sensor has to be 1mm from the backpalte or not?
Old 05-22-2009, 01:52 PM   #111 (permalink)
Mine's butted right up against the backplate, but some other people have had to move it back a little.
BTW, here a link to the aluminum brackets: http://www.alumafx.com/webstore/
HeliFreak Support
Graupner MZ-32
Old 05-22-2009, 02:03 PM   #112 (permalink)
it has the plastik bracket is there a need for an aluminum?
If yes i can do one..
Old 05-24-2009, 04:31 AM   #113 (permalink)
Good day everyone. will the curtis ATG magnet and sensor work with the MGP? thanks!
Alain
alain_soresca is offline        Reply With Quote Quick reply to this message
Old 05-24-2009, 11:03 AM   #114 (permalink)
Team Taco VP
Yes it will.... most gov sensors will work except the GV-1 sensor. Thats the only one I know that is different and only works with the GV-1.
Bob
Old 05-25-2009, 02:06 AM   #115 (permalink)
thanks sir Bob. i will start setting up later. good day and happy flyin!
Alain
Old 05-25-2009, 06:00 PM   #116 (permalink)
Hi All! I'm getting my T-Rex 700 and my questions 1. Can I use the "Switch Mount" (Manual - Item 94 Pg41) to place the servo for the mixture control 2. If yes, anyone have the size of that slot and recommended servo that can fit into it? 3. Approx length of the servo connector rod? Many thanks.
HeliBru is offline        Reply With Quote Quick reply to this message
Old 05-26-2009, 12:26 AM   #117 (permalink)
Team Taco VP
The Trex700 frame already has a place for mixture control servo! No mods needed. It is made for a HS65 servo size (mini). Link length I dont know but I used a long link from a Trex450.
Bob
Old 05-29-2009, 05:00 AM   #118 (permalink)
Default Aluminum mount
Thanks Bum. I just finished Frankenstiening my cracked plastic mount back together with epoxy. I ordered an Aluminum mount as soon as I read your post!!!
Boeing Freak is offline        Reply With Quote Quick reply to this message
Old 06-02-2009, 05:30 PM   #119 (permalink)
Default aluminum mount
Ron's Helipoz South is also carrying the mount:
http://www.ronlund.com/Merchant2/mer...t_Code=AFX001B
Old 06-11-2009, 01:28 AM   #120 (permalink)
Default multigov
Sir Bob,
Just wanna ask if you have a video of a multigov that is already set-up on your heli and do the test flight? would you choose limiter rather than gov?
thnx
walles2002 is offline        Reply With Quote Quick reply to this message
