Beam Beam Helicopters Factory Support Forum |
09-14-2014, 11:12 PM | #1 (permalink) |
V2 (2013) Autorotation bearing fitment.
I have both V2 and V2 (2013) bearings, cases and sleeves. The V2 fits fine as per original bearing. The V2 (2013) bearing protrudes beyond the bearing case and makes it impossible to fit through the gap in the frame with the pulley and sleeve assembled. It also means that the main gear wont align with the pinion. Has the lower mainshaft bearing block been changed? Any hints or tips? My heli is a V1.
You are only as good as your next crash. |
