Go Back   HeliFreak > R/C Helicopter Support > 500 Class Electric Helicopters > RCDN 500 Nitro Conversion
RCDN 500 Nitro Conversion R/C Depot Hobbies RCDN 500 Nitro Conversion Kit Support
Old 05-23-2009, 09:34 PM   #21 (permalink)
I used the stock plastic rx tray by cutting it down and mounting it over the tail boom block to mount the Rx so when servicing the tail boom you don't have to remove the Rx.
Cheers, Glenn
Outrage Fusion 50 FBL SK720 12s Xera 4025-560,Kon.HV 80 ,JR8717,OR 9088 on 6v TP 6s 65c 3300's
Trex 700CHP FBL SK720 MX510,Kon HV 80, JR 8717,OR 9188, 6v, TP 6s 45c 4400's
Gernejr is offline        Reply With Quote Quick reply to this message
Old 05-29-2009, 09:05 PM   #22 (permalink)
Originally Posted by BenHeli View Post
RCDepot/flyhelirus now offers the milled back plate and metal mounting bracket for those running the Spektrum sensor.
I wish I knew this ahead of time...I just ordered my kit today and wish I had these parts ordered at the same time.
Team Synergy- YS Engines - Coolpower
puma1824 is offline        Reply With Quote Quick reply to this message
Old 06-07-2009, 06:28 PM   #23 (permalink)
Just redid the 500n i cut down the battery tray and turned it upside down mounting it ove rhte boom with 2 screw then place a small piece of 2 way tape to hold the back of the tray to the boom . Now if i strip TT gears only remove tray and pull boom housing out.
also use my Mircoheli CF Rx tray in place of RCDN gyro mount to hold my Mutligov ..
Cleaned up some wiring by installing the 5.1 step into the 770 wiring and shorten the wire goingto th Rx.
ID:	100845   Click image for larger version
Cheers, Glenn
Old 06-30-2009, 12:39 AM   #24 (permalink)
Redid wiring for better Multigov placement. Used the supplied gyro mount and tilted in slightly at an angle and secure Multigov on top. Clears canopy with no problem.
Vbar and other electronics placement:
Basically used the supplied radio tray attached to the motor mount for the Vbar module on top and the Futaba RX mounted upside down underneath. The Align 2-in-1 is mounted to the baseplate and the portion where the writing is sits neatly under the suspended RX. The fuel tank sit up against, not on, the 2-in-1 where the wires come out. Mounted the battery under the bottom plate. Vbar sensor on top of boom mount (I did NOT try the front mounted sensor plate).
Old 07-10-2009, 10:49 AM   #25 (permalink)
Wow, real neat installation Puma 1824.
MM
MetalMagus
IF IT FLIES, I CAN CERTAINLY CRASH IT!
metalmagus is offline        Reply With Quote Quick reply to this message
Old 12-29-2009, 01:34 PM   #26 (permalink)
There is just so much stuff all condensed into that heli ha.
I want one!! Would it be worth putting the header tank on? the kit doesn't come with one but I assume that it would give you a little more flight time... thoughts??
Mike
MKlinkerRC is offline        Reply With Quote Quick reply to this message
Old 01-03-2011, 04:28 AM   #27 (permalink)
Originally Posted by lowflyer101 View Post
they are working on 700e
so now that the 550E and 700E are out do you think the 500N is on the cards?
Im only new to nitros and love my 500N, so i think this would be a match in heven.... Does anyone know of any conversion kits out there?
Cheers Kallen
Stretched Trex 500 with ino-labs all round
kwesty2008 is offline        Reply With Quote Quick reply to this message
Old 01-24-2011, 03:07 AM   #28 (permalink)
I doubt it but, we were thinkin about throwing a .50 into the 550.
!Team! - Carson - FYOURFACE - Low Budget - Tail-In
amp3seven is offline        Reply With Quote Quick reply to this message
Old 03-24-2012, 09:38 AM   #29 (permalink)
Lightbulb
Well, to revive a dead thread...I have been seeing engine temps get too high despite how rich you make it. I eventually realized that the air-flow over the cylinder head is no where near enough. I use an Align 2 in 1 so, I have a push glow system. I cut the aligator clip that the 2 in 1 has for the glow plug and put a 'pull the wire, place on glow plug and release the wire' deal on there. I covered the hole in the fan shroud for the glow plug and sat the fan shroud tilted slightly forward OFF of the cylinder head, on TOP of the glow plug boot.
I also covered the rear of the fan (shroud off) w/ a piece of curved plastic attached firmly so the airflow isn't lost into the frame ...this should have been considered to begin with if you ask me.
But basically, the air flow has now MORE THAN doubled and I now see appropriate temps (according to how rich I make it, etc.) I am now able to use the MultigovPRO feature w/ a mixture control solenoid...I even have co-ilot 2 and a 2nd header tank on this insane trex 500!
love this ship!
SKYQUEST is offline        Reply With Quote Quick reply to this message
