Old 01-31-2013, 01:05 AM   #1 (permalink)
Default "Tick" in drivetrain?
Just spinning my Protos over by hand and I can hear a mild ticking noise somewhere near the boom block, also, the belt appears to be not running centrally on the tail pulley, any suggestions?
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote Quick reply to this message
Old 01-31-2013, 01:40 AM   #2 (permalink)
Tick typically gear tooth. Sloppy belt? maybe not tight enough ?
rojack is offline        Reply With Quote Quick reply to this message
Old 01-31-2013, 02:10 AM   #3 (permalink)
Nick up the boom block bolts.
Put some oil on the pulley bearings.
Pulley belt pulleys out, check bearings(if bothered).
[B]TT E820 - Kosmik 200, Scorp 5035 TT G4.1(x2) - OS 91 3D Speed, Hatori
MSH Brains + JETI DS-16
rossk is offline        Reply With Quote Quick reply to this message
Old 01-31-2013, 02:50 AM   #4 (permalink)
Cheers guys, I'll give those things a try.
One thing I never really figured out on the Protos was how tight do I want my belt?
Atom 500
Spektrum DX8
Old 01-31-2013, 06:58 AM   #5 (permalink)
I run mine reasonably tight, I've had a few belts come off, so I keep them a bit tighter now and so far haven't had a problem.
Mini Protos can be run a lot looser in comparison, never had one of them come off
Old 01-31-2013, 07:28 AM   #6 (permalink)
I had same problem with mine and my belt was not tracking properly.
Found sloppy bearings in idler pulley. Usually a tic on Protos is a bearing going bad since there is no gear mesh. Either tail pulley or tail support box idlers.
Rick,
Team pilot ,
crickr1 is offline        Reply With Quote Quick reply to this message
Old 01-31-2013, 07:59 AM   #7 (permalink)
Cool
I thought that sound is normal when turned by hand. it is the belt meshing on the main gear.
change your belt if it bothers you
as far as tension is concerned too tight is much worse than loose
it should be only tight enough to stop the belt from slipping, start with the motor then the tail
Spending time, Paying attention
Bladefx is offline        Reply With Quote Quick reply to this message
Old 01-31-2013, 08:23 AM   #8 (permalink)
also make sure you dont have any extra twists on the belt. it should only rotate 90* inside the boom.
I'd rather build 'em than fly 'em
tat2spyder is offline        Reply With Quote Quick reply to this message
Old 01-31-2013, 08:44 AM   #9 (permalink)
The harder (lots of cyclic in maneuvers) you fly, the tighter the belt needs to be. Otherwise you will get belt skipping and lots of belt dust. I used to follow the 2-3mm gap recommendation by MSH. But as my flying progressed, I could hear the belt skip during some moves. So I tightened it some more (probably 1mm gap) and no more belt skipping.
MSH Protos 500, SAB 630
alexf1852 is offline        Reply With Quote Quick reply to this message
Old 01-31-2013, 10:53 AM   #10 (permalink)
Check your OWB inside the pinion too. That one also gets loud when it's about to fail.
PRÔTOS 500 FBL "Sky Whip" | Robird G31
Goblin Speed | iKon
Old 01-31-2013, 01:05 PM   #11 (permalink)
Make sure you don’t have an extra twist in the belt inside the boom. Also, when you tighten the belt you have to pull tension in two directions with motor and the boom. For example, if you have too much tension on the boom side and not enough on the motor side then the belt teeth won’t line up correctly on the main gear.
mattmezz is offline        Reply With Quote Quick reply to this message
