Old 05-07-2013, 11:30 AM   #21 (permalink)
Cal, looks like this was made into an official sticky, even for the information you have in here. Just needs to be cleaned up some, given a proper title and as more information comes in you can edit as you have been doing to complete this.
It's real exciting to at last see a sticky here, especially for those who say "just got my 300x, is there any issues or anything I should be made aware of?" LOL
Steven
mCPX BL, BL nano, 300x, TREX 450 Pro DFC, Spektrum Dx9, iCharger 206B
dragon79 is offline        Reply With Quote Quick reply to this message
Old 05-07-2013, 02:32 PM   #22 (permalink)
Glad you're doing this work, I PM'd you links to all the videos I have bookmarked as I read the forums here for my initial setup.
FP - Blade mCX2/mSR {x2}/Nano QX{x2}/120SR - Syma s107g - Xieda 9998{x2}
CP - Blade Nano CPx/mCPx(v2+BL {x2})/CP Pro 2(Scale Build in Progress)/300x/300xSS(Benched)
TX - Spektrum DX6i/DX8
jcmo is offline        Reply With Quote Quick reply to this message
Old 05-24-2013, 07:04 AM   #23 (permalink)
Agreed on the zip tie method for the skids. In a crash those will break, instead of the frame breaking. You need a total of 8 zip ties for this.
I like the Blade alu rear grips, takes away the slop that generates in the stock plastic ones.
Batteries: Nano-Techs are great, noticeably more powerful that stock E-Flite batteries. And very cheap too. Buy at HobbyKing.
CNC'ed main gear from Lynx or MicroHeli (also has anti-rotation hub). The stock gears are cast and normally a bit uneven, generating vibrations. Which is never a good thing in a heli.
Dyeing for different colors: Tail fin, upper fin and tail blades take color very well. Use RIT dye. Don't try to dye the skids and main gear, they don't take color well at all.
Lynx dampers are great, more precise.
You don't really need alu upgrades in the main head, it's mostly for bling.
The Turnigy SuperBrain 40A works fine with stock servos. It has logging, is light, and has a governor feature. You can also use a Turnigy programming box with it. Plus a USB adapter in order to load the logs to your PC.
Great tread, should be one like this for every heli!
Micro: OMP Hobby M1
Big: SAB Goblin 500
Radio: Spektrum DX8 Gen 1
Old 05-24-2013, 01:33 PM   #24 (permalink)
You can zip tie the skids to the frame to prevent the lugs breaking as already mentioned, or you can change the skids for nylon bolts like I did:
https://www.helifreak.com/showpost.p...2&postcount=32
Blade 180CFX | 300X
MSH Mini-Protos 3S, Spirit FBL
Parkmaster 3D, Funjet, Sbach 3D, FrSky Taranis, FPV260 Quad, Pheonix Sim
stevebaker is offline        Reply With Quote Quick reply to this message
Old 05-29-2013, 07:31 PM   #25 (permalink)
Default Shake in the tail
I was chasing a pretty severe tail wag with some major vibes as well. No tail blade balancing fixed anything. Align tail hub cured the wag and the vibes were lessened. Added the aluminum pitch slider and lever as well. Tried Lynx blades as well. It developed a nasty shake in the tail that made it unflyable. Was suggested by LHS to change out the bearings in the tail case so I did and shakes all gone. Heli only has about 20 packs through it and that is the second set of bearings that have gone bad. First was the motor bearings which HH did send me a new motor.
So if you develop a high speed, side to side shake in the tail, change out the bearings, $6.
Marty
CrashCanuck is offline        Reply With Quote Quick reply to this message
Old 05-30-2013, 04:19 AM   #26 (permalink)
Marty
Is there a BOCA bearing kit for the 300X?
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 05-30-2013, 05:47 AM   #27 (permalink)
Default Tail pitch slider mod
See post #183
https://www.helifreak.com/showthread...495364&page=10
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 05-30-2013, 03:52 PM   #28 (permalink)
There certainly is. $26.99 for a full set of steels. $80.95 for a full set of ceramics.
Of course you can order them individually if you don't want a full set.
The only ones they don't include are the small thrust bearings in the tail grips. (apparently they just don't carry thrust bearings that size)
http://www.bocabearings.com/search.a...0%20X&Feature=
Those are the bearings in the frame, head and tail case of the helicopter. However; they do also list them for the stock motor if you have that...it's says its for the 420H but the 320H has the same bearings.
http://www.bocabearings.com/search.a...=420H&Feature=
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 06-11-2013, 06:40 AM   #29 (permalink)
More details on the cable tie method:
https://www.helifreak.com/showthread.php?t=539036
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 06-11-2013, 10:53 AM   #30 (permalink)
Default Re-building the main rotor assembly
Thought I'd update and post this very useful diagram that "kenkadish" was kind enough to post in another thread.
Thought it useful for others to post here as this thread is a Sticky.
Blade 180CFX | 300X
Old 06-12-2013, 09:41 AM   #31 (permalink)
I would like to add to the crash kit.....
FBL links these tend to go missing with the tip of the blade grip
Servo pushrod links
Main Gear hub
Spare jesus Bolt upper and lower
I would also like to see some more info on ESC upgrades :-)
Ive personally opted for the same as DCH and gone for the Tunrigy AE45-A. I have flashed the firmware with BLheli (10.2) software (as famously used on MCPX's) VERY nice easy setup.... Of course the ESC fits the 300x perfectly in stock position. Has 45 amp continous capability and a 4 amp BEC So will cope with servo and motor upgrades. Not to mention programing capabilites far beyond my understanding but the gov mode is a nice option.
So far im running CF blades with Savox 0257's (cyclic) and 0264 (tail), Scorpion 2213-14 (13t) Gov 3500 HS, Turnigy AE45-A ESC set at 6v output. AD brace, Lynx head, tail blades and dampers, Fusano tails fins, zip tie landing gear, Ar7200BX in stock position but using 3m tape, Align tail hub and grips. Im VERY happy with this setup. FYI i run Turnigy Nanotech 45's Lipo's because it pulls quite hard on the power so a high C rating is prefered. Noticable decline in power when using stock or lower quality Lipo's.
AUW is 431g (no battery)
BLADE 500Xc, 300X, MCPX V2 BL, 130x Red Bull, Hubsan X4 Quadcopter, DX7s
sn00p is offline        Reply With Quote Quick reply to this message
Old 06-17-2013, 05:04 AM   #32 (permalink)
Anyone know if there is a weight difference for the ceramics vs. steel?
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 07-27-2013, 04:47 AM   #33 (permalink)
Originally Posted by dony45 View Post
I would assume your talking about the 450 size. On Align, I don't think all the align 450's have the same tail hub and grips does it matter which ones you use, V2, Sport, Pro, DFC, ect. ?
I notice that there was no response to the above posting.
I have found a cheap source for the Align 450 Pro/Sport Metal Tail Holder Set TL450034-03
Is this set compatible with the 300X and if so does anyone have a part number for tail rotor blades? There seems to be a choice of "plastic" (H45035?) or carbon fibre.
Any information gratefully received.
Aerotony is offline        Reply With Quote Quick reply to this message
Old 07-28-2013, 06:03 PM   #34 (permalink)
Anyone the align tail hub and grips work... Arguably the tarot or align thrust bearing versions are best... I personally run the old cheap plastic version non thrust type.
As for tail blades use 300x compatible blades of your choice. I use lynx but would like to try a set of kbbd's when I find a set in the uk.
Old 08-01-2013, 08:10 AM   #35 (permalink)
Default Link lengths
I know not all are exact, but what is the general lengths for all links?
Purchased Blade's metal servo arms and now they are not 90* to the main shaft!? Reinstalled the plastic, ok. Should I recenter in the Bx? Or take a lost and go back to plastic?
Rick
Nano QX, MCPX, SR 120, 130x, 300x, 450 3D, 450x
Razskidoo is offline        Reply With Quote Quick reply to this message
Old 08-02-2013, 02:37 AM   #36 (permalink)
Rick
90 the servos, then adust the links so that the swash is level - preferably using a leveling tool. Then do the rest of the BX setup.
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 08-21-2013, 11:21 AM   #37 (permalink)
Default Tail Grip Assembly
Tail grips assembly photo:
Note, I also found I needed an extra thicker shim (as well as the standard 2 shims) to remove lateral play in the grips.
Just assemble dry to check this out before loctiting the bolts.
Blade 180CFX | 300X
Old 12-16-2013, 12:01 PM   #38 (permalink)
what is the stock FBL linkage lenght?
spruemaster is offline        Reply With Quote Quick reply to this message
Old 06-13-2014, 09:40 PM   #39 (permalink)
Since this thread is a catchall, I added Shy's links to worthy threads in post 1. I'm not sure this is the long term solution but at the very least, it makes them easily accessible in the mean time.
Rick
Helifreak, the place to be!
rdlohr is offline        Reply With Quote Quick reply to this message
Old 06-29-2014, 07:23 PM   #40 (permalink)
Thus, if you hit throttle hold before a crash, you take away the FBL controller’s ability to strip your servo gears.
How do you figure that ?
TH does not remove power from the AR7200BX or the servos , fact is servos will still be powered and trying to move.
I only pointed this out due to you comment
The downside of a sticky is that it lasts a long time so you don't want misinformation,
mS/R --3ea. mCPX 2 converted to BL 4ea. mCPX BL 2ea. BL-130X
400 FBL ,.Blade 450X ikon Blade 450X with Ar7200BX
Blade 300X MIcroheli CF frame many upgrades 230S , LOGO 690 Brain / HD , Trex 450 Pro with Brain ,planks...
everydayflyer is offline        Reply With Quote Quick reply to this message
