Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Compass 7HV, 7HVU and Chronos
Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion
Old 08-10-2013, 09:48 AM   #1 (permalink)
Default Hot Compass SZ 4926 motor?
Just finnishing the build of the 7HV. Everything went smooth as butter :-)
Motor is the Compass SZ 4926, and the esc is the Hobbywing 120hv pro.
When i spin up the motor mounted on the heli, on the bench, without the main blades, but with the tail blades, it runs pretty hot after a short period of time, in about a minute it is 42C (107-108F) Is this normal?
If not, could this heat be caused by wrong settings in the hobbywing ESC? Like hz or timing settings.
What else could cause this?
And btw, what settings are you guys using on this esc with this motor?
Thanx in advance :-)
Yozim
Gravity never loses. The best you can hope for is a draw!
Compass Atom 7HV, Align T-rex 550E DFC, Align T-rex 250Pro DFC, Align T-rex 250 Pro
Yozim is offline        Reply With Quote Quick reply to this message
Old 08-10-2013, 09:54 AM   #2 (permalink)
That's not all that hot to be honest ... most of my motors come down between 100-130F
If your ESC and packs come down warm (not hot) then all should be well. If you want it to run cooler, you can adjust your PWM and timing.
Jeff_Barrett is offline        Reply With Quote Quick reply to this message
Old 08-10-2013, 10:44 AM   #3 (permalink)
by memory using the HW120 - 12pwm & 18.75 timing - i used these settings with NO issues.
Compassmodel / Savox / BavarianDemon / Fusuno / Rotor-tech / Revolectrix / Mks-servo / www.hobbyhangar.co.nz
Raynman is offline        Reply With Quote Quick reply to this message
Old 08-10-2013, 11:12 AM   #4 (permalink)
Thanks alot for your teplies guys. I'll compare my settings to yours Rayman, and if i dont remembering wrong here my settings are like yours
Thanks again :-)
Yozim
Old 08-10-2013, 02:11 PM   #5 (permalink)
I am running same settings as ray man also. Mine also gets very hot like that after being on for 30 seconds on the bench. After an entire flight mine hits 160 on the windings.
Protos 380
Protos Max V2
vinnyd is offline        Reply With Quote Quick reply to this message
Old 08-10-2013, 02:11 PM   #6 (permalink)
If you can touch the motor and hold your hand on it for at least a couple seconds - you'r fine. It means you'r under 75C. If temps are above that, I'd check for any bad bearings or gear mesh, although high-end motors with such winding as SZ4926 are safely rated for well above 110C, although such temp is already bad for main gear. peace
ciobrelis is offline        Reply With Quote Quick reply to this message
Old 08-10-2013, 06:26 PM   #7 (permalink)
Pwm set to 8 on mine esc..sat it to 12 now, new chech tomorrow. Hopefully maiden too... :-)
Thanx alot you guys :-)
Yozim
Old 08-11-2013, 02:08 AM   #8 (permalink)
mine gets around 153F on a 65deg day
(***WARNING*** Stop Spamming Helifreak)
freedom is slavery.
Citizen 375
Fly it like you stole it
Money does bring happiness, never seen a sad person on a jet ski
redsoper is offline        Reply With Quote Quick reply to this message
Old 08-11-2013, 11:56 AM   #9 (permalink)
Its typical for a motor to heat up fairly quickly if you run it on the bench without a load. But 42C is not even close to being hot though. Fly it and measure the temp then. I'd be concerned only if it got over a 100C for example. All the motor components including epoxy used are designed to take at least 150C temps and in many cases even more but the problem is once the magnets get hot enough they lose their magnetic strength which results in decreased power output. So if you get temps between 60C and 80C after flight its normal.
belcom is offline        Reply With Quote Quick reply to this message
Old 08-11-2013, 03:20 PM   #10 (permalink)
Temp gunned my compass motor today and the windings were at 132c and can 99c. This is with the Gmauro heatsink mind
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 08-11-2013, 04:42 PM   #11 (permalink)
That's a little high. Toasty I would say.
Old 08-11-2013, 05:51 PM   #12 (permalink)
Ha ha, what a knob. Should have put F as in Fahrenheit.
Old 08-11-2013, 05:58 PM   #13 (permalink)
Hahah knob. Haven't heard that in a while.
Ian
7HV ULT TracX | 550U TracX | DX9
NZ Heli thread - https://www.helifreak.com/showthread.php?t=480630
Magnazan is offline        Reply With Quote Quick reply to this message
Old 08-16-2013, 01:38 PM   #14 (permalink)
Knob? LOL
As such, sounds right where it should be.
= Rb43 =
Rob43 is online now        Reply With Quote Quick reply to this message
Old 08-16-2013, 04:45 PM   #15 (permalink)
Wow that heat sink makes one heck of a difference!! Did you cut any vents into your canopy also?
Protos 380
Protos Max V2
Old 08-16-2013, 06:22 PM   #16 (permalink)
No holes at all. It's massive Click image for larger version
Old 08-17-2013, 08:21 AM   #17 (permalink)
hmmmm where do you get this heat stink haha... i want one..
Blade 180 CFX, Sold the rest of my stuff, I dont really fly all that often any more.
dannylightning is offline        Reply With Quote Quick reply to this message
Old 08-17-2013, 08:54 AM   #18 (permalink)
Gmauro direct.
Old 08-30-2013, 09:47 AM   #19 (permalink)
Was testing this great bird couple of weeks ago with a flat 70% trottle curve. Motor abot 87-90C after flying one pack. Thats TOO HOT!
So what I did was to increase the trottlecurve up to flat 90 curve, after recommandations from a couple of great guys at our local club.
Result: motor temp about 70C, which is ok, but still a little hot.
Cut a couple of holes in te canopy, to get a little cooling for the motor.
Tested it today, and temperature is great, 55C.
Here is a pic of how I did the holes:
HDClick image for larger version
Name:	ImageUploadedByTapatalk HD1377873911.739573.jpg
Thought this could be a little helper for someone else who mabye is strugling with the same motor temp "problem"
Yozim
Old 09-06-2013, 12:01 AM   #20 (permalink)
Ordered the same heatsink from Gmauro. I think I have lost track of all the goodies in the mail...
Primal is offline        Reply With Quote Quick reply to this message
