Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 12-30-2014, 07:08 AM   #41 (permalink)
little Christmas present http://www.mercadorc.es/epages/ea868...ducts/SA00016A
some fusion 50 spare parts
markos51 is offline        Reply With Quote Quick reply to this message
Old 12-30-2014, 08:00 AM   #42 (permalink)
Originally Posted by Dmaxison View Post
Good to know about the feathering shaft. There is no issue with tail gear ratio since the Align gears only fit the tail box. 1:1.
There is no drop in solution for the front transmission gears. The latest design (by Outrage) increased the tail speed slightly.
(Outrage)
Umbrella gear info... 22 tooth to 18 tooth driven gear.
Since I have spares I haven't had to try the Align gears in the rear tail box. I'm pretty sure the Align gears have a 1:1 ratio at the tail rotor. Most heli designs control the tail speed at the transmission by changing spur gear and/or auto rotation gear.
Someone needs to count the teeth and report back...
Team Only Fine Helis
Flown on Jeti DS-16, Brain2, RCHN #222
MKS Servos, Scorpion Tribunus, MSH P700, Synergy e5s, N5cTT
Dmaxison is offline        Reply With Quote Quick reply to this message
Old 12-30-2014, 09:32 AM   #43 (permalink)
OMG i'm a tool! I got fooled by Loctite 406 whilst trying to adhere the flanged bearings into the frames and it sucked a big drop straight into theose flanged bearings like soLder into a well heated wire!! DAMN IT!
Considering how hard parts are to come across (even though this is just a bearing and i should be able to find one somewhere... somehow), this may spell the end to the build getting done in my last week of time off work! *sign/cry* lol
EDIT: Crisis averted, for now! Got the bearing running mostly free so that should do it for the time being.
HoffY is offline        Reply With Quote Quick reply to this message
Old 12-30-2014, 08:43 PM   #44 (permalink)
Glad to hear! Shouldn't be too much of problem unless your running some really smooth servos. Doubt you'll notice.
Old 12-31-2014, 08:38 AM   #45 (permalink)
Guys I have a BNIB oem boom with TT and un-used black front and rear tail gears. You cover shipping and a price of a burger and its yours. Trying to help fellow HF members.
Slow & Steady!
nmdesertracer is offline        Reply With Quote Quick reply to this message
Old 01-07-2015, 05:11 PM   #46 (permalink)
Shoot me a price, I am trying to keep my Fusion 50 for one more season and could use the parts.
Align Trex 700 V3 DFC HV - Vcontol Touch ¦ Mikado Logo 200 ¦ SAB Kraken 580 ¦ Align Trex 500X ¦ Sab RAW 500
Raydee is offline        Reply With Quote Quick reply to this message
Old 01-08-2015, 12:43 PM   #47 (permalink)
I've been PMing back and forth with nmdesertracer since last week about this...
* Goblin 700C, iKON, Torq 9180/9188, Quantum 4530-500, Edge HV160, Cyclone 695
* Outrage Fusion 50, SK-540, Torq 9180/9188, Quantum 4135-530, Edge HV80, SAB 630 Blk 3D
* Align T-Rex 500E DFC, SK-540, ICE 75
* Futaba 14SG
Arcturus97 is offline        Reply With Quote Quick reply to this message
Old 01-08-2015, 01:42 PM   #48 (permalink)
Got it... 20 1:1 ratio.
Gaui X5 (Waiting for parts)
Outrage Fusion 50.
Aurora 9
tolenca is offline        Reply With Quote Quick reply to this message
Old 01-08-2015, 02:57 PM   #49 (permalink)
Thanks for the post!
Old 01-08-2015, 08:32 PM   #50 (permalink)
My Pleasure...
Outrage Fusion 50.
Aurora 9
Old 01-14-2015, 09:49 PM   #51 (permalink)
Sorry for the late response stuff went to acturus97
Slow & Steady!
Old 02-21-2015, 10:28 AM   #52 (permalink)
cnk
I've got a NIB kit with 2 sets of black gears up for sale in the FS forums. Bought it back in 2011 and never got around to building it.
https://www.helifreak.com/showthread.php?t=682844
cnk is offline        Reply With Quote Quick reply to this message
Old 02-22-2015, 12:22 PM   #53 (permalink)
My Fusion is still flying.I try to find replace Outrange spare parts.I found out that Align trex 700 boom and tube is ok for use if you cut the right length.
I canot find main gear.
Old 02-22-2015, 04:17 PM   #54 (permalink)
Are you looking for the regular main gear or the Delrin CNC main gear?
Scorpion Power Systems
Michaelinpr is offline        Reply With Quote Quick reply to this message
Old 02-22-2015, 04:33 PM   #55 (permalink)
Good to know. Do you also use Align torque tubes? I would assume you could cut those down as well.
This is gonna cost me.
aburkhardt is offline        Reply With Quote Quick reply to this message
Old 02-24-2015, 10:57 AM   #56 (permalink)
I need black main gear or white but not the old spare part.I have mx700 motor and it is too powerful.
Yesterday i tried Fusion with shorter trex 700 boom.It fits on the front main gear box but the in the tail box does not fit all the way in . Align boom is a little larger.No problem
I had on the trex 600 black back tail gear.
In normal mode it looks ok but in idle1 (2100) i had a terrible tail swish.
As i noticed align part has 2 more teeth that original so maybe the tail blades were over speeding.When i changed with original spare part everything was smooth even 2200.
Outrage torque tube suit in Align boom.I compared trex and outrage tube looks exactly the same.If you cut and drill holes you can use it for fusion (not tested)
Of course Align spare parts are not cheap but i found clone trex 700 in hobbyking site
Assault 700 DFC
I have 2 Fusion 50 6 s and 12 s and i will try to keep them on the air.
I have some spare parts but i need to stock or find spare parts to replace originalsome.
Old 02-25-2015, 06:58 PM   #57 (permalink)
Sorry, all I have is the original white main gears.
I have never used the Align gears for the tail. If both gears in the tail have 2 more teeth than the Outrage ones, It would not change the gear ratio. You still are maintaining a 1 to 1 ratio with the front tt gears. Maybe the gears you tried were out of round or something.
Old 02-26-2015, 10:42 AM   #58 (permalink)
Finally Align tail gears fits ok.Probably my previous install had a loose screw or something like that.
Also Align boom works fine.Lets try find spare parts for Fusion.
I have some photos on photobucket please pm me how to upload.
Old 03-23-2015, 01:08 PM   #59 (permalink)
Align torque tubes probably fits if you cut the right length.Id is the same.
Old 04-11-2015, 08:28 AM   #60 (permalink)
Looking for parts for a Fusion in Canada?
flyswatter40 is offline        Reply With Quote Quick reply to this message
