Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > SR
SR Blade Helicopters (eFlite) SR
Old 09-13-2011, 12:58 PM   #61 (permalink)
Originally Posted by E_heli View Post
Looking good, keep the video coming, show your no bar BSR next.
i dont think ill go no bar on the SR, not planning on doing any thing but flyinig it the way it is. but FBL is king on smaller helicopters, on my 550 i did not feel the need to go FBL but on a 450 or 500 its really makes a difference, i am sure it would have on the 550 too but it was so smooth and stable in the air already.
Blade 180 CFX, Sold the rest of my stuff, I dont really fly all that often any more.
dannylightning is offline        Reply With Quote Quick reply to this message
Old 09-13-2011, 02:29 PM   #62 (permalink)
Hi, Danny, strange to see you back! a good surprise
Estarter originally just took the Flybar off, but then went to FBL electronics later - post 18 onwards
I was really amazed just how well it flew without any stabilization - kudos to the pilot
toys2cars2toys is offline        Reply With Quote Quick reply to this message
Old 10-08-2011, 01:13 PM   #63 (permalink)
Originally Posted by SYMAWD View Post
Is there anyway the mCP X's board can be wired into the SR's power system so that the FBL unit could be used?
Just pick up a good mcpx board, I have another spare frame, I will try to stick with the stock 2in1 using the steve board for the tail motor control, let's get to work. . .
estarter is offline        Reply With Quote Quick reply to this message
Old 10-08-2011, 04:11 PM   #64 (permalink)
Popcorn time - that's a nice twist on your already interesting FBL SR
I'm sure you will have already seen this thread, well worth a look if you haven't
http://www.rcgroups.com/forums/showthread.php?t=1429963
With some inspired thinking, this guy used an mcp 3 in1 to control just the cyclic servos and a separate RX for throttle and rudder with gyro as usual. Both RX's are bound to the TX
Old 10-08-2011, 06:06 PM   #65 (permalink)
Thanks for the link, a lot of info, I plan to use the tail gyro in the mcpx board to control the stock DD tail motor.
Old 10-08-2011, 06:15 PM   #66 (permalink)
That's cool, I guess the fixed tail gyro gain could be a potential problem...but there's only 1 way to find out. If you do have problems, you could look into changing the tail blades for those with different diameter/pitch, effectively changing the overall gain
Will you need two "thesteves"? ...Main and tail?
Should be good
Old 10-08-2011, 06:19 PM   #67 (permalink)
Very interested to see how it turns out.
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
SYMAWD is offline        Reply With Quote Quick reply to this message
Old 10-08-2011, 08:58 PM   #68 (permalink)
me as well.
just got my SR in the air again today after months of letting it collect dust.
cheers,
robb
astrorobb is offline        Reply With Quote Quick reply to this message
Old 10-09-2011, 04:59 PM   #69 (permalink)
That could work, though you'd have to be careful not to burn the board. It's a lot of wiring. I think you'd have to use the integrated RX on the board, run the signal wire from the board to each servo and the positive and negative from the 2-in-1.
Good luck
Blade 130X, Blade Nano CPX
Edge 540T, Mini Funtana X, UMX Sbach 342 3D
Lunchbox is offline        Reply With Quote Quick reply to this message
Old 10-09-2011, 07:10 PM   #70 (permalink)
I am short one of "the steve" converter, forgot the one for the main motor.
Old 10-09-2011, 07:37 PM   #71 (permalink)
Why do you need one for the tail? It is a brushed motor so why would you need a signal converter?
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
Old 10-12-2011, 12:17 AM   #72 (permalink)
I have hard time to solder the servo wires in the pc board, I don't want to ruin a good 3in1 board, need to order the micro servo connectors.
I mount the 3in1 board at the back of the frame.
Old 10-15-2011, 12:26 AM   #73 (permalink)
Slow progress, got the servo connection done now, next is to test servo direction.
Name:	servo connection.jpg
Old 10-15-2011, 09:31 AM   #74 (permalink)
OK, looks like power for the mcpx board from the SR esc, and the bottom wires get the micro servo connector?
7hvu, 6hv,,Prôtos,450Pro, DT520E
some planks
Jumna is offline        Reply With Quote Quick reply to this message
Old 10-15-2011, 12:41 PM   #75 (permalink)
Ahh, hit a bump in the project, the E-flite digital servo does not work in the 3in1 board!
Old 10-15-2011, 04:23 PM   #76 (permalink)
Maybe it is picky about voltage?
some planks
Old 10-15-2011, 04:33 PM   #77 (permalink)
The Corona digital servos work with the mcpx 3in1, need to get the CCPM direction right.
Old 10-24-2011, 04:45 PM   #78 (permalink)
The mcpx 3in1 board works good in the DIY FBL Blade SR, hovering test video:
[ame]http://www.youtube.com/watch?v=KN3wENBsJ5s[/ame]
Old 10-29-2011, 08:28 PM   #79 (permalink)
amazing work!!
Old 11-06-2011, 09:13 PM   #80 (permalink)
Anyone has used the AOE convertor in mcpx 3in1? Looks like this convertor can drive both the main and tail esc from the 3in1.
