Old 01-28-2013, 08:24 PM   #1 (permalink)
Default Night flying for mCPX
As most of us I have more time at night. Is there a way to use these mods on a mCPX ?
Mcx2, 2 nCPX 2 mCPX v2 2 130x trex 250 plus DFC 3gx mrs TREX 450L Dominator AR7200bx. Twin Goblins 380 Spirit flybarless DX8.
I've purchase all my helis in pairs.
Delfin is offline        Reply With Quote Quick reply to this message
Old 01-29-2013, 10:28 PM   #2 (permalink)
This is what I found
http://helircstore.com/shop/mcpx-gen...atterblades-v2
LayzTexan is offline        Reply With Quote Quick reply to this message
Old 01-30-2013, 12:04 PM   #3 (permalink)
Thanks man
Old 01-30-2013, 02:53 PM   #4 (permalink)
Your welcome, Let me know how they work
Old 02-03-2013, 11:41 AM   #5 (permalink)
He has a new set out that has light tubes too. It looks really nice and I'm contemplating it for my new MCPX BL. But it's a little pricey...
lovespicyfood is offline        Reply With Quote Quick reply to this message
Old 02-04-2013, 03:49 PM   #6 (permalink)
Originally Posted by LayzTexan View Post
Thanks for the support, some Vendors are out.
My email: ifly65@att.net
DarkMatterBlades.com
James
Blade 360 BL 2 Devil 380 Outrage Fusion 50 Gaui X5,NX4,X2 NX4: Savox sh1250, sh 1257, Ikon, Hatori pipe, OS 37 X5: RJX 0521HV X2:MKS DS 95l Spektrum H3020 7200bx Scorpion HSC MCP X BL NCcraig Flashed TA 915 9t.
ifly_65 is offline        Reply With Quote Quick reply to this message
Old 02-06-2013, 08:42 AM   #7 (permalink)
i dont mean to high jack this thread, but i saw a mod i would like to share for the mcpx.
the blades had contact wires going down inside the main shaft on both blades, and they came out under the main shaft. they were c-ad to the mIn gear and contacted a + and - brass contact. it all ran off the main pack.
i did not get a pic , but i could make a diagram.
fusionsx00 is offline        Reply With Quote Quick reply to this message
Old 02-06-2013, 04:35 PM   #8 (permalink)
Fusion. Please do so. Actually that's what this thread is all about.
Thanks man.
Old 02-07-2013, 10:34 PM   #9 (permalink)
Here you go.....
https://www.helifreak.com/showthread...ight=dre414%5C
HankAz is offline        Reply With Quote Quick reply to this message
Old 02-07-2013, 10:43 PM   #10 (permalink)
yup thats like the one i saw,
wow man awesome work
Old 02-08-2013, 07:50 PM   #11 (permalink)
Thanks guys
Old 02-27-2013, 12:57 AM   #12 (permalink)
the night helicopter looks great, just want to how it work at night.
Chrislee is offline        Reply With Quote Quick reply to this message
Old 02-27-2013, 05:57 PM   #13 (permalink)
Slightly off topic, but have you guys seen the new Heli Max SS 100 LED that is coming out? It has leds in the main and tail blades and the entire setup runs off the main battery. I'm wondering how they do it and looking forward to seeing this! The micros are the perfect setup imo for night flying.
http://hobbyproinc.com/store/product...-With-LED-RTF/
Pete
Old 03-28-2013, 01:01 PM   #14 (permalink)
Just thought I would show off my little MCPX I modded this morning. Using two Parkzone Vapor batteries to power two 3 LED segment Nav Lights. Can't wait to test her out this evening and see how she does with the extra addition. 7.4v doesn't quite push these lights as hard as they desire, but they are plenty bright and the weight sacrifice doesnt seem to be to bad.
NF1T is offline        Reply With Quote Quick reply to this message
Old 03-28-2013, 03:53 PM   #15 (permalink)
COOL! Let us know how it goes. Seems like you might need more lights for orientation but who knows... I'm interested in that new Heli Max heli that is coming w/ lights stock, but I'm unsure if it's out yet...
Old 03-31-2013, 08:43 PM   #16 (permalink)
it has a main gear with a contact plate , wires go thru the boom and connect to the blades.
the parts from this heli may be good to use , like the blades, contacts , the tail is kinda of risky
it has the led inline on the tail motor, and the blade reacts to the led.
im still working on mine, i made my blades and i am working on a contact plate.
i plan on running all off the main pack.
Old 04-01-2013, 08:45 AM   #17 (permalink)
Tried to fly with just the navlights on the base of the canopy, this was not a good setup at all. It did not help that I had black blades which negated seeing the disc spinning as it was inflight. Rethinking where this is going and trying to come up with another setup. I think a set of yellow or light color blades illuminated by a set of top facing LEDs would help, a set on the tail of the airframe and a light color tail rotor would also be beneficial.
Pics once I get it reworked.
Old 04-01-2013, 11:14 PM   #18 (permalink)
i finally got my bl mcpx night setup. well the blades portion. i still need to run a tail light.
i made my setup like the one linked above. made a rotating contact ring and ran my wires
thru a hollow main shaft. im using the mainshaft at a ground , and one wire thru to the
bottom to my contact ring. it was a pain , serious pain. if i can find a really thin brass or
copper washer then i can make the setup 1000x easier. when im done i will write up a
complete build.
you can see i am having dimming issues with the blades spinning, i think the contact points
are the problem.
here are a few pics.
Old 04-02-2013, 08:58 AM   #19 (permalink)
That rocks, love the setup
Old 04-02-2013, 01:32 PM   #20 (permalink)
Sweet!!
