Old 07-04-2012, 10:54 AM   #1 (permalink)
Default Main blade choices
I don't see much choices for main blades for 300x. Its 245mm or we can use others?
torch8 is offline        Reply With Quote Quick reply to this message
Old 07-04-2012, 11:40 AM   #2 (permalink)
The Honey Bee CP used 246mm blades, quite a few available online - you'd need to check the root thickness and bolt hole size
FWIW these worked with the SR, not sure if SR = 300X in that respect
toys2cars2toys is offline        Reply With Quote Quick reply to this message
Old 07-05-2012, 02:20 AM   #3 (permalink)
Automotive technician - but really a rocket scientist
http://helidirect.com/sab-redwhitebl...ht-p-21188.hdx
those will work. this guy here is using them....
[ame]http://www.youtube.com/watch?v=f5f6r19oEuo[/ame]
meatwad99si is offline        Reply With Quote Quick reply to this message
Old 07-13-2012, 12:49 AM   #4 (permalink)
If the sab 255 blades work then the Gaui blades will be a cheaper alternative...
Only 30 bucks not 40... still pricey but not as bad... If your looking for carbon blades im sure you dont crash often anyways so the 30 bucks wont be bad...
http://www.anythingheli.com/gaui-x2-...arless-212220/
Old 07-13-2012, 09:53 AM   #5 (permalink)
The Gaui X2 blades have a thinner root, so you might have to shim them. In order to use the SAB blades on the X2, they needed to be sanded down.
GravityJunkie is offline        Reply With Quote Quick reply to this message
Old 07-13-2012, 11:01 AM   #6 (permalink)
i've ordered these blades here:
http://www.fast-lad.co.uk/store/micr...8-p-11379.html
a good choice untill now (6 flights)
next simu only...
ducatimoto is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 12:23 PM   #7 (permalink)
this blades looks pretty good
SAB Main Blades 255mm Carbon - Red Devil
Material: Carbon
Recommended for: 3D & Fun Fly
Profile: symm.
Length: 255mm
Chord: 26mm
Grip: 5mm
Section Thickness: 3,5mm
Hole: 2mm
Price: ~35,-EUR
weight: SAB ~11.5g vs Wood Stock ~17.5g sounds promising to me
stolen here, no flight reports yet
affiliated with my wallet.
BLHeli with locator beacon now!
honkytown is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 02:39 PM   #8 (permalink)
Well, canīt fly it without tail servo. But thanks for posting, so I donīt have to.
Hubschrauberpilot is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 11:05 PM   #9 (permalink)
Should see a lot better flight times as well with those light blades.. Along with better (less) disc loading..
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN G380/R420/G500-x2/R580/G650/R700/G770 (and many others)* Swinging Rotortech Blades * OMP M1 & M2 * MSH Brain * * iX12*
akamullen is offline        Reply With Quote Quick reply to this message
Old 07-19-2012, 02:38 AM   #10 (permalink)
sweet got my question answered. BTW do these need to be shimmed? ordering a set on pay day so i can rev this beast up
tacomaster is offline        Reply With Quote Quick reply to this message
Old 07-19-2012, 05:23 AM   #11 (permalink)
yes.
Old 07-19-2012, 06:28 AM   #12 (permalink)
really nice looking choice, looking forward for your opinion. whats wrong with your stock rear servo? how thick are the shims you have to use?
Old 07-19-2012, 01:52 PM   #13 (permalink)
Unsurprisingly, my 300X flys way more stable than with the wooden ones.
Shims are the ones from the original tail-blades; but could be slightly thicker.
Tail servo blew when I slipped off my plastic landing place & hit the edge with the blades,...
Upgraded to the Hitec HSG-5084MG tail stands now rock-solid
Old 07-19-2012, 02:54 PM   #14 (permalink)
boss hog. got those blades on the way now, lol now we just need some kbdd or edge tail blades....
Old 07-19-2012, 10:47 PM   #15 (permalink)
You can see the big difference in weight because the woodies are designed for FBL and are weighted. Wonder when aftermarket FBL blades will become available?
Fairplane is offline        Reply With Quote Quick reply to this message
Old 07-19-2012, 11:05 PM   #16 (permalink)
i highly dont know about that... its a nice theory but its more likely they are just heavier cause they are wood... i dont think your gonna notice a difference in fb vs fbl blades on this size on heli...
Old 07-20-2012, 07:32 AM   #17 (permalink)
Question Very Nice!
Hubschrauberpilot, very nice look on your 300 X and I see you have the option CF tail fins installed too.
Did you have any photo's showing the stock main blades next to the SAB main blades?
ACTIVE FLEET: GAUI X4 II, OXY 2/3/4 >< Align >< BLADE >< Walkera
...living the Hobby 4+ minutes at a time
R3L72 is offline        Reply With Quote Quick reply to this message
Old 07-20-2012, 08:07 AM   #18 (permalink)
Thanks & yes those are the original Blade fins.
Old 07-20-2012, 11:36 AM   #19 (permalink)
These dont look to bad either: http://helidirect.com/miroheli-250mm...ro2-p-6168.hdx
They are 250mm so a lil closer to stock size but I order a set of both to try them out as well.
Dubie is offline        Reply With Quote Quick reply to this message
Old 07-20-2012, 12:32 PM   #20 (permalink)
What about blades for the SR? It came stock with 245mm's like the 300x, but there's some Xtreme 235's that are made for the SR:
Everyone seems to like them on the SR. I think I'll order a pair to try. At $7. why not.
If it can fly, I will fly it
CousinLarry is offline        Reply With Quote Quick reply to this message
