Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum |
10-23-2009, 05:20 PM | #1 (permalink) |
14mz 2.4 gov and gyro function ?
HI I would like to know what the best way is to set up a multigov pro and a solid g gyro on this radio. I want to be able to turn gov off with a switch . normal mode [1700 ] idle 1 [1800] idle 2 [1950 ] do I set the rpm in the radio on the gov channel or in the screen that plugs into the multi gov pro. Same with the gyro settings do set it up on the screen that plugs into the gyro or in the radio on the gyro channel. Thanks ! o yeah Its going on a vibe sg 90
10-30-2009, 02:42 PM | #2 (permalink) |
I got it Working. All you have to do is set the rate in the radio on the gyro channel .while looking at the screen on the gyro.keep moving the rate in the radio until you see about 39 gain in the gyro screen thats plugged into your gyro.Now i can set different rates for each flight condition. For the gov I just null both default channels for the gov and plugged in to any channel above 7 .and set that to my flight conditions [normal] [ idle 1] and[ idle 2] hope this can help someone.
10-30-2009, 08:28 PM | #3 (permalink) | |
with MultiGov Pro, you can't have 3 speed + on/off switch.
So I set speed 1 to 0 , i.e disable GOV and this speed for normal flight mode. Next I set a offset mix to the GOV channel and assign it to a switch, I use this switch to on/off the GOV at any time in flight to check the mixture and Tx's throttle curve setup. You can still use the GOV function in the Tx, just set the value to 0,50,100 for normal,idle 1 and idle 2 TGO Quote:
