Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others |
05-03-2009, 02:47 PM | #1 (permalink) |
Blade CP Pro 2 flight and crash.....battery ran out.
Fried my battery and also the throttle hold didn't seem to work too good. Still, no damage at all other than a fubar'd battery now. I was sure a battery should last longer than 5mins. Got this a week ago and started doing some loops and rolls, still a bit twitchy but I'm still learning.
http://www.youtube.com/watch?v=V92qKI5oA5E Mind you it was windy so I guess it uses more power than when calm? Dan
Trex 500 Pro MCPx v2 130X DX7 |
05-03-2009, 07:22 PM | #2 (permalink) |
looking at the video it looks like u just went inverted and crashed ?? that could easly kill the battery looks goo up until the crash though
05-04-2009, 01:04 AM | #3 (permalink) |
But I was full negative pitch and it just seemed to bog down and go in. I have no trouble admtting when it's due to pilot error (most of my crashes) but why would a light crash kill the battery? Or do you mean because the blades were still trying to turn in the grass and that they were obstructed it overheated the battery?
05-04-2009, 08:41 AM | #4 (permalink) |
what happened to the battery is it puffed,low voltage ? I know with mine i get about 8 minutes of flight time but thats with throttle hold off and just mild flying so 5 minutes could seem about right i guess
05-04-2009, 11:30 AM | #5 (permalink) |
Thanks man. Yeah it ballooned up and was really hot. Now it doesn't give enough power to even lift the Blade even after a full charge so maybe one of the cells is dead. For now I'm using it to fly the CP2 which works fine with it. Weird.
05-04-2009, 11:42 AM | #6 (permalink) |
Lynx.1677.....Nice flying and sorry to hear about the mishap. I was watching the video and noticed the skids. What type of struts and skids do you have on your blade? Thanks!
05-04-2009, 06:12 PM | #7 (permalink) | |
Pics:
05-05-2009, 07:07 AM | #8 (permalink) |
Thanks!
Lynx.1677.....Thanks for the info on the skid set-up. Does it make the Blade more stable?
05-05-2009, 09:24 AM | #9 (permalink) |
Yeah much easier to fly in any sort of wind. It was a bit unstable before that.
05-05-2009, 09:27 PM | #10 (permalink) |
Need some part numbers
Lynx.1677 ....Do you have some part numbers for the parts you used? I can't seem to find them on-line in the states. If I had the part numbers it would make things a lot easier. Thanks!
05-06-2009, 03:44 AM | #11 (permalink) | |
Honeybee frame: EK1 0248 King2 battery hanger: EK1 0559 King2 skids: EK1 0560 You will need to trim a little bit of plastic off the rear part of the battery hanger just below the screw so that it doesn't get in the way of the main gear. I did this with a pair of cutters but you can do it with a dremel drill or even file it down.
