mCP X Blade Micro CPx Helicopters Information and Help |
12-06-2011, 04:31 AM | #1 (permalink) |
Can't do a pirouette, drifts away, help!
Hi,
My new mCP X v2 feels stable but when I try to do a pirouette it drifts away quick, how can I solve this? Should it not be possible to do stationary pirouettes indoor?
Lynx Heli Innovations | HD Helicopters |
12-06-2011, 05:02 AM | #2 (permalink) | |
Other is... practise, practise, practise and learn how to fix heli position it as it goes around. It is a skill to pirouette mCP-X on the spot. And many other helicopters, too. It took me around a year to learn how to do it with more or less success - and I started with flybarred Mini Titan (450 class) and then continued learning it on FB version of same heli and then bigger (Protos) before I learned how to do fine corrections all along the pirouette - no matter which helicopter it is. So - practise it... |
12-06-2011, 05:55 AM | #3 (permalink) |
Damn it, I was hoping on a simple fix
12-06-2011, 07:42 AM | #4 (permalink) |
As mentioned above, the cog is very important. Making sure it is spot on will help a lot.
12-06-2011, 07:53 AM | #5 (permalink) |
Hey
It can be done with practice. Try slowing down a little because you will have to correct at least once per 360. I find to get it nice a smooth I have to correct 2 or 3 times per 360.
A lot of us skip learning pirouettes and move on to flashier moves, I did. Now I find myself going back to learn pirouettes both inverted and normal so I can learn piro flips. I usually finish every flight with a few pirouettes. Good luck
Team Scorpion Team Boca Bearing Team Revolectrix Check out my Heli Pilot Shirts https://teespring.com/stores/rc-heli-pilot-shirtsMy Youtube channel http://www.youtube.com/user/JJInvert...n?feature=mhee |
12-06-2011, 12:49 PM | #6 (permalink) |
How do you check the CG on the Mcpx? There is no flybar to put your fingers under?
12-06-2011, 12:52 PM | #7 (permalink) |
Rotate the head so the blades are 90 degrees to the tail boom, pop one of the dogbone links off a blade grip and hang it from that blade.
12-06-2011, 01:08 PM | #8 (permalink) |
I check cog with some sort of string wire etc fed through the rotorhub above the featherng shaft and try to eyeball center on the hub.... (rkh hub).
Sent from my thumbz |
12-06-2011, 02:56 PM | #9 (permalink) |
had my mcpx for a 3 days now and find it pretty tricky to piro it too...but only to the left. i find if i try to piro it to the left,it wants to come backwards,quickly....caught me out yesterday and crashed it into my thumb,took a nice chunk out of it where the nail meets the skin,lots of blood too! lol
but a piro to the right i find it will stay pretty much in one spot...its a weird one and i dont know why one way is easy and the other not... slighty off topic,but just wanted to praise the boom and grommit mods...made my heli fly so much better. kudos to whoever figured out those mods! loving the mcpx so far |
12-06-2011, 05:11 PM | #10 (permalink) |
It took me a while to learn piros. You just half to star off slow then gain speed as you get better.
MCPX V2 |
12-12-2011, 10:12 PM | #11 (permalink) | |
drifting pirouettes
If the boom slightly turns in the frame or the tail motor mount turns on the boom, you get an unwanted out-of-plane component of the force from the tail rotor that will push the tail upward or downward thus take the heli out of perfect horizontal plane.
MSH PRÔTOS CF FBL: YGE, Scorpion, JR3717HV, SK-720 w/ HBL980 JR X9503, 3DHSExtra300SHP, Precision Aerobatics Extra MX iPAs Last edited by asasan; 12-13-2011 at 04:23 AM.. |
12-13-2011, 02:26 AM | #12 (permalink) | |
12-13-2011, 08:37 AM | #13 (permalink) |
I just went out and flew a battery And realized I was putting in some AEL whenever I did piro's. Left or right depending on piro direction. I then did some without AEL and it drifted a little not really to bad. The biggest problem I face is that a lot of times due to variables I guess the heli does not always fly the same. I am just a sport flyer, all orientations, circuits forward and backward ETC. Loop and flip, no inverted so take it for what it's worth. I did notice the drift was alot more noticeable on fresh pack, I fly Spyders.
