Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters > E5
Old 09-03-2012, 10:47 AM   #61 (permalink)
Default Motor shaft size?
Does anybody know which size motor shaft the pinion is fit for; 5mm or 6mm shaft?
Futaba 14SG, Synergy E5, Furion 6, Beam E4(v1) FBL, CGY750, Skookum
dpelletier is offline        Reply With Quote Quick reply to this message
Old 09-03-2012, 10:53 AM   #62 (permalink)
6mm
beeflyer2 is offline        Reply With Quote Quick reply to this message
Old 09-10-2012, 11:20 AM   #63 (permalink)
Originally Posted by BennyTRD View Post
What's your AUW at the moment Matt with 6S 5000's?
Do we have an answer to this question yet?
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 09-19-2012, 04:23 PM   #64 (permalink)
Nope.
Stuff
Rob Cherry is offline        Reply With Quote Quick reply to this message
Old 09-19-2012, 04:33 PM   #65 (permalink)
Originally Posted by NovaCX12 View Post
Couple questions as I start buying stuff for this upcoming project.
Motor KV on 10S/12S? Pinion? I plan to stretch it to 600 size. Max blade size if stretched to 600 size? Can I run 105 Tail blades? Is the main gear the same teeth count as e6/e7? Target headspeed?
Thanks!
Matt recently announced the 4.5 tail ratio option for those who want to slow the head down for 606mm yet keep the tail speed up where it belongs, the 96's should be OK. No word yet whether 105's will work on the E5S.
With a 7.93:1 – 9.91:1 main ratio, you could run the 560kv motor on either 10 or 12S simply by switching pinions.
Headspeed with a 560Kv motor:
10S: 1800-2350
12S: 2150+
Stuff
Old 10-05-2012, 07:25 AM   #66 (permalink)
I want to do a 12s stretched E5 since I have a few extra parts laying around from my compass 6hv build.
Compass 540kv motor, HW, HW Platinum 70A HV, and 2500mah-3300mah 6s lipos.
Will the E6 belted tail work or is the TT the only option? How many teeth on the main gear?
William
Synergy N5C, 130x, Mini Protos 6s
wbefield is offline        Reply With Quote Quick reply to this message
Old 10-11-2012, 11:01 PM   #67 (permalink)
Default Motor Shaft Length?
Wanting to use my Pyro 600-11 but not sure the shaft will reach counter bearing.
As is shaft length is 23mm, is this going to reach?
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 10-23-2012, 09:12 AM   #68 (permalink)
I'm in the same boat wbe, the stretched E5 looks like a good match for my 6HV, geared to run on 12cell 3300 it should be a rocket like the 6HV
Models:Compass 6HV Synergy E7 Warp 360
Radio: Futaba 8FG
Lojik is offline        Reply With Quote Quick reply to this message
Old 10-23-2012, 11:26 AM   #69 (permalink)
Running belt drive on the E5 would require a new front idler pulley bracket because the frames are narrower than the E6/7. Not sure if this is going to happen. Main gear is 119T.
Old 11-03-2012, 05:46 AM   #70 (permalink)
What is or will be the max sized 10S set up in MAH?
I can see you........
Sigma Golem is offline        Reply With Quote Quick reply to this message
Old 11-14-2012, 11:46 AM   #71 (permalink)
Planning to run mine with a 1300kV Viper motor I have in my 550e. Will be using vBar gov as well, or I may stick an iKon on this one.
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 11-30-2012, 03:11 PM   #72 (permalink)
Default E5 Release Date!
We have an official release date!
The first batch of E5 Kits will start shipping from dealers on Friday the 7th of December.
Thanks for your patience!
Matt
00boto is offline        Reply With Quote Quick reply to this message
Old 12-02-2012, 10:34 PM   #73 (permalink)
Ill be placing my order this week. Been waiting for this heli to come out
Sent from my DROID RAZR using Tapatalk 2
AZHELIMEDIC is offline        Reply With Quote Quick reply to this message
Old 12-04-2012, 04:02 PM   #74 (permalink)
Hmm I have been recently thinking about that one, because I need a travel heli2go.. something smaller than 600size heli and with 6S.. I think the E5 will be it.. My first Synergy I find it very sweet! Can't wait!
Yea I am a girl 2 Raptor G4 FBL, SAB Goblin 630, Synergy E5, Vibe 90SG FBL, Fusion 50 FBL, Velocity 50, Titan X50, Raptor 50 (30 size now), T-Rex 250SE
DX8
Airkid is offline        Reply With Quote Quick reply to this message
Old 12-11-2012, 11:11 AM   #75 (permalink)
Can I run a 600mx 1220 kv in this little beauty?
crustysphinkter is offline        Reply With Quote Quick reply to this message
Old 12-11-2012, 12:11 PM   #76 (permalink)
It will work just fine. Will need the 12t pinion which I believe is now available.
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 12-11-2012, 12:14 PM   #77 (permalink)
12T actually comes in the kit.
Old 12-11-2012, 12:33 PM   #78 (permalink)
That's what I'm running in mine. I've been running with the 12T pinion at 2200-2500 rpm and I ran it with the 14T last weekend at 2775 rpm.
Team Synergy Field Rep, Rail Blades
Rodney Kirstine is offline        Reply With Quote Quick reply to this message
Old 12-11-2012, 03:25 PM   #79 (permalink)
Thanks! I was thinking 13/14 in the kit for some reason.
Old 12-18-2012, 09:09 AM   #80 (permalink)
HI, does anyone know the distance between the main grip bolts center to center? Also if anyone has a logo 600, i'd like to get the same measurements if possible. What i'm trying to determine is if the head is larger or similar to the Logo 600 head bolt center to bolt center. Thanks!
mCPX BL
NovaCX12 is offline        Reply With Quote Quick reply to this message
