700 Class Electric Helicopters 700 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
04-21-2011, 11:19 PM | #1 (permalink) |
700e Canopy Mount Options??
So i'd like to upgrade the stock canopy mounts to something "better".....it appears there are a couple popular options. The RC Booya rear mounts or the Quick UK magnetic mounts. From trying to do some research it seems like these 2 are for the nitro version only? Something about the version 2 electric canopy being too rounded at the front?? What are guys using these days? I have the blue and white 700e canopy.
Thanks in advance Spence
Trex 470LP / Beastx / Align BL50X / Align 470MX Trex 500X / Beastx / Align RCE-BL80X / Align 520MX |
04-22-2011, 02:51 AM | #2 (permalink) |
I had a spare couple of Booya mounts for my 600 and used them on the back
of my 700. I didn't like the lower mounts, so tossed them and fitted the same clamp on the front also used on the 600. Now the canopy is off and on in seconds and sits just as good |
04-22-2011, 04:02 AM | #3 (permalink) | |
Sirolf, do you have a part number for that clamp? Thanks |
04-22-2011, 06:30 AM | #4 (permalink) |
I certainly do..it's HN6088 http://www.readyheli.com/HN6088-Cano...o_p_33624.html
Just slide on the canopy till it's pretty much center, drill holes an fasten! |
04-22-2011, 06:43 AM | #5 (permalink) |
Quick UK magnetic on rear
Stock on front For front load battery setup very fast to remove canopy. No drilling of canopy.
"If you think you can or you can not you are right" Goblin Xera 4530, YGE 160,VBar Diablo, HJive, 4525 Ultimate,VBar Synergy N5C sitting in Box... |
04-22-2011, 07:05 AM | #6 (permalink) |
Quick UK magnetic front and back = Perfect for me.
04-22-2011, 07:10 AM | #7 (permalink) |
I tried them all. Q UK magnetic are the best.
Minicopter Diabolo 800+ - Minicopter Triabolo - Srimok FAIFA Jeti DS-16 |
04-22-2011, 07:15 AM | #8 (permalink) |
I went with the keychain option..simple, inexpensive and works like a charm...
MSR x1 / mCPX x2 / 450 x4 / Chaos600 test bed / Chaos600 Air-Wolf / American WereWolf 800 / KFrame800/900/1000 / Assorted Fixed Wing JR9303 / JR9503 / Futaba10CHP |
04-22-2011, 09:05 AM | #9 (permalink) | |
link on how that was made?
TRex-800E /Scorp 5035-478 5+5YY 1.8mm/VBar Blue Full 5.2Pro /CC Hv160/WR-Herc Super BEC/RJX 810mm 3D /RotoTech 115 + QuickUk Tail/ Hitec 7940th HV/TP 5000 65c |
04-22-2011, 09:40 AM | #10 (permalink) |
This was originally posted a long time ago..
The keychain has a hole already in the receiver half so all you need do is screw it on a proper length spacer and mount on the frames
04-22-2011, 10:46 AM | #11 (permalink) |
Quick UK Magnetics ! Once you've tried them, there's no going back !
Goblin 770 4540 395 Sig 16S YGE 160UHV VBar (gov) Goblin 700 4530 540 LE 12S Ice 2 160HV VBar (gov) Brushless MCPX |
04-22-2011, 11:08 AM | #12 (permalink) |
Thanks fellas!!
S
04-22-2011, 12:30 PM | #13 (permalink) |
Are these the ones your using, http://grandrc.chainreactionweb.com/...ducts_id=50201 and if so they fit the original 700e 3G canopy? Everything I read on them say for nitro. Any other parts needed to install?
Tom |
04-22-2011, 12:45 PM | #14 (permalink) |
yes
04-22-2011, 12:48 PM | #15 (permalink) | |
S
04-22-2011, 12:50 PM | #16 (permalink) |
I ain't tight with a dollar .....BUT $39.50??????
Do I get kissed with that *%%&
04-22-2011, 01:10 PM | #17 (permalink) |
That is correct, the nitro ones are good for the 700E.
04-22-2011, 03:26 PM | #18 (permalink) | |
In progress photo..I use them with the plastic and rubber gromments for a little flex. |
04-22-2011, 03:57 PM | #19 (permalink) |
Am I the only one feeling that the companies which manufacture the upgrades are using our addiction to make a bigger profit on our expense with no proportion to the products they sell?
Come on - 40$ for canopy holders?? I can purchase 10 rounded strong magnets the same size needed for only 1$...maybe I should try and make them myself and then sell them to you guys for 1/2 the price..
Henseleit TDR! Trex 800E F3C; Trex 550FB ------------------- I have no life anymore - only heli's in my head.. |
04-22-2011, 04:08 PM | #20 (permalink) |
Agreed, seemingly overpriced but the magnets are cuped and act as a guide, nice thumbscrew type bits, it all just works together very, very nicely...I felt better about the $$$ spent once I had them in hand and even better once installed and tested.
