Outrage G5 Outrage G5 Helicopter Factory Support Forum |
12-22-2008, 11:47 AM | #21 (permalink) |
The tail bearings sometimes get squished when you tighten the end screws on the outer frame.
Stick a washer inbetween the frame and a bearing and you are good to go!
Team Fun / Heli Canada **When you start to be in complete control reflexes are not a requirement.** |
12-22-2008, 11:54 AM | #22 (permalink) |
The Capi
Do you have a photo Solaris ?
Spreading capibara awareness since 2006 |
12-27-2008, 02:12 PM | #23 (permalink) |
My G5 is packed up for the winter.. I will get a photo when its back out again
01-06-2009, 06:12 AM | #24 (permalink) |
Hi,
G5 build on-going, I plan to put a BEAM carbon tail push rod... How do you have dealt with the G5 push rod guides (the holes are too small for the beam tail push rod) thanks, cédric
Never Underestimate The Power Of Stupid People In Large Groups |
01-06-2009, 06:41 AM | #25 (permalink) |
To be honest, I've run an 1/8" carbon push rod on my T-Rex 450 and Rototworkz G4 unsupported for years with no problems, Central Hobbies makes a very nice kit with 2 rods and 4 titanium barbed ends, then you can purchase extra ends and make up a few more push rods, they hold up very well.
Clyde Fox Port Charlotte, FL. Team Rotorworkz/Outrage |
01-06-2009, 07:24 AM | #26 (permalink) |
Hi,
I re-edited this post in order to avoid asking questions everywhere. I also added photos for understanding. Questions 1/ Does it matter if I run a beam carbon push rod with no guides on the boom? 2/ What are everyone's DX7 swash values? Mine: AILE +40 % ELEV -50% PITCH +50% I had to reduce AILE cause when I put the sticks on the corners the right servo arm was touching the frame. I may also have to dremel a bit the screw...? High resolution picture : http://www.gamani.org/g5/DSC_8933.JPG 3/ I went to setting up the head, followed the linkage measures ... and also leveled with a swash leveler the swashplate. I mesured my pitch with a idleup curve : High : 13 Mid : 5 Low : -5 It seems that my swashplate is too high, I may have to shorten the linkage that goes from the servos to the swashplate right? I also think that the leveler balls has to be both aligned High resolution picture 1 : http://www.gamani.org/g5/DSC_8930.JPG High resolution picture 2 : http://www.gamani.org/g5/DSC_8931.JPG 3/ I used a cutter to clear the little piece of plastic that was toucing the main gear. Clearance is now ok. High resolution picture : http://www.gamani.org/g5/DSC_8935.JPG Cédric
Never Underestimate The Power Of Stupid People In Large Groups Last edited by jurassic5; 01-06-2009 at 08:25 AM.. |
01-06-2009, 08:22 AM | #27 (permalink) |
1. The Beam push rod will be fine with no guide, yes.
2. The swash values will depend on how much cyclic response/pitch you want. 3. Yes, try lower your swash to get the lower mixer arms 90 degrees. Pictures won't show.
Mathias Lynx Oxy 3 | JR XG14 |
01-06-2009, 08:26 AM | #28 (permalink) | |
Thanks for the support, I updated my post and also added corrected pictures in low/high res. don't hesitate to make comments cédric
01-06-2009, 08:33 AM | #29 (permalink) |
Yep, you gotta lower your swash.
As for the screw, just take a dremel and cut it till it's clearing the frame.
01-06-2009, 08:41 AM | #30 (permalink) | |
High : 10,1 Mid : 0,8 Low : 9.9 I don't think lowering it more will solve anything; I may have to use the long linkage that goes from the swash to the top arms Cédric
01-06-2009, 08:55 AM | #31 (permalink) |
Adjust your swash links until the ball on the lower mixer arm is on pair with the radius arms. Then follow Capi's G5 Head Setup 101. You can't adjust your pitch by only adjusting the swash links.
01-06-2009, 09:41 AM | #32 (permalink) |
The Capi
I would be careful that servo wire doesn't make contact with the main gear. Did you try the fix in post #8 ?
01-06-2009, 09:51 AM | #33 (permalink) |
Capi, maybe you can move all the non hint messages to its own thread leaving this one with just the tips ?
01-06-2009, 09:53 AM | #34 (permalink) |
The Capi
I kinda like this format, it takes longer to read but it keeps the thread up to date.
01-06-2009, 10:57 AM | #35 (permalink) |
Hi Capi,
for post #8, I'm really too lazy to unmount and try to reverse the pieces to clear the gap To have clearance, I just use a cutter to cut the pick off on the tail gear I may be dumb... but how does the G5 straps work? I cannot strap the lipo ! Cédric
01-06-2009, 11:23 AM | #36 (permalink) |
The Capi
01-11-2009, 01:47 PM | #37 (permalink) |
Thanks you for your help on this G5 build
I'm running 29% gain on the DX7 gear channel, perfect tracking. Just went for a quick hover to try out... too cold ! but MAN what a BIG difference of power comparing to my T450 ! G5 ROX. Here're some photos High Res : http://picasaweb.google.fr/okayplayer31/OutrageG5 Cédric
01-11-2009, 02:24 PM | #38 (permalink) |
The Capi
Glad we could be of help, that's what we are here for.
01-13-2009, 05:21 PM | #39 (permalink) |
Capi, What's the trick to installing the CF tail blades? The root is to wide. Should I spread the tail blade grips a tad?
Just a guy and his heli.... |
01-13-2009, 05:27 PM | #40 (permalink) |
The Capi
I didnt have that issue with mine.
P.S. Jurassic Park 5 twist that tail servo on your boom so it completely hides behind the boom, this will prevent it being damaged by a paddle strike.
