300X Blade 300X Helicopters Information and Help |
08-10-2012, 11:42 AM | #141 (permalink) | |
Happy flying ....Brad Trex 550e v2,BLADE 450X ,130X NEVER! McPX BRL, 120DO2s, McPX, Stryker , Edge 540qq,UMX BEASt, Crak Yakx2, YAK 55M 35CC,A.W. yak 54 20CC,3dhs 330sc 57inch, ALL ON MY JR9503
08-10-2012, 04:56 PM | #142 (permalink) |
Wow
Finally got the Gaui blades on after ~10 decent flights with the Xtreme blades. WOW what a difference. Pitch pumps are great now....almost Trex250ish....Also gonna try the red dampers.
Gonna make another comment in the other thread, but this was ONLY possible after shimming the rear servos and hot gluing the crap out of the entire area!! Without the hot glue the little bird was vibrating itself to death with all the blades @100%. And yes I balanced them all (and the weeee tail blades....) This heli has a design flaw with the 'main shaft tower' But, when it is flying right, it is one sweet heli !! Cheers...Keith
300X,B450,T250se,T2503gx,T450AR7200bx,T4503gx,T500 3gx,T500pro3gx,T5503gx,T700HV3gx,Goblin500 |
08-14-2012, 12:53 AM | #143 (permalink) |
Got my hdx 255mm CF blades today from HeliDirect. They look ok for the price (~$18, plus shipping). My main concern is that they do not have a brass eyelet/sleeve in the blade root holes, just a bare CF hole. I'm not sure if this is an issue or not? Any ideas, like wicking a little thin CA in these holes? Thanks.
BTW, they are a lot more flexible than the Clubheli 255mm CF blades I'm currently using, which are very nice (and have brass eyelets/sleeves). Cheers, TomC
Blade nQX,mCPX-BL,450x,500x Bell 222(bd3sx),550x(bd3sx) TT X50E, 10s, bd3sx Ion-x, Actro 32-3, SS, 10:1, PJazz esc, 10s Now also a FPV addict; Quads and Planes (soon to try heli's!) |
08-14-2012, 08:41 AM | #144 (permalink) |
I wouldn't do that. Most blades have a polystyrene foam core, and if that thin CA wicked into an area of foam it will dissolve it.
Chris Boultinghouse |
08-14-2012, 11:45 AM | #145 (permalink) |
Anyone know if I will need to shim these and if so were I can find some shims?
http://www.experiencerc.com/store/21...)-p-11774.html Sent from my iPad using Tapatalk HD |
08-14-2012, 12:31 PM | #146 (permalink) |
You will, and shims can be just about anything the right thickness. Washers, plastic you have laying around. If they are the same root thickness as the club heli blades (and I think they are) you need about .065" shim on each side. I had some thin shims that came with a Radix blade set that I stacked up (two .025 and a .015 on each side).
In the past, I made shims to run Align blades in a B400 from those thin roll-up cutting boards you can get at the dollar store. They are just about the right thickness.
