05-12-2010, 07:56 PM
#22 (permalink)
Originally Posted by js349
I'm tired of replacing the tail gear that meshes with the main gear. OK, I've only replaced 2 of them but I've not even had this thing a month . So, does anyone know how we can harden these things so they don't chew up so easily? I've also had to replace my tail driver shaft once and I'm going to have to replace the current one when my last parts order arrives and I'm going to have to make another parts order for more gears.
My first post and the Ufly is my first Heli. I've done my share of hitting the tail rotors but a few of those times was because I was getting no response from the tail rotor. Same issue, easily worn mesh gears. After taking the tail boom apart I found out the tail shaft bearings crept up into the tail boom so there wasn't a bearing by the tail rotor mesh gear that contacts the main gear. So the bearing was about 2 inches into the boom and that didnt keep firm pressure on mesh gear. You might want to check your out.
