Old 03-26-2013, 08:41 PM   #61 (permalink)
Had the Nano for 4 days and less than 25 flights now and it's already got this problem (granted, it was 25 flights worth of bumps, crashes, and hard landings). Called up HH and told them the situation and got a nice lecture on spending more time in the simulator, after which they said they would send me one free. Props to Horizon for great service in spite of my honesty ;-)
Unfortunately they require a picture of the old one snapped in half, so there goes any chance of reflowing and having a spare board. The furniture pad fix is great, but also check out the thread about lining the bottom of the board with fuel tubing, as this protects both the sides AND the bottom.
How to avoid the dreaded "won't bind" issue
I love the Nano, and I'm impressed that it flies with the stability of a bigger bird, but this solder problem is absolutely debilitating.
V1rous is offline        Reply With Quote Quick reply to this message
Old 03-26-2013, 10:44 PM   #62 (permalink)
Looks like his is where I'm headed too. I've got only 10 flights on my nano and I have to remind nearly every time I put a fresh battery in. It will be a sad day when I can't even bind.
So what's the proper bind distance for the Tx?
It's amazing what you can do when you don't know that you can't do it. ~unknown
forjer is offline        Reply With Quote Quick reply to this message
Old 03-27-2013, 01:07 AM   #63 (permalink)
3ft or more
Active: 130X / 300 CFX /KDS 550 V2 / 350QX / lots of foamies / DX8 / DX6i
Retired: mSRX / 120SR / 300X / B-SR / HK450V2 DFC / mCPX (all versions)
Familyman67 is offline        Reply With Quote Quick reply to this message
Old 03-27-2013, 12:14 PM   #64 (permalink)
Thanks. I'm sure I'll be forced to rebind so I'll try that tonight.
One more ques? Before flying, is it necessary to power down the Tx and Rx after a successfull bind?
Old 03-27-2013, 01:00 PM   #65 (permalink)
Nope. Just unplug the battery and plug in a new one. Set it on a level surface before it finishes initializing to make sure the gyros are centered.
- Benton Jackson, Maple Grove MN
Roswell Flyer (retired), Concept EP (retired), Eco 8 (retired), WLToys V929 & V202, Nano CPx, Nano CPx mild BL, Nano QX, mCX2, 130x
GoatRider is offline        Reply With Quote Quick reply to this message
Old 03-27-2013, 01:46 PM   #66 (permalink)
I have found that I need to re bind to the dx6i every time I want to fly the nano. Not sure why this keeps happening but its a bit of a pain.
Blade MSR / Blade Nano CPX X 2/ 130X / DX6i
QAV 210 , inductrix FPV, Bunch of Tiny Whoops
VooDooMafia is offline        Reply With Quote Quick reply to this message
Old 03-27-2013, 02:08 PM   #67 (permalink)
Do you fly to Low-Voltage-Cutoff? That sometimes erases the binding memory of the brick. It's also hard on the batteries. Better to use a timer, set to 1 minute less than it usually takes to get to LVC. For me, that's 4 minutes on stock, 5 minutes on 200mAh cells.
Old 03-27-2013, 02:28 PM   #68 (permalink)
No always set the timer on the transmitter , and I end up crashing and stop flying well before the timer goes off lol.
Its only with the Nano it does this the MSR and MCPX are fine and do not need to rebind
Old 03-27-2013, 02:53 PM   #69 (permalink)
Huh. Another thing you could try is starting over with a clean model memory. That's usually the suggestion for not binding, but it's worth a try for this.
Old 03-27-2013, 03:00 PM   #70 (permalink)
Yea thats what I am going to do and see if that helps
Old 03-27-2013, 07:52 PM   #71 (permalink)
Default need advice: Nano won't bind anymore
I don't know what's up with horizon. I read post like this all over the forum I was very close to purchase 2 mCPX brushless to add to me fleet of only blade helis . I got a new nano hovered 1 battery. The other battery the belly crashed on the side from 3 feet high nothing mayor. I called HH got a hard nosed rep named mike since the beginning of the call was very impatient that said it was the
fault of me crashing a heli and it would cost me a new board and the $30 1/2 an hour repair rate and I would have to pay shipping.
Here they advised me to call again and another rep said it would be free and that I woul have to send the heli in me aping shipping. He was ok but sounded lazy.
Called again. Got a nice rep but I still had to send it in.
5 time I think I got the 1st mike I told him that in the forums they send the boards and motors free even when the heli had been abused. In all my calls I was nice and polite. But this guy got pissed again said that the forums are not official and that they don't do that and ended the call. Thank god that nitro hobbies replaced my nano.
But in 5 calls after I purchased 6 of their helis and a Dx8 and their Phoenix simulator. Never called and that treat me for no reason like that. I'm so disappointed in them. The only reason I spend $$. On their expensive parts and helis it was because I read that their customer service was good. I was in for reality check I will not purchase from them or recommend them. There are better end cheaper alternatives.
There finally wrote it,had to let the steam off.
Mcx2, 2 nCPX 2 mCPX v2 2 130x trex 250 plus DFC 3gx mrs TREX 450L Dominator AR7200bx. Twin Goblins 380 Spirit flybarless DX8.
I've purchase all my helis in pairs.
Delfin is offline        Reply With Quote Quick reply to this message
Old 03-28-2013, 07:18 AM   #72 (permalink)
I have the same issue, I am going to have to try these suggestions. I don't want to have to get a new 3 in 1. Hoping I can just limp this one along for a few months until I can afford a 130x
Never thought I would find a more expensive hobby than my Mustang
BMFmach is offline        Reply With Quote Quick reply to this message
Old 03-28-2013, 08:52 AM   #73 (permalink)
Amain has them for 199 (you have to add it to your cart), with 2 extra batteries, extra blades and a metal beval gear.
John
nCPX , 130x, DJI f450 5.8 GHZ FPV, T-Rex 500ESP DS510, mini VBar, 13T
T-Rex 600ESP 12s, scorpion 4025 630, VBar, DS650, DS610, 14T- T-Rex 700E V2 VBar
jlharv is offline        Reply With Quote Quick reply to this message
Old 01-31-2014, 09:02 AM   #74 (permalink)
Originally Posted by 4712 View Post
Here a Foto, where Your critical section is...
Coating was removed and pins resoldered.
What a brilliant thread! It's helped me to identify what the rx chip is and on squeezing it tight to the board bind issue gone away. So I guess a reflow is almost a definite for the problem to go away for good! Will have to remove the goo on it with a dremel heat torch and then reflow all those tiny legs... May as well do most of the board too some of the capacitors look either smothered or minimal dry solder at best...
Face it the board I got on my nano had the worse soldering I've ever seen! Bits of solder all over the place it's amazing it worked at all and didn't just short out! Well best Shen Zhen can do I guess...
Oxy 2 FE, 180cfx spartan lynx pro tail,130x stock, Goosky S1 x 2 , mcpx stock x2, mcpx bl mod, nano cpx dbl bl, nano cpx wild bl, nano cps, DX8. For fpv Phantom 3 pro.
Bhujang is offline        Reply With Quote Quick reply to this message
Old 08-13-2014, 07:43 AM   #75 (permalink)
Just Joined the club, now I have to tell Dad I screwed up my $200 AUD heli Again. IF HH ADVERTISES THIS AS A CRASH RESISTANT HELI THE BOARD SHOULDN'T BREAK. Gotta call HH support from Aus.
hypnotoad is offline        Reply With Quote Quick reply to this message
Old 08-20-2014, 11:32 PM   #76 (permalink)
Originally Posted by coredump View Post
That is right, coredump is my ID.
Great that 4712 can help you closer.
I was just read this and I have the same problem. Is there anything you can do to fix? I do not mind paying, but I just don't want to buy another board. I already have two that don't work..
heli_shmeli is offline        Reply With Quote Quick reply to this message
Old 01-03-2015, 06:19 PM   #77 (permalink)
Default Thats the MCU chip, Not the bind chip!!
Guys This just happened to my nano, there is a tiny silver chip directly in the middle at the bottom of the board, I set my soldering iron on the tips of this chip to reflow the solder joints, and voila!!! she binds!!!
will post some pics when I get home from the gym!!
HauLo is offline        Reply With Quote Quick reply to this message
Old 05-29-2016, 12:31 PM   #78 (permalink)
Is there any way of ironing a chip that disconnected from the board??
I had some connextion issues but when i pressed the board it was fine.
Today after a major crash it just didnt work, so when i pressed the little chip underneath, it fell of the pcb to my hand..
Any suggestions?
It's a nano cps if it makes any difference
alonglick is offline        Reply With Quote Quick reply to this message
Old 05-29-2016, 02:05 PM   #79 (permalink)
If you know anybody who is in the electronics field, they may be able to repair this for you. The parts are quite small, and are very difficult to repair using normal soldering equipment. I'm not saying impossible to repair, just difficult.
I have to turn the music down while driving so I can see better.
MariaFan is offline        Reply With Quote Quick reply to this message
Old 05-30-2016, 03:26 AM   #80 (permalink)
Actually In my work i can try give it to the soldering guy that might do that, but it's a very tiny chip and with special connections.
I tried calling HH but no answer there yet..
I'm not trying to get any free things, but I honestly think that no matter how hard the crash was (It was hard but not that bad) none of the chips should be disconnected from the board. uffff
