Like Tree7Likes
Old 06-07-2014, 10:01 PM   #301 (permalink)
Thanks Chris that's what I thought.
Sent from S4 using Tapatalk
Protos 380 Vbar NEO, HW 60A V4, XNOVA 890KV
Raptor E700 700MX 510KV, Castle 120HV w/Vbar Neo Gov 1960
Working on getting Protos max
Vcontrol
tshelby73 is offline        Reply With Quote Quick reply to this message
Old 06-09-2014, 01:28 PM   #302 (permalink)
See you made it on the show that shall not be named good job
Vcontrol
Old 06-09-2014, 01:36 PM   #303 (permalink)
Default Re: iKON Setup and Tuning Video Series
sent from my Verizon Samsung Galaxy Note 2
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 06-09-2014, 09:06 PM   #304 (permalink)
So, why is my ikon not keeping my tail servo settings of frequency I put in? All of a sudden I started having horrible tail servo oscillations. Plugged in the ikon and all the tail settings were not what I put in. Reset to factory then reloaded my file and it still wont keep them. Any suggestions?
weav01 is offline        Reply With Quote Quick reply to this message
Old 06-09-2014, 09:49 PM   #305 (permalink)
You'll need to move to next panel before closing software to save settings. If you just set the tail freq and close the software it will not save.
Field rep for Discover Card and team Visa.
MSH Brain super fan and crash test dummy.
kthane is online now        Reply With Quote Quick reply to this message
Old 06-09-2014, 09:56 PM   #306 (permalink)
Thanks man, i will try that tomorrow evening and report back.
Old 06-10-2014, 11:44 AM   #307 (permalink)
In tail software page at the bottom. Is it necessary to set the rotation of the main? And what to the "precomp" setting do. Mine have been uncheck and seems fine.
Old 06-10-2014, 11:55 AM   #308 (permalink)
Those settings are needed to fine tune the tail precomp. If you are happy with your tail performance than they are not needed.
Old 06-11-2014, 11:42 AM   #309 (permalink)
Default iKON Setup and Tuning Video Series
Well for now my tail seems fine. I do very basic fast forward flight. If I punch the cyclic the tail will kick out a bit. I has a little small way to it. But it flys very well. At some point I would love to be able to fine tune the settings vs and make it super smooth. That's why I asked what they could do for me.
Old 06-11-2014, 11:58 AM   #310 (permalink)
You are describing what those settings are designed to fix. By telling the system what direction your head rotates and turning on the precomps, it activates a set of parameters that will feed in tail input to counter torque when you load the disk, IE pump collective or input hard cyclic.
Once you enable these features you can fine tune their performance on the advanced menus.
If you heli is flying well just have a small kick I recommend you try it.
Old 06-11-2014, 04:31 PM   #311 (permalink)
Sounds good Chris. Thanks for the input. I always envy the guys who say "locked in" and "smooth". My hurricane is good but I was always afraid of all those settings not knowing what might happen. This ikon is the first high end FBL I've ever had. I read these forums daily. I probably know more than I give myself credit for. Thanks again
Old 08-10-2014, 06:27 PM   #312 (permalink)
Did you ever upload the Advanced Menu settings/walkthrough?
Jason Asch is offline        Reply With Quote Quick reply to this message
Old 08-22-2014, 03:59 PM   #313 (permalink)
I have a jeti ds-16 and ikon, and i need to do patch system and reciver.. And i dong understand the jeti heli setup! :-( just want to fo out and fly my goblin, does any one have a video off the jeti setting utt an ikon??? Heeelp [emoji106]
Marius løseth
Mcpx-hpo5s 9t wow pnp kit-xtreme alu parts-kbdd blades
t-rex 450 v2 scorpion hk2221-6v2 11t and hk2221-8v2 13t
t-rex 500 cf scorpion 1900kv 12t 6s fp 2500mah 25c
Bade 130 x spin 8000kv 2s 65c
mrloseth is offline        Reply With Quote Quick reply to this message
Old 08-30-2014, 01:32 PM   #314 (permalink)
Chris,
Would you point me to a video or thread that deals with advanced tail settings, please? (already read the one in the sticky section, but I have questions). I would like to see how different values affect tail behavior. I'm still trying to get the right stop and hold gains, but still, my 550's tail is not where I want it to be. I also need to see how tail asymmetry works.
Thanks!
T-Rex 700 HV DFC, Logo 550SX, Logo 480Xx
JR Forza 450, G380, OXY 285
I'm proud of my crashing skills!
Chep is offline        Reply With Quote Quick reply to this message
Old 09-11-2014, 10:21 PM   #315 (permalink)
hey chris thanks for the vid i'm newish to this but one question for you do you need the link programmer or can you just link to computer and use a castle card ?
I'm running the tracx from compass (which is brain,ikon anyway) in a warp360 thought I'd nailed till I saw this vid of yours . Also explains why the setup don't seem right although i'v been able to hover and fly round but tail not strong like it should be thanks
regards mick
wolfie64666 is offline        Reply With Quote Quick reply to this message
Old 09-11-2014, 10:24 PM   #316 (permalink)
regards mick
To properly setup the gov with a castle esc you will need the castle link.
Sent from my SM-N900V using Tapatalk
Old 09-11-2014, 11:16 PM   #317 (permalink)
Thanks Chris I'll have to get one here in Australia then cheers
Old 09-12-2014, 07:09 AM   #318 (permalink)
You should be able to use castle link software by plugging USB cord into program card and computer.
Vcontrol
Old 09-12-2014, 07:20 AM   #319 (permalink)
I totally miss read his post, this is correct. If you have a Field programmer you are good to go.
Old 09-12-2014, 08:05 AM   #320 (permalink)
Ok , oh well ordered a link anyway only $21 aussie dollars complete with cable an all no big deal an will be good to have but thanks guys
Regards mick
Tags
save
