Go Back   HeliFreak > R/C Helicopter Support > 100 Class Electric Helicopters
100 Class Electric Helicopters 100 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 12-13-2013, 05:21 PM   #1 (permalink)
Default Trex 150....The 100 Flight Report.
I now have over 100 flights on 2 Trex 150's. I bought them from my local hobbyshop last week.
I have 3 crashes so far. None were my fault. Mechanical stuff on the little beast. Here is what I know.
1.Aluminum Main Shaft seems to bend easily. Be ready to either straighten it or replace.
2.Landing gear always breaks the rear tab that holds it into the frame...seems fragile. Can be fixed after breaking with a 2 mm carbon rod and superglue and drilling.
3.Blades seem to crack or completely break the ends off easily upon impact.
4.Servo wires are very close to spinning motor. Will cut the servo wires easily. Hard to solder tiny wires but can be done
5.Tail motor housing tends to crack without even crashing. Be ready with to superglue the motor in the housing when it cracks or the tail motor will come OUT WHILE FLYING....Not fun. New housing comes with tail boom crash kit but no way to thread wire through the boom with the connector on the end....
I have had all the above happen to me several times.
Overall to me it is much more fragile than the Blade MCPX BL.
BUT it flys so much better!!!!!!! The tail hold is awesome and the flybarless board makes it fly like a larger heli. The flybarless controler is fantastic.
My only complaint is the flip rate is slower than the MCPX BL. But I can live with that. My BL can be flipped in a 18" Box....
Would I buy this heli again.....Hell Yes!!!
Would I recommend it to you....I don't know. You decide.
All I know is I'm having fun with it regardless of my issues.
Cheers
Trex E's 250/450's/500/600's.
Trex 600N's, Raptor 90SE, Goblins.
Thousands of Flights.
emoe is offline        Reply With Quote Quick reply to this message
Old 12-13-2013, 05:36 PM   #2 (permalink)
Sounds fun...I think we have a great mcpx upgrade.kit..upgrade to 150 board and add bl motors...best of both.
Warning this hobby is very addictive and may damage your wealth.
Pigs dont fly is offline        Reply With Quote Quick reply to this message
Old 12-13-2013, 05:40 PM   #3 (permalink)
Default Re: Trex 150....The 100 Flight Report.
BL flips faster???? Not in my experience AT ALL!
I think you need to turn your cyclic dial and dual rates up on the 150, mine flips 3x faster than any BL I have ever flown.
Dylan ~ www.AstroidDesigns.com
Old 12-13-2013, 05:48 PM   #4 (permalink)
Thanks for the detailed report by the way, it's good info
Old 12-13-2013, 09:02 PM   #5 (permalink)
I agree, once I turned up the cyclic flip rate this thing is insane! It can flip much faster than my BL ever did.
DJG24 is offline        Reply With Quote Quick reply to this message
Old 12-13-2013, 09:23 PM   #6 (permalink)
Dylan, My BL will flip in an 18" Box. Your Trex 150 will flip 3 times faster???
That's a 6 INCH BOX. Wow.
We need to have a flip contest.
Old 12-13-2013, 10:52 PM   #7 (permalink)
Collective management.
Lol just kidding. I'm still working on that as well with my big helis.
/#Team BK Servos//#Team Pulse/#Team AMain Hobbies// /Team Canomod//
Greg Jackson 2017 Team USA F3N https://www.youtube.com/channel/UCci..._R4nja0RYeXykg
GJacksonF3N is offline        Reply With Quote Quick reply to this message
Old 12-13-2013, 10:59 PM   #8 (permalink)
A flip to inverted, or a flip all the way around back upright?
Old 12-14-2013, 12:29 PM   #9 (permalink)
Sounds like we need to have a flip off....
Post up your videos boys, we'll be the judges.
-Shane
ShaneXman is offline        Reply With Quote Quick reply to this message
Old 12-14-2013, 01:06 PM   #10 (permalink)
Continuous flips starting at 25 seconds [ame]http://youtu.be/GUmZ8BSEVTA[/ame] This is with dual rates at 125 and travel adjust at 100, it gets much faster if you increase the travel adjust. Flip rate pot is maxed out, or almost maxed out.
Be kind to me, that was my first flight of the day, still a little groggy
Ill try and get back to back videos today of both helis flipping at their max rates
Old 12-14-2013, 01:10 PM   #11 (permalink)
I don't know if it's just a perception thing on video, but it sure looks and sounds more powerful than my BL. I can't wait to give her a go.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 12-14-2013, 01:12 PM   #12 (permalink)
It is more powerful than a stock BL by a big margin, but also heavier.
Put the same main motor in the BL and you see the power to weight difference [ame]http://youtu.be/jMeaY-PYr6s[/ame]
Old 12-14-2013, 01:52 PM   #13 (permalink)
Default Mcpx vs 150
I've been considering a 150 but if that's what I can do to my Mcpx, I may skip the whole 150 thing. Or maybe I do need another heli
BigRich63 is offline        Reply With Quote Quick reply to this message
Old 12-14-2013, 02:36 PM   #14 (permalink)
I found the roll rate incredible. My BL back flip rate cant touch this heli. Why my back flips are slower on the BL I no not, but ..... just turn the roll rate pot up a bit and add some expo if needed and hang on for the ride
Torquefactor is offline        Reply With Quote Quick reply to this message
Old 12-14-2013, 04:37 PM   #15 (permalink)
I believe the t-rex 150 isn't built to be unbreakable, but built for straight out performance. I'ts like the bigger heli's.. You crash it, you break it. You don't crash it, it keeps going.
I do believe aswell that the 150 has some more power then an mcpx BL. Maybe its that extra amount of power that makes it less crash-proof then an Mcpx-bl.
Both will have it's up and downsides i guess.
Robby_R is offline        Reply With Quote Quick reply to this message
Old 12-14-2013, 10:55 PM   #16 (permalink)
Great comment.
Nice flips Dylan
Old 12-15-2013, 09:27 AM   #17 (permalink)
Yeah. I feel like if it flies like a bigger heli, i wont crash it as much. Most of my mcpx crashes are a result of the heli doing something unexpected, and i either crash wondering what the heck is going on, or i try to save it and bog the motor and blow the tail out, complicating things even more, still resulting in a crash.
I do have the occasional dumb thumb like anyone, but its like a 2/8 ratio. 2 dumb thumb crashes to every 8 "What the frick is this thing doing? Where is it going?" crashes. Its not because I'm taking risks I wouldn't normally take. I'm sick of repairing my mcpx since it breaks on almost every crash anyway, so I fly it more carefully like my big helis, and yet still crash it more. Actually i fly it more carefully because i know its more prone to flying out of control the more i jam the sticks around. My only explanation is because it doesn't fly the same. Its less predictable and needs to be babied.
The reports of the 150 flying more like a real heli is making me very happy. If it really does, I foresee fewer crashes in my future. And if I do crash and break it, it'll still be cheaper to fix than any of my other helis, including my mcpx BL.
Sent from my DROID RAZR HD
corrosionate is offline        Reply With Quote Quick reply to this message
Old 12-15-2013, 09:40 AM   #18 (permalink)
I haven't read of anyone stripping the servos in a crash yet, so that seems promising. That'll keep the repairs simple.
Anyone strip one yet?
Old 12-15-2013, 12:12 PM   #19 (permalink)
good point! swashplates breaking, tailmotormounts but no servo's
DX8 +180 CFX, 200QX
retired Trex 450 pro 3GX, MCPx, 130x
kmkflyer is offline        Reply With Quote Quick reply to this message
Old 12-15-2013, 01:10 PM   #20 (permalink)
Cheers
50 flights in and would agree with everything in the nicely written report. Only addition is the Swash comes apart as well. We need the likes of Lynx & MH & Dylan to crank out replacement real parts fast!...
timdknowlton is offline        Reply With Quote Quick reply to this message
