Old 01-17-2011, 04:01 PM   #1 (permalink)
Default Boca Oneway bearings install questions( UPDATED ?)
i need a new one way bearing for my t-rex 500 after my second crash of loosing power due to the one way failing ..so should i get the align replacement or the boca replacement thats 15 bucks over 4 bucks for a ABEC 3 replacement...do better one ways really make a difference ?
Compass 7HV 9180/9188 Vbar
Compass 6HV 9180/9188 Skookum,4025-630KV
Compass 6HV Savox/ 9188, Vbar,
Fusion 50 9080/9088 Beast X
Velocity 50n 9080/9088 VbarSAB Goblin 9180/9188 Kontronik helijive Coming soon
AnTi Taco is offline        Reply With Quote Quick reply to this message
Old 01-17-2011, 05:24 PM   #2 (permalink)
I had nothing but problems with my one-way bearing on my 600E. I tried every type of lubrication and several new one way bearings and they would always lock up. I eventually purchased the beefy one-way bearing from lukerc but even that one failed after a few flights. It had the opposite problem of the stock bearings and wouldn't hold anymore.
I purchased the Boca one-way last winter and haven't had a single problem since. Very highly recommended and worth every penny.
SAB Goblin 700, 4525-520LE, Kontronik Jive 120HV, VBar Pro
Trex 600E Pro, CC 85HV, Mini VBar Pro
Trex 700N LE, Align 91H, Align pipe, AR7200BX
Brian7982 is offline        Reply With Quote Quick reply to this message
Old 01-17-2011, 05:26 PM   #3 (permalink)
is one better then the other i don't know the difference... other then SS or PLASTIC for the spring plastic is more money
http://www.bocabearings.com/productD...px?ItemID=3299
Old 01-17-2011, 05:56 PM   #4 (permalink)
I would think SS would be better in a heli. The plastic sounds like it is designed for low temp, high corrosion. Unfortunately, I emailed Boca on a one way bearing question a few months ago and they chose to not reply.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 01-17-2011, 06:08 PM   #5 (permalink)
ok i just ordered the one thats SS and its the same one they offer in there complete heli bearing kit so i guess i got the right one
Old 01-24-2011, 04:08 PM   #6 (permalink)
ok i got my Boca Oneway bearing today and i have two questions
1. should i grease up the inside of the bearing?
2. i took the align one out 1 week ago so i forgot how to put it back in i think....so if i hold the bearing in my hand and have the main shaft connected the shaft should spin right...... but if i try turning the shaft CCW it should lock up right?
Old 01-24-2011, 04:12 PM   #7 (permalink)
Team Taco Member
Light oil only in one way bearings. Grease will clog it up
Mark
Morley F1 60 Max (OS 61LX-H), Hirobo SDX (OS 55HZ-H, GY701), Trex 450SE + some planks
MarkD is offline        Reply With Quote Quick reply to this message
Old 01-24-2011, 06:37 PM   #8 (permalink)
If the OWB has a rotation arrow on it, that should face down.
Sounds like you have it right. The main gear will spin cw when installed, so it should grag the main shaft sleeve and turn the main shaft.
Trex 500-3226-1600, 14T, Koby 90LV, HS-5245MG, DS655, AR7200BX, DFC
Trex 450 Sport-2221-8, 15T, CC Edge 50 Lite, HS-5065MG, HSG-5084MG, AR7200BX, DFC
DX8
wanderer56 is offline        Reply With Quote Quick reply to this message
Old 01-25-2011, 03:49 PM   #9 (permalink)
A popular one way bearing lubricant is automatic transmission fluid. Only a few drops are needed.
Old 01-25-2011, 07:05 PM   #10 (permalink)
Where the Hell is Tonawanda?
JR X9503
TREX 500 ESP FBL, Skookum SK720, Scorpion 3026-1600, 14T
CHP TREX 600 ESP FBL, SK720, 8S, Scorpion 4025-740, 12T, WR Bec
TREX 700E FBL, SK720, 12S, Scorpion Comm 130A ESC & 4035-500 , 12T, WR Bec
Tisondm is offline        Reply With Quote Quick reply to this message
Old 01-25-2011, 08:36 PM   #11 (permalink)
Ok I got it in right but decided to use red loctite to hold it.in place dam one-way could be put in by hand so didnt feel comfortable using green or even blue..
Old 01-26-2011, 02:31 PM   #12 (permalink)
Ah a thriving metropolis (or small town) outside Buffalo, NY where it is always warm and sunny
Blue and red loc tite are made for bolts, green is made for retaining bearings.
Old 01-26-2011, 03:38 PM   #13 (permalink)
green is just more removable i just used red cause i don't care if i can't get it out....
Old 01-26-2011, 06:38 PM   #14 (permalink)
I don't know if I would want to rely on loctite to hold that bearing in place. There are some serious forces being placed on that bearing and if the loctite fails you better know how to do an auto.
I wonder if anyone else has had this experiece with the Boca One Way. You might even want to call Boca and enquire about this. I would be very concerned about it.
Let us know how it goes. One of mine needs to be replaced and I just ordered an arbor press.
JR X9503
Old 01-27-2011, 02:34 AM   #15 (permalink)
Team Taco Member
Is this bearing going into plastic or the align metal center hub? If it's plastic Loctite with attack and weaken the plastic
Loctite 641 is the stuff for bearings
Mark
Old 01-27-2011, 06:53 AM   #16 (permalink)
metal on metal t-rex 500 hub and boca OW
Old 01-29-2011, 09:19 AM   #17 (permalink)
Team Taco VP
Anti Taco, please do not double post the same question multiple forums. It makes it hard for people to respond and for searching when someone is searching for the same information.
Your answers are here in the one you posted in the main forum.
https://www.helifreak.com/showthread.php?t=274572
Bob
Old 01-29-2011, 09:22 AM   #18 (permalink)
ok but my OP was about if the BOCA ow was worth getting then ask how to install.....then made a second post about Loctites but i get what u saying
