Eagle Tree Systems Onboard data loggers, telemetry, and OSD support |
07-13-2009, 09:19 PM | #1 (permalink) |
Brushless Motor Calibration
I've got everything hooked up correctly for the brushless sensor (at least I think so). I am getting readings on the rpm, but they are WAY off. It's saying 3000ish when I know it's probably around 2100. When it asks for the poles, I am taking that from the Scorpion 890 data and entering 12. Then on the gear ratio conversion, I am taking the 170 tooth main pinion for a trex 600 and dividing by the 13T pinion I have.
Any suggestions for what I might be doing wrong here?
I've never met a heli I couldn't crash. Last edited by schneids; 07-22-2009 at 11:35 PM.. |
04-18-2010, 11:13 AM | #2 (permalink) |
I'm having the exact problem .....
Trex600 with 12s scorpion 4025-630 (8 poles) Main gear 115T - Pinion 11T - ratio=10.454545 ESC Kontronik Jive 120+ I have swithed the wires between the ESC and Motor a few times...... I even tried it with a different motor (4035-630 with 10 poles) but the same problem. when my friend download the data on his laptop he gets the same readings.... So i think there is nothing wrong with the software or laptop. With a Skytach gauge I get ; 2130 rpm.... BUT THE EAGETREE says 3400 rpm.... i'm sure the Eagletree is wrong. But WATs the PROBLEM ??????? Please help me..... Marco
Jeti DS-16 TX Gaui X7, MKS980, MKS950, Vbar, Railblades, Mezon 135, Scorpion 4035-500, Gensace 5300 12S Voodoo 700, BLS251, BLS451 , AC3X, EDGE, Kontronik Jive 120HV, Pyro 700-52, Turnigy 4000 10S |
05-03-2010, 03:01 PM | #3 (permalink) |
try to enter as 10 poles
Gaui 200 •Gaui 550 •Gaui X5 BeastX Castle Scorpion Hyperion Spektrum JR The Front Porch, Nexgens Lounge |
05-12-2010, 06:03 PM | #4 (permalink) |
I think the problem lies with the Kontronic, I solved my problem by just using one wire for sensor. You need to test what wire and to what cable on the motor.
Felipe |
04-08-2018, 12:41 PM | #5 (permalink) |
Hey guys, I have the Eagle Tree software reading the motor with the brushless sensor but I don't understand what each of the calibration settings do. Could somebody please help?
The motor has 32 magnets, 16 pair poles. The motor has an internal gear reduction ratio of 5:1 The wheel diameter is 20" RPM (at the wheel) should be about 140, multiplied by 5 this is 700 at the motor. The readings I'm getting are in the thousands though. For more info on my project: Wiring for the Mountain Wheelchair is Coming Along | Mountain Wheelchair |
