Old 05-12-2007, 12:28 AM   #1 (permalink)
cd5
Default What does a flybar actually do?
It may seem like a dumb question , but could someone please explain the function of the flybar. Laymans terms would be appreciated.
Thanks for your help.
cd5 is offline        Reply With Quote Quick reply to this message
Old 05-12-2007, 01:12 AM   #2 (permalink)
The flybar holds the paddles, it's the paddles that do the initial work to get the complete rotor disc to lean where you want it to.
To see it in slo-mo, unplug the rx battery and manually tilt the swash in any direction you want. Now slowly rotate the main blades and watch each mixing arm and linkage tilt each paddle up and down as you watch it go around.
This is the initial steering action to then tilt the rotor disc in the direction you want it to go.
AMA/CD# 365566 AOPA# 5081747
AMA Turbine # 15130
... Intercepting the Localizer...
Guidance by Futaba 14MZ Heli 2.4 GHz ......FUTABA-- Always Imitated, Never Duplicated
sleddog7 is offline        Reply With Quote Quick reply to this message
Old 05-12-2007, 06:57 AM   #3 (permalink)
Power steering for changing the pitch of the main rotor blades for cyclic input and gyroscopic stability. The heavier the paddles you run the more stable the system and the less aerobatic the helicopter. Lighter paddles mean faster aerobatics but its more likely to be disturbed by wind or pitch in fast forward flight.
Andy
AMA 77227
Jacksonville FL
http://www.jaxrc.com
BarracudaHockey is offline        Reply With Quote Quick reply to this message
Old 05-12-2007, 10:17 AM   #4 (permalink)
Like BarracudaHockey said, gyroscopic stability. You can fly without paddles, just weight on the flybar but you will end up with a very slow cyclic response.
On a flybarless heli, when you input cyclic, you get instant response. The flybar dampens this by resisting the cyclic input. You can control the amount of dampening by varying the paddles size/weight, position from main shaft and mixing levers(where tuneable).
Mark Webber
wai-rc.com
MarkWebber is offline        Reply With Quote Quick reply to this message
Old 05-12-2007, 12:05 PM   #5 (permalink)
The function of my flybar is to bend!
Mikado Model Helicopters
Edge Blades
Big Fil is offline        Reply With Quote Quick reply to this message
Old 05-12-2007, 01:29 PM   #6 (permalink)
So if I want to slow down the cyclic response - could I cut down (reduce in size) the paddles ? I don't want to kill the response, just make it less twitchy (EP 100)
Cheers,
Mike.
Old 05-12-2007, 02:58 PM   #7 (permalink)
Mike
The easiest and most tunable route is flybar weights. I use them on my AP gasser to help stabilize the cyclic response. Weights closest to the paddles is most stable. Move them in as you feel you want better response.
One of the reasons I went flybarless on my raptor.
Mark Webber
wai-rc.com
Old 05-12-2007, 06:19 PM   #8 (permalink)
Put wheel collars on the flybar, move them out (equidistant) to dampen, in to liven.
Andy
AMA 77227
Jacksonville FL
Old 05-13-2007, 09:46 AM   #9 (permalink)
Pistol Pete is offline        Reply With Quote Quick reply to this message
Old 05-13-2007, 10:29 AM   #10 (permalink)
Cheers,
Mike.
Mike, I have a ep-100 also. You can dampen it somewhat with heavier flybar weights and a lot of expo set on your radio, but the ep-100 is, by nature, what you would call ""twitchy"
Hopefully they will get some better blades out soon, but the short blades, high head speed, and low AUW, makes for a handful at times.
I have gotten used to it, If it's calm enough, I fly it first before I fly my t-rex. The rex seems so much smooother after flying the ep100.
jimh is offline        Reply With Quote Quick reply to this message
Old 05-13-2007, 10:53 AM   #11 (permalink)
Jim,
Thanks - I just find that I am sitting happily hovering and suddenly it shoots off on it's own for no apparent reason - that's the bit that I want to lose - I don't want to kill it's manouvrebility.
I've got some extra fly-bar weights thatI'll try and see if that helps.
Cheers,
Mike.
Old 05-22-2007, 07:39 AM   #12 (permalink)
Default Good Beginner Info
To understand things like fly bar function and gyroscopic effect it is always good to read Colin Mill.
http://www.adventurehobbies.com/colin_mill.htm
The fly bar function question is detailed here:
http://www.w3mh.co.uk/articles/html/csm9-11.htm
imported_Jon_Bennett is offline        Reply With Quote Quick reply to this message
