Esmart E-Sky Esmart |
06-30-2009, 07:27 PM | #1 (permalink) |
Align 600mm Blades on a E-Smart 600
Helidirect sells the 600mm blades for the Esmart and the Trex 600. Does anyone fly with the 600mm Align Carbon Fiber blades? Thanks
06-30-2009, 11:32 PM | #2 (permalink) |
Not a good idea with stock set up but doable with new main gear and 635mm boom. Pitch range should be less than +10/-10 and about 10T pinion. Headspeed should be around 1800-2100 max. Best with 550 blades, 10T pinion on 6S.
_____________________ Scott's Hobbies DVS inc. |
07-01-2009, 12:07 AM | #3 (permalink) |
I don't see a 635 boom for E-Smart 600 are you talking about using other heli parts from another heli? and belt
07-01-2009, 03:17 AM | #4 (permalink) |
I think he means the 632 boom, I've used 600 blades on my ES600, but only because I wanted the added stability for doing Aerial Photography. I personally will only run 600's on my Semi-Metal kit (with metal blade grips) because it has the long boom but a shorter tail blade hub/grips so the blades are further away from the tail rotor. With the Metal Tail blade hub and grips the tail rotor gets dangerously close to the main blades, IMO.
07-01-2009, 08:46 AM | #5 (permalink) | |
07-01-2009, 10:27 AM | #6 (permalink) |
The boom on the Semi-Metal, Metal and Carbon Fiber Editions all use the 632mm boo, (it can be 630-635mm too) the Plastic Edition and G-Smart both use the shorter 608 boom.
But I'm pretty sure Damyxz was talking about the MicroHeli main gear because there is no other upgraded main gear for the E-Smart. |
07-01-2009, 09:59 PM | #7 (permalink) |
Thanks I was just quoting a web site on the 630mm boom I have never measured it but you know the E-Smart better than I do. I believe I have the Carbon Ed. it has the CF frame and boom and the metal head and tail. I few a battery with a set of Align 600mm CF blades today less vibration and a lot steadier than the wood 550mm I have been using. 4 mins. used 1200mAh of a 5 cell 5000mAh 30c battery, motor was warm about 110 and esc was about the same. I haven't look for different pinion gears yet but I don't remember see them on HeliDirect have you orded any gears? thanks
07-01-2009, 11:32 PM | #8 (permalink) |
Sorry, 632mm for the aluminum boom and 635mm for the CF boom(I measured and I have to grind the CF boom because the belt was too tight. That head speed is too high for a set of 600mm's (2200 Rpm at 11.1V @ 80% efficiency within half stick throttle, 2400Rpm @ full stick throttle.) Be really careful because
you might throw a blade weight and might hit somebody or yourself. I'm suggesting that you get a smaller pinion to get a head speed of 1800 to 2000 RPM at hover.
07-03-2009, 12:57 PM | #9 (permalink) |
Blades
Here is my two cents boys!! I've found the Mavrikk G5 and their other CF blades they call Max. value are great blades! (550mm)Both are wide chord and pretty stiff,fly very stable. Even their Patreiot series, the stars and stripes are Great blades.. All are somewhat reasonable in price too.(50-60) Anyway give them a look. Got them at heliproz.
Blade mSR, HBK2 Xtreme Outrage G5 EXI500, HDX500, Esky 900 E-Smart CF Pro, Full Metal E Smart, Outrage 550 G-Smart. Pegusas |
07-11-2009, 11:08 AM | #10 (permalink) |
I use the Mavrrik 550mm wide cord carbons on my Esmart(metal ed.) they are great...
Track very well and the autos are easy with these blades... I think I got them for $55 a pair at HeliProz...very good blades for the money! Ty |
07-16-2009, 11:18 PM | #11 (permalink) | |
07-17-2009, 07:48 AM | #12 (permalink) |
align pinions will not work on the E- smart. I posted a source for an 11T/10T pinion here a while back. Just be safe first. The 550 size blades works great and if you can find a set of 520 carbons, that's the ticket.
07-20-2009, 03:56 PM | #13 (permalink) | |
Just my 2 cents
TRaeside Blade CX2 - T-Rex 250 T-Rex 450 - T-Rex 500 CF HIROBO Shuttle ZX - E-Smart 600 All Metal - Gaui 200- Vision 50 - T-Rex 600ESP |
Tags |
600mm blades, e-smart 600, h60155t 600d |
