Mikado Logo Helicopters Mikado Logo Helicopters Discussion |
12-03-2013, 02:28 AM | #41 (permalink) | |
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl |
12-03-2013, 02:37 AM | #42 (permalink) | |
Logo XXtreme 480 - What Setup?
I ask, because I'm planning on running the same motor, but I was just planning on tapering one side of the shaft down to the required 5mm to avoid playing musical gears. Lol Any and all insight and direction you can provide would be greatly appreciated. Thanks again bud. -Shane |
12-03-2013, 03:05 AM | #43 (permalink) | |
I already have the .7 main gear from my L500. I put mod 1 gears in that from day 1 so my mod 7 main gear was never used.
12-03-2013, 08:09 AM | #44 (permalink) |
+100, love your idea, this way we can use the pyro 600 and you don't have to taper the shaft as you can swab the 5 mm bearing from the CB to one that adaptes 6 mm shaft
_____________ |
12-03-2013, 08:18 AM | #45 (permalink) |
Does it definitely run a counterbearing?
JR Forza 450 | Align Trex 550 V1 | Henseleit TDF | Henseleit TDSF |
12-03-2013, 09:44 AM | #46 (permalink) |
The 480 does not use a CB.
(-: Dave |
12-03-2013, 09:58 AM | #47 (permalink) | ||
I get these two items: • MIK4318 Mikado 18 Tooth Herringbone Pinion, M0.7, dia. 6mm • MIK4094 Main Gear 153 Teeth, Modul 0.7 ...and I'll be able to use the Kontronik Pyro 600-12 / Kontronik Jive 100+ LV setup without issue? Plug & Play? -Shane |
12-03-2013, 10:00 AM | #48 (permalink) |
Hope Dave confirms this possibilty, module 0.7 and 6 mm shaft will be outstanding upgarde.
_____________ |
12-03-2013, 10:03 AM | #49 (permalink) |
oh the only thing lift is the motor plate mounting as pyro 600 uses 25mm bolt spacing, i know Mikado has been moving away to the 30 mm spacing. There could be an issue using the pyro buddy
_____________ |
12-03-2013, 10:12 AM | #50 (permalink) |
LOL it seems extremely stupid if they areusing a 30mm motor mount with the 480. Since most motors for that size heli would barely have room for 30mm spacing. But it could be the reason they went with the 4015...
Already a shame that they did that with the 550.
GAUI X5 with Eznov Neuron and T10J |
12-03-2013, 10:23 AM | #52 (permalink) |
Love your spirit Shane
_____________ |
12-03-2013, 10:26 AM | #53 (permalink) |
by the way 17 tooth pinion and pyro 600-11 gives better numbers on module 0.7, you can get 2600 rpm at 70% throttle using the Jive.
_____________ |
12-03-2013, 10:32 AM | #54 (permalink) | |
Thanks man! I'm just trying to enjoy the hobby and build a helicopter I've been lusting over for some time...the way I want to build it.
Let me know, I'm definitely not committed to the 600-12...Thanks! -Shane |
12-03-2013, 10:34 AM | #55 (permalink) |
Mikado published the custom scorpion motor, it looks like the designed plate is M3, 25 mm bolt
http://shop.mikado-heli.de/LOGO-480-...&c=7438&p=7438
_____________ |
12-03-2013, 10:35 AM | #56 (permalink) | |
-Shane |
12-03-2013, 10:38 AM | #57 (permalink) |
Is this directed at me? Are you saying the 600-11 would be a better choice over the 600-12 for the XXtreme 480?
Let me know, I'm definitely not committed to the 600-12...Thanks! -Shane[/QUOTE] Yes, i think 17T and pyro 600-11 is better fit for module 0.7 and logo 480. the numbers are not bad, 16T will be even better but it is not available, 18T is over gearing in my opinion.
_____________ |
12-03-2013, 11:38 AM | #58 (permalink) | |
12-03-2013, 11:48 AM | #59 (permalink) | ||
It's official, I've placed my pre-order / order for the XXtreme 480 and the above referenced pinion / gear. Thanks for all of the help and great ideas. -Shane |
12-03-2013, 12:59 PM | #60 (permalink) | |
With 17T Throttle 55%: 2226 Throttle 60%: 2342 Throttle 63%: 2412 Throttle 67%: 2504 Throttle 70%: 2574 Throttle 73%: 2643 Throttle 76%: 2712 Throttle 80%: 2805 With 18T Throttle 55%: 2357 Throttle 60%: 2480 Throttle 63%: 2553 Throttle 67%: 2651 Throttle 70%: 2725 Throttle 73%: 2798 Throttle 76%: 2872 Throttle 80%: 2970
