Belt CP E-Sky Belt CP
Old 04-16-2013, 06:09 AM   #1 (permalink)
Smile 600-size Jet Ranger - new project
Well, a new project has started, and the fleet has grown by 1. A few weeks ago, I got a HK600-GT and assorted other bits (I'll post details later). It's been built and test flown, no issues, and now the modifications start. First was to flip the tail to the other side, as this will be a scale Jet Ranger build, and the 206 has the tail on the left. Thanks to crappy weather, I've not test flown with this arrangement yet.
The scale fuse has been ordered and is now in the UK, and finally cleared Customs (2 days from pickup in Hong Kong to arrival in UK, 6 days for Customs to decide I have to pay VAT ), so I should have it tomorrow.
This is the fuse: http://www.centuryheli.com/products/...tml?pageid=247
I got the unpainted version, as I plan to model it on the full size as pictured below. because I flew in this one a couple of years ago.
More pics and details to follow as the build progresses. I expect that eventually this will become FBL, for the full scale effect, but that will be down the road a bit.
Helis: Belt-CP, Mini Titan, EXI 450, HK250-GT, HK500-GT, HK600-GT, mSR (all modified/customised). Quads: Q4, nQX, HK250, Custom built 560 Deadcat camera platform. Some planks. DX6i & DX9. And a boat & some HK surface controller thingy.
CyprusDave is offline        Reply With Quote Quick reply to this message
Old 04-16-2013, 06:34 AM   #2 (permalink)
Avant Aurora 90n,Trex 600E Pro, HC500, HDX450sev4, Trex 250se, mCP-X, Mosquito, X/A Hexa/WKM/UHF/FPV, F330 Flame Wheel,
PenguinV2/UHF/FPV, 757-3 ex Ranger/uhf/Ruby/fpv, QAV250 w/Vector , Ritewing Drak w/Vector Crossfire and fpv.
Tomstoy2 is offline        Reply With Quote Quick reply to this message
Old 04-16-2013, 08:41 AM   #3 (permalink)
As you may know, I'm a sucker for scale!
WRT FBL, as you know, I used the Tarot ZYX system and found it near perfect for my requirements Can't comment on what it would do for aerobatic or even 3D flying, but for getting a FBL head to work for scale flying....piece of cake.
I see HK are doing it now for silly low prices....$55 (£35)!! Why buy a gyro and then "upgrade"...go straight to FBL!
http://www.hobbyking.com/hobbyking/s...m_Adapter.html
450 Bell 222, 450 Jet Ranger, HBFP Redbee Extreme, 500 size Blackhawk MH-60, 600 EP Spitfire, Sebart 342 30e, Davy Systems Flybaby, ST Models FW190, Micro SU26 & GWS P38. DX7s
Luke Warmwater is offline        Reply With Quote Quick reply to this message
Old 04-16-2013, 11:09 AM   #4 (permalink)
Yeah Luke, if you remember I asked you about the ZYX on your build thread, as I was looking at it as an option. I already had a GA250 gyro, so that is on there at the moment, and works great (maybe not for 3D either, but that's not what I'll be doing).
I was looking at a combination of ZYX controller and RJX head, both from HK.
http://www.hobbyking.com/hobbyking/s...0_50_Size.html
Also looking to fit Spin asymmetric main and tail blades, then dropping the headspeed way down for more of a scale effect. I'll change the current 13T pinion to 10T (smallest available), and if required, go to a lower KV motor as well, although I don't think that will be necessary.
http://www.fast-lad.co.uk/store/spin...0-p-14411.html
http://www.fast-lad.co.uk/store/spin...5-p-16062.html
http://www.fast-lad.co.uk/store/revc...t-p-11944.html
The fuse is unpainted, and from what I can find out, there may be a bit of work building the mount for the mechanics as well, so I expect there will be plenty of time to get the FBL setup sorted before the fuse is ready for final fitment
Old 04-16-2013, 12:23 PM   #5 (permalink)
I dropped my headspeed right down as well (TC is at 45%!!). I dropped from an 1800Kv down to a 1300Kv motor as well.
I run on 6S 2430mAh 30C-40C and they do get a bit warm with a 5 min flight time, so I think I'll up those to around 4000mAh 40C min....if I can fit them in!!
I also added longer tail blades, to combat the torque from 4 blades. Even though the scorpion tail adds length (and therefore "leverage") going from 76mm to 84mm has made a massive difference...and the raised tail gives you clearance for it.
Old 04-17-2013, 10:27 AM   #6 (permalink)
Fuselage has just been delivered to my work address, and of course the box has been opened
First look shows it to be very nicely molded in lightweight glass cloth, outside finished in grey primer, with some nice detail.
However, it looks like I was a bit premature in switching the tail mechanism to the left side, at the fuse is molded to have the tail on the right. No doubt to ease installation, but at the expense of scale accuracy Oh Well. Apparently the 700-size version is molded symmetrically, so the buyer can decide during fitting which side the tail blades are on, but this is not the case with the 600.
