Old 02-16-2007, 08:37 AM   #1 (permalink)
Default 140 CCPM for Stratus
Does any one have any more info the 140 CCPM conversion for the Stratus.
Lou
Time is an illusion. Lunch time, doubley so.
THX1138 is offline        Reply With Quote Quick reply to this message
Old 02-16-2007, 08:41 AM   #2 (permalink)
What you want to know?
https://www.helifreak.com/viewtopic.php?t=25650
David
DavidH is offline        Reply With Quote Quick reply to this message
Old 02-16-2007, 10:41 AM   #3 (permalink)
if is for sale yet?
misio is offline        Reply With Quote Quick reply to this message
Old 02-16-2007, 01:33 PM   #4 (permalink)
I emailed MA last week and hae not heard from them. I would like to know price and availability.
Lou
Old 02-17-2007, 04:52 AM   #5 (permalink)
I called them wednesday and he said they are not ready yet,still waitng for some parts.DOUG
G MAN
NO ES MI CULPA
G MAN is offline        Reply With Quote Quick reply to this message
Old 03-12-2007, 02:47 PM   #6 (permalink)
any body have any pics?
Lou
Old 03-12-2007, 03:28 PM   #7 (permalink)
Not a great picture. But here is a picture of Gordie's Stratus with the 140 eCCPM coversion installed on it.
http://events.helifreak.com/clints07/341.html
David
Old 03-12-2007, 03:46 PM   #8 (permalink)
Default Same Adaptor plate?
Hi
Does the 140° swash kit uses the same two "Adapter plate"
(#0217-8 #0218-7) as used for the Fury??
Or is it some different plates, due to the less materiale, on the status frame, between the ovalholes near the two "Main shaft retaining Collors"?
I geuss the Framespacer between the two Bellcrank, can not beused anymore - as it looks like thebellcrank on the 140 swash is sitting right in front of the mainaxle.....
ChopperKnud
ChopperKnud,
Team Heliwholesaler - Team Miniature Aircraft
ThePitchbrothers.com
Knud Pedersen DENMARK is offline        Reply With Quote Quick reply to this message
Old 03-13-2007, 11:39 AM   #9 (permalink)
GM1
There are two pieces that bolt onto the swashplate to convert it to 140 CCPM. On my prototype model, I drilled the frame through the thin piece next to the main shaft and then glued and bolted a reinforcing plate to the inside that has a pem nut for the pivot axle. There is a drill jig included. This is VERY different from the 140 conversion for the Extreme.
MA has redesigned the Stratus side frames with the 140 pivot hole included and the area around the pivot beefed up so new kits will have the option of 120 or 140 CCPM. I have a set of frames that I am installing for testing. The original conversion has been great.
Gordie
In a dog sled team, if you're not the lead dog, the view never changes.
GM1 is offline        Reply With Quote Quick reply to this message
Old 03-19-2007, 12:26 PM   #10 (permalink)
I installed the 140 CCPM conversion on my Stratus two weeks ago. It was very easy to install. However, when changing the swash setup in the radio you must start over with the setup of the heli from scratch. Changing the swash type in the radio changes everything back to default settings. I have about 20 flights on it so far and I'm definately liking the way it tracks. I talked with Tim of MA and he says he now has conversion kits in stock for the Stratus.
Earl McCoy
RealMcCoy is offline        Reply With Quote Quick reply to this message
Old 03-19-2007, 06:46 PM   #11 (permalink)
so is it release already ? how much is it ?
-Kenny
sookainian is offline        Reply With Quote Quick reply to this message
Old 03-20-2007, 04:15 PM   #12 (permalink)
MA Part No. 0217-4 - 140 ccpm Stratus conversion kit.
Retail Cost $49.95
It is very likely that these kits have not filtered to the distributers yet but they are available at this time from Miniature Aircraft. 352.383.3201
Earl McCoy
Old 03-20-2007, 04:48 PM   #13 (permalink)
MA had the 140 deg kits at the Bham event. They were selling them there.
David
Old 03-20-2007, 07:04 PM   #14 (permalink)
i just ordered one today for my E-Stratus hopefully it will be here by friday, in time for the tyler Tx funfly.
chuck
Chuck Bole is online now        Reply With Quote Quick reply to this message
Old 03-20-2007, 08:24 PM   #15 (permalink)
Btw, do we need to mod the orginal frame before we are able to install the 140 kit ?
Where can i find the menual i would like to take a look before digging out some money to buy it
-Kenny
Old 03-21-2007, 07:53 AM   #16 (permalink)
A template comes with the kit. One or two holes need to be drilled in the frames.
There is no manual, this is just a couple pieces of carbon and a couple of machined arms that bolt to the swashplate.
David
Old 03-21-2007, 11:05 AM   #17 (permalink)
But after converting, if we dont like, can we change back to the 120CCPm or we will be stuck with the 140CCPm ?
-Kenny
Old 03-21-2007, 11:13 AM   #18 (permalink)
IT can be swapped back and forth. You have to start programming fresh for the 140 deg CCPM. So once you change to the 140 deg CCPM from the 120 deg CCPM, it wipes out the model. So it is best to program the 140 deg CCPM on a new model memory.
David
Old 03-21-2007, 11:24 AM   #19 (permalink)
Ok, i am planing to get it soon.
Haha but is it worth changing ?? and recommandation ?
-Kenny
Old 05-01-2007, 06:17 AM   #20 (permalink)
Hi,
Is the 140 Swashkit still only available from MA??
ChopperKnud
ChopperKnud,
