Go Back   HeliFreak > R/C Helicopter Support > Mikado Logo Helicopters > Mikado Logo 700 Xxtreme
Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion
Old 11-29-2013, 02:45 PM   #1 (permalink)
Default Logo Xxtreme 700 motor
Hey guys, wondering if anyone is running anything other than the scorpion motor in this heli. I'm using the Align 800mx with CC Edge 160 ESC and it rocks!! Have never ran the Scorpion in this heli and was wondering if it's even worth trying cause the 800mx produces more power according to the specs.
Alignment is offline        Reply With Quote Quick reply to this message
Old 11-29-2013, 02:59 PM   #2 (permalink)
I'm waiting for a pyro-850-50. I'll post up my findings!
Silverline V-bar, Vbar Control
#205
rebeltrousers is offline        Reply With Quote Quick reply to this message
Old 11-29-2013, 03:20 PM   #3 (permalink)
I guess that motor has the right shaft for that heli?
Old 11-29-2013, 04:54 PM   #4 (permalink)
Yeah apparently it does. 8mm long shaft.
#205
Old 11-29-2013, 05:58 PM   #5 (permalink)
A Scorpion originally, I run a HKIII 4530 450kv Mauro.
Runs great!
sl4ppy is offline        Reply With Quote Quick reply to this message
Old 11-29-2013, 11:42 PM   #6 (permalink)
Running KDE 700XF-495 in 14S. Loads of power. Had to increase the tail gain a bit because of the toque.
HD750, TDR II, TDR, Logo 700, Logo 700 XXtreme, Logo 550SX V2
taoY is offline        Reply With Quote Quick reply to this message
Old 12-01-2013, 10:49 PM   #7 (permalink)
Pyro 850 hzndwind by myself yy termination on 14 s, saying that nothing wrong with mx 800, outright on bench or speed setup scorpion will be the stronger motor but on a governed heli with enough headroom you will not notice difference while at low to partial throttle it will most probably be more efficient. worth spending money on scorpion, nah rather get yourself a jive 120, will work very well with mx
Tdr quantum 4530 1.4 yy h/ jive120 beastx, Vibe e 8 12s mx 700 1.32yy vbargov fusionhawk, Banshee nr 36 kosmik 200 pyro 800 1.4yy 455kv 14s beastx, xtreme 700 pyro 850 1.5yy 14s kosmik 200
Stolla is offline        Reply With Quote Quick reply to this message
Old 12-08-2013, 01:28 PM   #8 (permalink)
I have a Cool Kosmik 160HV and Pyro 750-56L, could this combo be used in the 700 Xxtreme?
Synergy N5c TT | JR Forza 700 | Bell 430 Turbine
rdavis is offline        Reply With Quote Quick reply to this message
Old 12-08-2013, 03:23 PM   #9 (permalink)
Yes it'd be great as long as you can gear to the right HS!
#205
Old 12-08-2013, 03:28 PM   #10 (permalink)
Reb… Many thanks. What range of head speed should be targeted for L700Xx?
Old 12-08-2013, 03:40 PM   #11 (permalink)
MrMel's HS thing says that at 80% on the Kosmik running 12s and 17t pinion you'd be around 2141rpm which is pretty high.
Mine is around 1850....but I should probably go up a tooth anyway.
Running yours at 75% will give you around 2000 which should be fine?
I think the KV of your motor vs the lack of pinion choice is a pain but your esc/motor are top-shelf so it will still be a beast. IMHO.
See what others have to say?
#205
Old 12-08-2013, 04:16 PM   #12 (permalink)
Thanks again Reb… I did read in another thread that you can't use the 750 series Kosmik because the shaft is 6mm. I looked and do not see any 6mm pinions so it may be a no go???
Old 12-08-2013, 09:09 PM   #13 (permalink)
Is it a 6mm shaft?
#205
Old 12-09-2013, 03:37 AM   #14 (permalink)
Yes, the one I have is 8mm internally and 6mm externally. If I recall they make a 8mm shaft version too.
Old 12-09-2013, 07:30 AM   #15 (permalink)
I/m running a 18 tooth pinion with 800mx 520kv motor 2100 hs
Old 12-09-2013, 07:36 AM   #16 (permalink)
Alignment… is your shaft 6mm and if so is the pinion a Logo pinion and if not where did you get it from?
Many thanks, Ray
Old 12-09-2013, 09:01 AM   #17 (permalink)
Out put shaft on this motor i have is an 8mm by 52.3 mm which is perfect for the heli! Ypu can purchase this motor with this shaft through AMAIN hobbies for 230$ and it rocks! Obvioulsy im using a Mikado pinion too...
Old 12-20-2013, 06:58 PM   #18 (permalink)
Kontronik pyro 800-48L and kosmik 160 cool fitted to mine. Great combo. It's a squeeze to fit the cool under the canopy, and to be honest, unless you fly somewhere stupid hot, the standard kosmik would be perfect
helinutz is offline        Reply With Quote Quick reply to this message
Old 12-20-2013, 11:06 PM   #19 (permalink)
Cool what HS??
#205
Old 12-21-2013, 09:49 AM   #20 (permalink)
Many thanks helinuts... I will most likely have to go with another Heli as I already have the pyro 750 and cool 160, both brand new still in box.
