450 Class Electric Helicopters 450 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
09-12-2011, 11:19 PM | #201 (permalink) |
Wow incredible wiring job Matt!!!
S
Trex 470LP / Beastx / Align BL50X / Align 470MX Trex 500X / Beastx / Align RCE-BL80X / Align 520MX |
09-13-2011, 06:03 PM | #203 (permalink) |
OMG! It's a wireless heli!
09-13-2011, 11:16 PM | #204 (permalink) | |
S
09-13-2011, 11:23 PM | #205 (permalink) |
Thanks for posting those, Matt! I'm in the middle of a 450 Pro 3gx build, myself, and that's a wiring job I'd love to mimic.
09-14-2011, 10:07 AM | #206 (permalink) | |
I took my time doing the electronics wiring, and wasn't afraid to take the heli apart to get the wiring right. I found myself doing some of the wiring one way, then I'd think about it and come back to it the next day to change it and improve it. It took a while, but I'm pretty happy with the result. Not perfect though by any means. Thanks guys! |
09-14-2011, 10:26 PM | #207 (permalink) |
I would like to see the inside wiring with one of the side frames removed if that's possble. I know it's a pain so it's ok if you don't want to. Maybe you already have some pics taken earlier.
09-15-2011, 12:39 PM | #208 (permalink) | |
With the satellites, ESC servo wire, and the tail servo, you'll have an abundance of leftover wire you'll have to be crafty at tie wrapping and tucking into a safe spot. But the main servos wired the way I have them mounted to the 3GX in position 1 will give you a nice tight fit without much fuss. Just be sure to tie wrap the servo wire tightly against the inside of the frame as to give the most clearance from the rear gear in the tail. Take your time to position the servo wire so it lays flat against the CF. Here you go, hope this is helpful...
Helis - TREX 550 Pro V2 3GX, TREX 450 Pro V2 3GX, Trex 250 Pro, Blade 450, MCPX, SR, SR 120 Transmitters - DX8, DX6i |
09-15-2011, 12:57 PM | #209 (permalink) |
Matt, that's quite understandable about removing a side frame after you've just completed the wiring. However, your diagram is exquisit and certainly gives the complete picture.
Thanks! |
09-15-2011, 01:27 PM | #210 (permalink) |
No concern for interference/vibration by having the 3GX unit so close to the motor?
Align Trex 450 Pro & 450 Sport | E-Flite Blade CX3, mCPX and 120SR | Syma S032 and S107 Parrot AR Drone 2.0 | Futaba 10CHG | FlyMentor | Co-Pilot II | Traxxas Nitro Stampede If my hobbies don't kill me soon, I'll die a poor man. |
09-15-2011, 01:49 PM | #211 (permalink) |
Matt,
That looks similar to my wiring job that I got from watching Antonio from hobbypartz.com/xheli wiring video of an EXI 450 pro. I didnt follow him and run each front servo wire on the same side it is on, rather ran them all togeher with the ESC. What are the "Satellites" ? Antenna? Thanks and nice work! |
09-15-2011, 04:14 PM | #212 (permalink) | |
If you haven't noticed already, position 1 is perfectly center with the main shaft, so the 3GX when mounted at position 1 is at the heli's center of gravity. It's also the center of the heli where vibration will begin from. So in theory, anywhere further away from the main shaft (the heli's ceneter of gravity), the greater any vibration will be. So mounting the 3GX in position 2 might increase any vibration the unit experiences and also might give the 3GX a slightly less accurate reading of its axis's since it's not sitting at the helis center of gravity. That's my take on it anyway.
09-15-2011, 04:21 PM | #213 (permalink) | |
Yeah, both front servo wires run individually on both sides of the frame and meet the 3Gx in the back and they come together like a V. You can read up about the satellites and their advantages here... http://www.spektrumrc.com/DSM/Techno...dFeatures.aspx
09-15-2011, 06:24 PM | #214 (permalink) |
I was less concerned with vibration and more with electrical interference. I haven't seen the 3GX instructions, so if that's where Align suggests to put it, they must have tested it out, I would assume. Oh, and the centerline of the mainshaft is not necessarily the center of gravity. COG is determined by weight distribution and not physical placement of components.
09-15-2011, 07:32 PM | #215 (permalink) |
Position 1 is closer to the center of gravity of the heli than position 2, making it's corrections that much more accurate than position 2.
09-16-2011, 08:13 AM | #216 (permalink) |
Matt,
Thanks for the link. I have a Futaba FASST system and now I know why they say to take those two long (longer than JR anyway) antenna leads and try to get them 90 deg. apart. |
09-17-2011, 03:02 PM | #217 (permalink) |
Im well pleased to have seen this thread tonight as i hate having nothing but loose wireing hanging around on my RC cars and heli!!! Ive just been checking out new servo plugs as well as some techflex and heat shrink so that when i come to finishing my HK 450 V2 i will have all the wiring all neat and tidy and at the right lenths so it doesnt look all messy and badly finished off!!! Theres some really nice pictures here for me to get some good ideas!!!
09-17-2011, 03:10 PM | #218 (permalink) |
I'm not so sure about that. 3D helis have a high COG closer to the head, so the #1 spot may be closer to the mainshaft, but not necessarily closer to COG.
09-17-2011, 04:46 PM | #219 (permalink) |
Component placement is important, and it's great to discuss the pros/cons of each. Options such as putting an ESC under the battery tray where it helps pull CoG forwards and helps separate power/control electronics vs side mounting for arguably better cooling make for interesting debate.
Anything with buttons on it is even more of a challenge. I like keeping stuff safely inside the frame, but this can make access tricky. The CGY750 on my 500ESP (yeah, I know this is a 450 thread and mines on the 2nd page!) is a fine example of this, resulting in the unconventional, but perfectly usable placement under a carbon fibre receiver tray: Keep these posts coming guys... Makes for interesting reading... Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail Blackout 330/OpenPilot Revo with FatShark 600mW VTX, Futaba 8FG 2.4GHz |
09-18-2011, 02:33 PM | #220 (permalink) |
T-Rex 450 wiring
These pics were taken during a post flight check and cleaning. I tried to keep the wiring as hidden as possible. there is a boot (not pictured) to cover the wiring to the receiver I also secure the antenna wires to the skids and angle out for flight.
