Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters
Synergy Model Helicopters Synergy Model Helicopters Support
Old 07-27-2014, 05:17 PM   #1 (permalink)
Default assembly help
My recently rebuilt E7 went it yesterday after i lost the tail. Luckily crash wasnt bad, i was able to get it close to level and kill the throttle. It just cost me a set of main blades, a link, and some tail transmission parts.
My pin that holds the 18t bevel gear onto the spurs gear shaft came out. has anyone experienced this, and are you guys gluing the pin in or doing anything besides pressing it in to ensure it doesnt come out?
Specter 700 x 2--Diabolo UL--Compass 6hvu--Logo 600--oxy5+, oxy5, Oxy3, oxy2, SAB Mini Comet
Cajun Aircraft
B.Ewing is offline        Reply With Quote Quick reply to this message
Old 07-27-2014, 06:36 PM   #2 (permalink)
Hi B.Ewing,
Sorry to hear about your E7 going down, hopefully you can get her fixed and back in the air quickly.
The pin that secures the 18T bevel gear to the output shaft should have small M3 set screw securing it through a threaded portion of the output shaft where the gear is located. If the pin is missing or hasn't been secured down fully the centrifugal forces will eventually allow the pin to work free.
Hope this helps,
Cheers,
Ross
Thanks!
Rossco (Team Synergy UK)
Rossco is offline        Reply With Quote Quick reply to this message
Old 07-27-2014, 08:12 PM   #3 (permalink)
See these diagrams from manual. There is a set screw holding both the front bevel gear pin and the rear
These are from E5 but they are the same on the E7
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 07-27-2014, 08:33 PM   #4 (permalink)
I see didn't realize that it was a retainer
Cajun Aircraft
Old 07-31-2014, 09:29 AM   #5 (permalink)
another reason why our synergy models .pdf manuals are awesome.
~Synergy N7, YS91-3DS, IKONV2/BT XPERT SERVOS
~Synergy N5c TT, OS55-H, IKONV2
~Blade 180cfx
~Futaba T14SG
TeamXpertServos
Frequency is offline        Reply With Quote Quick reply to this message
Old 08-24-2014, 11:49 AM   #6 (permalink)
It's happened again. Lost the tail, same pin is gone. I don't know how, I definitely paid attention to the set screw this time around. This model went crash free for 1.5 years now 3 this summer
Cajun Aircraft
Old 08-24-2014, 12:47 PM   #7 (permalink)
Take the pin out. Run the set screw down until you can see it through the pin hole. Make sure there isn't any metal slag or debris in the hole.
Old 08-26-2014, 04:53 PM   #8 (permalink)
Chris is correct in making sure the thread are is clear. I run a pipe cleaner in all screw holes with acetone to get the cutting oil out of the threads. Those pins are really hard and the set screws do not tend to hold hard smooth pins over time. I sand the center of the pin with a dremel sandpaper disc, assemble and insert the pin, put a small drop of RED loctite in the screw hole and cinch down the set screw. The loctite is forced a head of the set screw. You will be surprised how well the RED stuff holds when you put it where it does't belong. Can't get it apart, well Tail output shaft $13.00, tail bevel gear $13.00 for a 2 pack, pin $2.00, CRASH $200.00 +, your choice.
Hope you get this problem solved, these machines are such fun to fly. Don S.
ds1rc is offline        Reply With Quote Quick reply to this message
Old 08-26-2014, 05:42 PM   #9 (permalink)
yea my game plan is to put that pin in Permanently and just change the whole shaft if need be.
Cajun Aircraft
Old 08-29-2014, 10:55 AM   #10 (permalink)
Some people are totally against red locktite but if you don't want your bird to come apart in the air it is the only way to go and if you need to get it apart later just use your soldering iron and touch the screw for a few seconds and it should come right out.
~Blade 180cfx
~Futaba T14SG
TeamXpertServos
Old 08-29-2014, 11:42 AM   #11 (permalink)
Although I've always been aware of the importance and significance of the set screw, I've never thought much about it after the initial build because after 4 Synergy builds (on my 5th now) and 1000+ flights, I've never had a single problem with the pins getting thrown. But this thread is inspiration to go back and check the security and integrity of the set screws on each of my Synergy models. Thanks for posting, and good luck on getting it sorted out and back in the air.
Nitro: Synergy N5c, Synergy N7
Electric: Synergy E7, Synergy E5, Logo 600SX, Henseleit TDR
bmclaurin is offline        Reply With Quote Quick reply to this message
