Futaba CGY750 FBL System Futaba CGY750 Help and features Support Forum |
11-11-2014, 05:00 AM | #1 (permalink) |
GY750 eGovernor - Overspeed
Hi guys.
Have a Goblin 630, with a Castle Phoenix Edge Esc with 4.20 firmware and GY750 with 1.40 firmware. On bench with no load, setting up the aux line on Esc as RPM Out and connected to RPM sensor on GY750, using the Esc governor, it mantain the exact RPM (less than 5 RPM differences) that i have configured on Esc. When i use the eGovernor from GY750, i cal the RPM on the governor setup and its ok, but when i start the engine, i always get more RPM, like 300 more in normal, 150 more in Idle1, etc. If its because i have no load, why the Esc governor works flawless and GY750 no? Thanks. |
11-14-2014, 04:23 PM | #2 (permalink) |
Look for posts from me in this forum and you'll find a wealth of information of the governor.
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail Blackout 330/OpenPilot Revo with FatShark 600mW VTX, Futaba 8FG 2.4GHz |
12-01-2014, 07:40 AM | #3 (permalink) |
5ephiroth
Have you had any new luck with setting up the egov in the CGY750, there was so much talk about guy's waiting for the egov update with 1.4 and there is very little info about how it is working. I would like to setup my E5s with the egov. Thanks
MA Furion 6, LHS Setup MA Fury 55: Futaba BLS 251, BLS 451, CGY 750, FGH12, OS 55 HZR, Hatori Synergy E5S: CGY 750, 14SG, KDE Direct Forza 450: Xnova, CGY 750, 14SG, MKS |
12-02-2014, 02:42 PM | #4 (permalink) | |
Steve
