Old 05-28-2013, 06:24 AM   #1 (permalink)
Default Did I brick my DS-16?
So...
New DS-16 with firmware version 2.0 delivered today.
Using my Mac, followed the update procedure to update to 2.01.
Upon restarting the DS-16 I get a bunch of text saying Application Test Failed and an MCU list of switches etc.
At the end of this is says:
Update file not found
Connect USB and upload firmware
Hold PWR+ESC buttons to power off/reset
The SD card no longer mounts so I cannot access the filesystem to re-upload the firmware and resetting just cycles through the above errors.
Any ideas on how to reset to factory?
SAB Goblin 500
SAB Goblin 700
Jeti DS-16
bobloblaw is offline        Reply With Quote Quick reply to this message
Old 05-28-2013, 07:36 AM   #2 (permalink)
Sorry to hear that... Did you remove the SD card from the Tx to try to mount it?
My DS-16 came with 2.01 installed fortunately
Minicopter Diabolo 800+ - Minicopter Triabolo - Srimok FAIFA
Jeti DS-16
tribe3 is offline        Reply With Quote Quick reply to this message
Old 05-28-2013, 07:42 AM   #3 (permalink)
I cant work out how to remove the SD card, seems well and truly held in its slot.
SAB Goblin 500
SAB Goblin 700
Jeti DS-16
Old 05-28-2013, 11:05 AM   #4 (permalink)
EspritModel.com
Exactly as card on cell phone, down and out.
Esprit Model is offline        Reply With Quote Quick reply to this message
Old 05-28-2013, 03:33 PM   #5 (permalink)
I removed the card. I appreciate the attention Esprit Model.
I need someone to send me the standard filesystem please as my DS-16 is now bricked until I can format the SD card and put the files back as they were.
Could someone please help my by uploading the contents of their SD card to dropbox so I can try and get my DS working again? Without this I am stick with an expensive paperweight.
SAB Goblin 500
SAB Goblin 700
Jeti DS-16
Old 05-28-2013, 03:56 PM   #6 (permalink)
Pm me your email I will send it to you V 2.01
Old 05-28-2013, 06:20 PM   #7 (permalink)
I can send you V2.0 that I backed up straight out of the box. Let me know if you have an FTP address or Dropbox.
Have laser, will travel.
cbdane is offline        Reply With Quote Quick reply to this message
Old 05-28-2013, 09:13 PM   #8 (permalink)
Just PM'd you with a DropBox link to my backup files. Hope this helps!
Old 05-28-2013, 10:13 PM   #9 (permalink)
Thanks to those that helped with sending files through.
Unfortunately this hasn't worked. I've formatted the card and put on the original files for the DS-16 and used a brand new SD card as well in case the card was an issue.
No luck, still stuck with Application Errors. Looks like this one is heading back to Esprit.
SAB Goblin 500
SAB Goblin 700
Jeti DS-16
Old 05-28-2013, 10:15 PM   #10 (permalink)
What is the firmware update process?
Copy files to card and boot?
MacOSX sticks its own files on the card, which might be getting in the way...
[B]TT E820 - Kosmik 200, Scorp 5035 TT G4.1(x2) - OS 91 3D Speed, Hatori
MSH Brains + JETI DS-16
rossk is offline        Reply With Quote Quick reply to this message
Old 05-28-2013, 10:31 PM   #11 (permalink)
Yes, that's the process. I cleaned the card of dot files before ejecting, no luck.
I'm fairly convinced the firmware process started but failed and now need to be sent back for service.
SAB Goblin 500
SAB Goblin 700
Jeti DS-16
Old 05-28-2013, 10:38 PM   #12 (permalink)
Did you clear the .files on a windows PC?
Mac will rewrite the files everytime it looks at it.
Also clear you trash before you eject, as they will still exist on the card until you empty trash.
Old 05-28-2013, 10:52 PM   #13 (permalink)
Yep, all clean. I worked as an Apple tech for years and currently work selling them so I am fairly OK with Unix to delete the dot files and directories.
SAB Goblin 500
SAB Goblin 700
Jeti DS-16
Old 05-28-2013, 11:04 PM   #14 (permalink)
So only the files that need to be there are there and it still fails?
I'm out...
Old 05-28-2013, 11:22 PM   #15 (permalink)
Yeah. Also did grab a Windows PC here and tried again, no luck.
SAB Goblin 500
SAB Goblin 700
Jeti DS-16
Old 05-28-2013, 11:45 PM   #16 (permalink)
there should be a way to get it back into a boot loading mode, so it starts again...
Old 05-28-2013, 11:46 PM   #17 (permalink)
Did you try installing the original files as well as the 2.01 update files. That might force it into an update sequence, clearing up the problem?
Old 05-28-2013, 11:50 PM   #18 (permalink)
Yes, tried that as well.
If I leave the update files there I get the following error:
"Update file not found"
If I use just the standard files without the updates I get:
"Application check failed! Check System!"
and it then reboots and presents the same error, over and over.
SAB Goblin 500
SAB Goblin 700
Jeti DS-16
Old 05-29-2013, 04:11 AM   #19 (permalink)
Default Re: Did I brick my DS-16?
Have you tried replacing the card with another one? Perhaps the card has gone bad.
Raptor E700: PowerDekker Pyro650, JR DS8925HV & SPG01, 12s, Vortex VX1, Kosmik160, Jeti DS-16
_Dekker is offline        Reply With Quote Quick reply to this message
Old 05-29-2013, 05:30 AM   #20 (permalink)
Yes. I had to buy a new card to get a micro SD to SD converter so I have tried a new card. Wish it worked!
SAB Goblin 500
SAB Goblin 700
Jeti DS-16
