Align 3G FBL System Align 3G FBL Flybarless System Software and Hardware Support |
07-08-2014, 03:37 PM | #1 (permalink) |
3gx Not Powering Up/Binding
I was at the field today flying my 450L Dominator. I have over 50 flights on the heli with the 3gx so far, and have had no issues up until today. I ran one pack through it without issue. I wait about 10 minutes in between flights and get the heli prepped for the second flight. Plug in the battery and notice the sat was blinking, indicating a low signal. Tried re-binding it, to no avail, and now the 3gx doesn't do a thing. It has 4.94 volts coming in from the ESC, but is not showing any voltage output?
Did my 3gx go bad or is there something I am missing?
450L Dominator 6s, Nano CPX, DX8 |
07-08-2014, 03:54 PM | #2 (permalink) |
Is the sat blinking intermittently(flickering) or flashing like when you initially bind?
07-08-2014, 03:58 PM | #3 (permalink) |
Originally it was just an intermittent blinking. After attempting to re-bind it, the sat did not give any kind of light, nor did the 3gx unit. I tried multiple satellites, and all did the same thing. ESC was getting voltage to the unit, so by process of elimination, I would assume the 3gx is bad.
07-08-2014, 04:21 PM | #4 (permalink) |
Could be but have you tried a different Sat Ant port on the 3gx?
07-08-2014, 04:56 PM | #5 (permalink) |
I have tried both ports with different cables and sats and neither did a thing.
07-08-2014, 05:03 PM | #6 (permalink) |
Doesn't sound good, you're right...........
Forgive me for asking a simple question but are you trying all this with the bind plug installed? |
07-08-2014, 05:18 PM | #7 (permalink) |
Yes I have been. Tried multiple bind plugs, with the possibility one of the ones I was using was bad and got the same result from each.
07-08-2014, 07:10 PM | #8 (permalink) |
The only other thing I can think of, before pointing the finger directly at the 3gx, is does your Dx8 connect, or indeed bind, to any of your other models? Just to rule out your Tx.
07-08-2014, 07:14 PM | #9 (permalink) |
I tried binding it to a DX9 as well and it did not work. I think I have tried and re-tried everything. Tried to eliminate as many other factors as I possibly could and everything points to the 3gx being the issue. I'm going to order up an AR7200BX to replace it. Have heard that the heli will fly so much better with that unit as opposed to the 3gx. I had the heli locked in with the 3gx, so if it flies any better than it already does/did, I will be an extremely happy camper!
07-08-2014, 07:37 PM | #10 (permalink) |
Yep, I can't think of anything else you haven't already tried?? Although, aa last ditch attempt (while waiting for your new FBL), you could try powering your 3gx from an external source to eliminate the ESC/Bec. Just remember to pull the red wire from the Throttle servo connector if you do this.
Good luck and hopefully you're back in the air soon |
07-08-2014, 07:43 PM | #11 (permalink) | |
07-08-2014, 07:49 PM | #12 (permalink) |
Sorry I couldn't help some.........
Pity one of the 3gx gurus isn't online to help. They may have some better ideas. I don't fly an AR7200bx but plenty at my field do, on different makes and size Helis, and they all like it. Not as tuneable as the 3gx or some other FBLs but it 'just works' is what they say..... |
07-09-2014, 02:23 PM | #13 (permalink) |
Where are you reading 4.94V? at the satellite cable or ESC to 3GX? If ESC to 3GX, that sounds low. It should be 5.5V or higher, preferably 6V.
What satellites are you using? DSM2 or DSMX? One or two satellites? 3GX will not power up if it not seeing the radio signal/bounded. I'm assuming you are following the proper steps for your satellite binding(DSM2 and DSMX has different binding steps). Have you tried to bind the satellite antenna connected to a full receiver/satellite to your radio?(taking 3GX out of the chain to make sure no issue with the satellite/transmitter) |
07-09-2014, 02:46 PM | #14 (permalink) | |
I'm using a single Spektrum DSMX satellite. I tried using a different sat and nothing would work again. When I plug in the battery, neither satellite showed any kind of light. I tried both satellites in the 2 ports on the 3gx. I tried binding the sat to a AR7200BX and it worked without issue so it is not the sat. I'm fairly certain there is something wrong with the 3gx. I tried to bind it using an Align ESC off of a TRex 500 and nothing would work.
07-10-2014, 09:50 AM | #15 (permalink) |
ESC/BEC should be putting out around 5.5V to 6V. I wonder if something caused the internal BEC to fail in your last flight(when it came down abnormally hot). If you have a servo or servos that are binding(gear damage or any other mechanical damage in the head/tail section), it will overload BEC and may cause it to burn out/damage components. You may want to contact Align to have them check out your ESC/BEC(assuming Align) and 3GX.
07-10-2014, 10:23 AM | #16 (permalink) |
I had had a crash prior to the flight. Damaged one of the blades, slightly bent the main shaft, stripped the torque tube gears, and bent the tail boom. I checked the head and tail assembly for damage and nothing was evident.
The servos were free and were not binding, so I assumed there was no issue there. I will run them through a test on my iCharger 406DUO and see what it comes up with. I ordered a Castle Edge 50 and an AR7200BX to replace the stock units, but hopefully I don't need a new set of servos as well.
