Old 11-08-2010, 12:22 PM   #1 (permalink)
Default Fury 55 "clicks & pops" Or whats wrong with the Fury 55
Now tha the Fury 55 has been out for a while, What issues are there with this heli, if any? I know there were a few teething problem early on, but that happens with anything "new". Have those early problems been taken care of? I thinking new heli and I considering the Hirobo SDX, Audicity Pantera and the Fury 55. That's quite a range of choices, but so far, those are the choices.
kenh is offline        Reply With Quote Quick reply to this message
Old 11-08-2010, 01:21 PM   #2 (permalink)
Well, I can only compare it to T600, both are now FBL.
I bought the Fury as my last attempt at staying FB. It flew OK, but I did not like it as much as my T600 FBL. It always has been very smooth. The recent installation of Vbar Blue 5.0 has now made it my favorite heli.
Notes:
1) Mounting all of the electronics can be interesting, there is a post with pics for ideas.
2) They had a main shaft issue that has been resolved, the new shaft is solid, the old shaft was hollow.
3) There is a know vibe issue around 1800. I run it at 2100, so it has not been a problem.
4) The landing gear is like butter, a pro suggested the Align gear, it works out much better.
5) They offer a bottom CF support that does not come in the kit. I installed it from the start as others had posted that they broke the frames on hard hits without it.
6) I converted the FB head to FBL for $30 worth of RJX parts.
7) More and more stores are starting to carry parts. MA, Heliproz and Heliproz South of course have the same parent company. Other retailers I have found are Hobby Hut and most recently Helidirect.
8) I was a little disappointed that there were some part shortages recently. Everything seems to be back in stock. Part of this was the main shaft problem.
This does not make sense yet to me, but I am running YS 56's in both heli's.
The MA is pulling much harder than the T600 and it does not bog as easy with identical collective/cyclic pitch. Both engines are similar on run time, engine temp, etc.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 11-08-2010, 07:50 PM   #3 (permalink)
Thanks Fast!
About the hard pulling YS 56's... Years back there was a car racing series with "Identically" prepared cars. I think they were Camero's, anyway, every year one of the cars always out run the others. Kind of like your two helis.
Anybody else have any comments?
Old 11-08-2010, 08:32 PM   #4 (permalink)
I've got kit #12. I love the machine. My main shaft (hollow, came with the kit) is just fine. Only some of the main shafts were soft...which has been resolved. The only thing that I didn't like was the clips on the spindle. No problem with the "soft" option, but when you add all of the shims for max-stiffness..it's nearly impossible to get the clips to seat. However, this too has been resolved with the 1-piece clipless dampers. Cheap, and very easy to install.
Ron's has excellent service, and hey, you can always call MA if you want. All around, you can't go wrong with the Fury 55.
-Joey
J.B. Jones
head_node is offline        Reply With Quote Quick reply to this message
Old 12-06-2010, 11:50 AM   #5 (permalink)
About the vibe issue.. can you comment more on this?? My machine runs super smooth, but there is a visible vibe at the top of the canopy. I always ignored it and thought it was the flimsy Canomod canopy.
so far my only complaint is they coulda done a better job with the canopy. Its cheap likes to crack and chip, plus the color scheme is a bit ugly.
eightythree is offline        Reply With Quote Quick reply to this message
Old 12-06-2010, 05:01 PM   #6 (permalink)
On mine , it's not a " vibe" issue ; its a low head speed nod , as the really hard head setup requires a higher head speed ..
My Tempest head equipped Stratus's do it as well; no biggie....
And yep , the canopys aren't anywhere near as solid as MA's used to be , but they are lots less $$$$$$....
Peter .... Furion 6 FBL ; E,N and G Whiplash FBL ; 2 Spectra G FBL ; Stratus FBL ;MA Extreme+E Razor+N Razor +Fury 55 FBL;xcell 60+xcell 70: TSA 700N & G; TSA 600N Pro & Platinum ; All BeastX ; guided by XPS .
Peter is offline        Reply With Quote Quick reply to this message
Old 12-06-2010, 09:57 PM   #7 (permalink)
We did just release some slightly softer dampers, they really reduce the low headspeed "nod"
p/n 0844-13 are 85 durometer
http://www.heliwholesaler.com/0844-1...nfo/MA0844-13/
p/n 0844-14 are 80 durometer
http://www.heliwholesaler.com/0844-1...nfo/MA0844-14/
and p/n 0844-15 is a damper tuning kit with 80,85, and 90 durometer
http://www.heliwholesaler.com/0844-1...nfo/MA0844-15/
We did testing with these softer dampers and we found they are suitable for 3d flying as well as sport/hovering. If you like to fly with a lower headspeed, I highly recommend them.
Zeal Rotor Blades
Team Horizon Hobby
Brian James is offline        Reply With Quote Quick reply to this message
Old 08-14-2011, 01:51 AM   #8 (permalink)
-Joey
I just gotten a new fury from a fellow friend and after adding all the shims for max stiffness, it is impossible to get in the c clip. Can I do away with the c clip? I tried the whole morning but can't seems to work.
Kasama Srimok 90: JR8917HV all round | YS91SR | Hatori 946 | Spartan Quark | BLS251
http://nitro-magic.blogspot.com
TmMugen is offline        Reply With Quote Quick reply to this message
Old 08-14-2011, 05:43 AM   #9 (permalink)
-Joey
Hello, did you not install the c clips?
Old 09-06-2011, 08:52 PM   #10 (permalink)
Tim,
My apologies, I've been away from the forums for a while.
Forget the shims for max stiffness. Drop one of them so that you can get the clips to install. You probably won't notice the difference. I broke more of those clips trying to get "max stiffness" than I care to remember. It is a major pain.
Better yet, install the "clipless dampers". They're 1 piece dampers, and you can throw those clips as far back in your toolbox as you can. It will seriously make fiddling with the head pleasurable.
I recently bought the 3-damper tuning kit. It has the hard, medium, and soft dampers. I installed the soft this weekend. I haven't flown with it yet, thanks to a tropical storm. Hopefully, I'll be able to test them soon, and find the right damper.
Good luck.
-Joey
J.B. Jones
Old 12-30-2011, 02:03 AM   #11 (permalink)
I put over 60 hours on my Fury 55 (OS 55 futaba FBL and MA FBL head).From May to November. I respectfully disagree. There is a resonant vibration during spool up and spool down. For me its around 1750 or so. Just adjust your governor accordingly and don't operate there.
Awesome machine. OS55 with a Hatori pipe on 30% Nitro. Without a doubt the heli that always goes to the field. MA quality is outstanding. I also fly a 700 FBL nitro and a Blitz AVRO 90.
The Fury has a lot of performance. Buy and FLY with confidence.
T-Rex 700 Nitro ,BLITZ AVRO 90, M.A. Fury 55FBL, SAB Goblin 700, T-Rex 500, T-Rex 250,T-Rex 600E DFC, Outrage Velocity 50V2
Arclight338 is offline        Reply With Quote Quick reply to this message
