700 Class Electric Helicopters 700 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
04-21-2010, 09:24 PM | #1 (permalink) |
7 channel radio required??? Align seems to think so
I'm super keen for the 700 but I've just been reading the specs page on the Align site. It says it requires a 7 channel radio. Is there a reason for this or is this just a typo? Will my DX6i be adequate?
Thanks. Last edited by Billdozer; 04-22-2010 at 08:17 AM.. |
04-21-2010, 10:08 PM | #2 (permalink) |
I cant see a reason unless you want to drop a bomb with the 7th channel......oh wait that sounds fun...
04-22-2010, 01:07 PM | #3 (permalink) |
I can't imagine you trying to drop a bomb when you can't do autos.
TEAM LYNX HELI Hang down, flip it, and reverse it ! |
04-22-2010, 03:09 PM | #4 (permalink) |
7th channel is required for your governer gain. This tells teh gov. what mode the transmitter is in (ie normal, idle1, idle2) and determines your headspeed in each. You can fly a 90 without a gov, but I wouldn't reccomend it, the motors aren't cheap to replace when you overspped it and blow one up. Channel layout is as follows:
throttle aileron elevator pitch rudder gyro gain governor gain |
04-22-2010, 04:54 PM | #5 (permalink) | |
I think maybe you will need an extra channel in the receiver for an extra power input so the amps can be split between two wires (maybe?) |
04-23-2010, 04:29 AM | #8 (permalink) |
mine only needs 6 chanels though i do have a DSX7 and use a AR6700 for an RX. not sure what they are on about with 7 cahnnels....
TREX 700 YS 120, <>T-Rex 700E 3G, <>600 ESP 3G 4035-630, <>T-Rex 450 Pro 3G, 550E 3G Scorp 4035 560 |
04-23-2010, 04:34 AM | #9 (permalink) |
Perhaps the manual is available for download? That would clear things up.
Scott Trex 500 / /3026-1600/CC Ice75 /3G /Ds510's/Torsion 430 fbl's Trex 450 pro/HK2221-8/ Ice 50 /HS-5065MG/325D's/Kbdd's |
04-23-2010, 05:51 AM | #10 (permalink) |
i run a 6200 on my 700 conversion and i havent had any issues.
04-24-2010, 10:47 AM | #11 (permalink) |
Im using a Futaba 6EX Tx for all my helis and planned on using this for my 700E. For Rx I use a Futaba 617FS 7ch receiver. Would this suffice for the 7ch recommendation by Align? I see a few people on this thread using 6ch Tx with no problems.
T-Rex 700LE x2 T-Rex 600LE x2T-Rex 600ESP T-Rex 500ESP x2 ElyQ Vision 50 - OS55, B320 Flown via DX7 |
