MA Gas Miniature Aircraft Gas Helicopter Support Forum |
08-24-2015, 08:26 AM | #21 (permalink) |
No bueno...
The numbers on the only belt I have are illegible, can anyone advise as to the belt number used? Thanks.
06-15-2017, 01:06 AM | #23 (permalink) |
Raja, is the output voltage customer changeable or do I need to send it back to be changed?
06-17-2017, 12:31 PM | #24 (permalink) |
Jewel onboard generator - thanks Raja.
You can change it with a castle BeC / ESc configuration cable.
http://www.castlecreations.com/en/ca...it-010-0005-00 This is what you need . Sent from my iPhone using Tapatalk |
06-17-2017, 10:50 PM | #25 (permalink) |
Do you use the castle software as well?
06-17-2017, 11:59 PM | #26 (permalink) |
Yes
Castle software and cable to change it, unless its got one of my original design regulators (earlier V1 model) -- those are hard wires I need to change resistors to alter the voltage...
V2 now makes more max amps power and more power at idle also. -=>Raja.
MA 1005, Hanson 270, 4717 flts, Spectra-g, Hanson 270, 3672 flts Whiplash-g V1-2, Hanson 300, 2235 flts, Whiplash-g V2, Hanson 300, 1552 flts Whiplash Turbine, TS 45i WSE, 296 flts Jewel on-board Generators, Miniature Aircraft Team Manager |
12-30-2019, 08:27 AM | #27 (permalink) |
Hey guys, sorry to dig up an old thread here but I have recently purchased a heli that is equipped with a generator. Is a 2s lipo acceptable to use if the output voltage is set to 8.5v??
12-30-2019, 05:50 PM | #28 (permalink) |
I would lower it
I recommend you drop it to 8v if you wish to use that lipo or drop it further to 6.9v and use it with a Life battery. That's what I use on my helis with HV servos (Life).
-=>Raja.
12-30-2019, 08:50 PM | #29 (permalink) |
That would be a 2 cell Life pack, correct?
12-30-2019, 11:13 PM | #30 (permalink) |
Yes
Those work very nice I use one that is about 3 to 3.5oz quite light yet does the job as a battery backup with the generator system.
-=>Raja.
12-31-2019, 05:59 AM | #31 (permalink) |
Awesome, thanks for the reply!
01-13-2023, 12:32 PM | #32 (permalink) |
Hey Raja, are the generators still available?
01-17-2023, 04:48 PM | #33 (permalink) |
Hi Zach
Yes sir, available for sure just let me know what you like and we can get you hooked up
Along with the generators, I have super bright white and red LEDs that glow only from the generator not on-board batteries to indicate that the generator is making power as well as voltmagic battery monitors to watch the levels of the battery pack realtime. The generator system makes good power even at idle so its still putting out while you are doing autorotations, and you know how I love to do those As for mounts I have them for the Whiplash helis in stock, gasser or turbine, for the older models I would have to order (for the Spectra or 1005 for example). For turbine models the generator system maintains both receiver and turbine batteries so it also is a true gas an go machine just like the gassers. Thanks for your interest in my Jewel RC generators and please let me know if you have any other questions. -=>Raja.
