Old 11-24-2012, 05:30 PM   #1 (permalink)
Default First Heli Build - Trex 700e DFC
I'm spastic at interpreting directions, so I had my current Trex 550 built for me. And I'm scared to death to fly it aggressively, because...I wouldn't know how to fix it. So, I've decided to jump in with both feet and buy a Trex 700e DFC HV.
I've reviewed a couple build threads and wanted to confirm components I will need. Most importantly...do I need a receiver with the 3GX? I was planning on the AR7000, but someone told me it's not necessary. Here is what I think that I need:
700e DFC HV Kit
AR72000 receiver
6S 5000 65C lipos
Series connector for lipos
2S 2100 25 C lipo for the receiver
Connector for the receiver lipo
Swashplate level
Pitch gauge
Any recommendations are appreciated...I will sort through and pull the trigger later tonight. Thanks.
jstan is offline        Reply With Quote Quick reply to this message
Old 11-24-2012, 06:08 PM   #2 (permalink)
Default Welcome
700e DFC HV Kit
AR72000 receiver
6S 5000 65C lipos
Swashplate level
Pitch gauge
Hi jstan,
Big welcome to 700 club...
I'm still waiting for my Super Combo... Soon!!
Chas
Align TRex 700E DFC HV~Spektrum DX8 MAAC 91236
Blade mCPX BL Blade mQX DJI Phantom 3 Pro'~iPad Air 2 Cellular
Heli-Max Voltage 500 3D Heli-Max 1SQ~Spektrum DX6i
Parrot AR Drone 2.0 Traxxas QR-1 RealFlight Drone 6.5
ChasCS is offline        Reply With Quote Quick reply to this message
Old 11-24-2012, 06:10 PM   #3 (permalink)
Assuming you have Spektrum transmitter ie. DX6i, DX7 or DX8 you won't need a receiver. However you will need to order qty 2 DSMX satellite receivers. They plug right into the 3GX. It's convenient to use a serial adapter to tie the 2 6S batteries together. Otherwise you can buy the more pricey 12S packs. Most are also using a separate battery pack for the RX (3GX) system. I use a 2200mah 2S lipo. Your kit may come with an Align voltage regulator and should be fine if you don't fly 3D. A good upgrade from that would be a ProTek like this. http://www.amainhobbies.com/product_...tage-Regulator
Also replace the tail hub washers with anything thicker steel than the OE washers (see thread on this topic) from the getgo.
I hope this helps. I hope others chime in to make your holiday purchase a great one!
Jeff B
800E Trekker - 700E DFC - 550v2 - 500 DFC - 450 DFC - Goblin 630
RV_7A is offline        Reply With Quote Quick reply to this message
Old 11-24-2012, 06:18 PM   #4 (permalink)
I'm pretty sure he'll need an Rx if he has a Dx6i because the gain channel in the 3gx is mapped to Channel 7.
-Edit- ......and he wont need a regulator either if getting the HV.
I had a 2 lead y-harness (http://www.spektrumrc.com/Products/D...odID=SPMYHEC36) from my 2S Lipo straight into 2 ports on the 3g which supports up to 8.4v from memory and then, obviously, the servos to the 3gx.
Bonkievan is offline        Reply With Quote Quick reply to this message
Old 11-24-2012, 06:19 PM   #5 (permalink)
Good call. ^^^
Jeff B
Old 11-24-2012, 06:26 PM   #6 (permalink)
Thanks for the feedback...I am very excited about figuring this whole thing out and maiden by new year!
I use a JR 9303 transmitter, so it sounds like I don't NEED a receiver. But do I WANT one? The fact that it's in the product info, makes me think that there are some advantages to using an receiver and connecting the 2S battery to it.
Other question is re: the voltage regulator...is this only required if I opt NOT to use a receiver or in all cases? Thanks.
Old 11-24-2012, 06:46 PM   #7 (permalink)
Bonkievan - I think I saw how you used the split wire connector, but thought you ran from the battery to the receiver...does it connect to the 3GX instead? Thanks.
Old 11-25-2012, 03:08 AM   #8 (permalink)
[quote=jstan;4475547]Thanks for the feedback...I am very excited about figuring this whole thing out and maiden by new year!
Im not familar with your tx(I run a dx8) so perhaps others can be more specific but as its 9Ch and dsm2, there would be no reason not to run 2 Sats off the 3gx. Less clutter, so far as wiring goes. In saying that, some people prefer to run a full range Rx on large Helis plus Sat. Myself personnally, and i'll comment what I ran when I had the 3gx on my 700DFC, I just ran 2 Sats off the 3gx and it flew fine. I now have a HC3sx FBL unit and still run 2 Sats off that also for my Hv setup too btw
There are a few different scenarios to your above question but I'll just comment on the 700 DFC HV setup you have stated you'd like to run.
Basically, with the Hv combo you can forget about the regulator (and the Rx if you so wish).
Again, others may like to post on other setups but as the 3gx and Hv servos in the Combo all support the voltage output direct from a 2S lipo, this is certainly one of the more common setups I believe .
[quote=jstan;4475587]Bonkievan - I think I saw how you used the split wire connector, but thought you ran from the battery to the receiver...does it connect to the 3GX instead? Thanks.
Yes, you are right. From your 2S lipo you plug the 2 Y-leads direct into 2 power-bus ports on the 3gx and you're good to go.
As I said, there are other ways to do things and I'm sure people will comment further, but this is just what I ran on mine on the recommendation of the majority i spoke to here on HF when I built mine not to long ago.
Old 11-25-2012, 03:27 AM   #9 (permalink)
BTW jstan,
Following on from what RV_7A said regarding the current 'tail issues'.......
Many have destroyed or grounded helis as they dont want to risk flying (like mine) because of it, so I would recommend perhaps 'holding' on pulling the trigger until Align sort this issue. No point buying an expensive, potentially defective heli, when I fix should be around the corner.
Alternatively, buy it and wait for whatever 'fix' Align comes up with. This may include buying the upgrade though, unfortunately.
Hopefully Align will 'come to the party' on that and either heavily discount or, maybe wishful thinking provide for free, the 'upgrade' to all those who have brought the 700DFC.
Old 11-25-2012, 05:46 AM   #10 (permalink)
Sell the 3GX and get an AR7200BX, FBL and RX all in one, just run one Sat for signal diversity.
I find BeastX easy to set up and requires little to no fine tuning to fly really nice.
Align Digital pitch gauge is nice, so is the align swash leveller for 600-700.
With regards to series connector, you can just solder one EC5 to each ESC wire and then run a bridge between them. so the series is built directly into your ESC conectors without the need for a harness.
T-Rex 700E Pro DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro |T-Rex 500 DFC Pro mini V-Bar
T-Rex 450L Dominator | JR DSX9 9503 Mode 2
Steemo is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 11:18 AM   #11 (permalink)
Do yourself a faver and go to Finless's tech page and watch his build vids. There is a ton of info there.
https://www.helifreak.com/showthread.php?t=74703
HankAz is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 11:21 AM   #12 (permalink)
one better vid by colin building the 700 dfc
[ame]http://www.youtube.com/watch?v=WijejqKCxes&feature=channel&list=UL[/ame]
[ame]http://www.youtube.com/watch?v=56vGxk3ewko&feature=relmfu[/ame]
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 01:36 PM   #13 (permalink)
Awsome...probably should have done this prior to ordering a lot of stuff. It will be interesting to see what I need to buy/return after reviewing. Thanks all!
Old 11-26-2012, 02:25 PM   #14 (permalink)
Default One Last thing...
Thanks all...I think that I'm ready to go with the exception of the receiver batt. I like the Y-connection method. One last question...is a standard 2S, 25C lipo ok to use or do I need to get a specific receiver batt. Those look to have around 5-8C. Thanks.
Old 11-26-2012, 05:20 PM   #15 (permalink)
Higher c rating gives no disadvantage, batteries give what they are able when the system demands it, if the batteries are not able to deliver the full amperage due to low c rating then the village will sag.
Batteries will never give more than the system demands.
Old 11-26-2012, 06:05 PM   #16 (permalink)
Originally Posted by Steemo View Post
..........then the village will sag.
Really?
You must have some unusual amperage round your parts Steemo
To the OP. I run a 2200mah 25c on my 700dfc hv. I run telemetry off that also.
Old 11-26-2012, 06:33 PM   #17 (permalink)
Thanks guys...net result is that it looks like I have the right stuff coming so any future accidents can certainly only be attributed to equipment failures .
Old 11-26-2012, 08:08 PM   #18 (permalink)
Originally Posted by Bonkievan View Post
Really?
You get the picture
Damn swype keyboard
Old 12-17-2012, 09:08 PM   #19 (permalink)
Default Successful Maiden Today
I had my first two flights on my 700e DFC this afternoon...and they were awesome. The head and tail tracked wonderfully and I will work on the small amount drift tomorrow.
I just wanted to say thanks to all the folks who took the time to answer questions for a first time build and setup. I honestly didn't think my very small sales brain couldn't figure out how do get this animal together and wouldn't have been able to do it without you.
- Jeff
Old 12-17-2012, 09:13 PM   #20 (permalink)
- Jeff
Congrats on the maiden!
