Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X7
X7 Discussion and support of the Gaui X7
Old 08-04-2014, 12:59 AM   #1 (permalink)
Default One Way Main Gear Upgrade
Hi,
For you guys who have upgrade to the new OW Main Gear Complete Upgrade.
Do you still have to the Mod or it is strong enough?
Using the Scorpion 4525-520
cRash_landing is offline        Reply With Quote Quick reply to this message
Old 08-04-2014, 05:28 AM   #2 (permalink)
If you have the one with the 3 vertical pins on the sides of the internal sleeve there is no need to upgrade.
https://www.helifreak.com/showthread...=575871&page=4
post 67
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks
omerco is offline        Reply With Quote Quick reply to this message
Old 08-04-2014, 09:07 AM   #3 (permalink)
I got the latest kit and did iT annyway... Beter save then sorry
Minicopter Diabolo black edition
Logo 550 2017, Gaui X3Gold, Oxy 210FE
Vcontrol Touch, NeXt, PL8x2
RuudM is offline        Reply With Quote Quick reply to this message
Old 08-04-2014, 09:21 AM   #4 (permalink)
If you have the one i have i wouldn't touch it...
Old 08-04-2014, 10:46 AM   #5 (permalink)
Hi,
Thanks for the reply.
This is the one that I have, I believe it is the newer version.
http://www.anythingheli.com/gaui-x7-...pgrade-217170/
I cannot seem to find where how to do the mod is. Can someone direct me.
Thanks!
Old 08-04-2014, 11:06 AM   #6 (permalink)
Default Re: One Way Main Gear Upgrade
Originally Posted by cRash_landing View Post
Hi,
Thanks!
Yes, 20 topics below this topic.
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro
velocity90 is offline        Reply With Quote Quick reply to this message
Old 08-04-2014, 11:50 AM   #7 (permalink)
Hi,
Thanks!
Its impossible to know from that picture. You need to open it and see if you have the 3 pins holding the sleeve:
https://www.helifreak.com/attachment...ing;5998115]Hi,
Old 08-04-2014, 12:04 PM   #8 (permalink)
I will check later after I get home.
Old 08-05-2014, 01:53 PM   #9 (permalink)
I'm curious to see if you're new OWB has the update or not. Have you had a chance to check?
XL V2, Soxos 7.1L - Previous: Kraken 580, Nimbus, Protos 380, Kraken 700, Diabolo 700, Oxy 5/2, Logo 600 / 550SX, Protos 700, Synergy 516, Velos 880, Gaui X7 / X5, Goblin 380, Blade 120SR/180SR/ mcpx BL/300X/450XL, Align 700X/150/Leap 3D
gtruk is offline        Reply With Quote Quick reply to this message
Old 08-06-2014, 01:13 AM   #10 (permalink)
I checked it and it is not.
The crown gear hub is upgraded to the newer version while the main gear hub is not.
I am curious on how do you know what is the right length to drill to put the set screws on?
I have a dremmel and I can make the flat spots but when drilling holes to match it, its kinda hard.
Old 08-06-2014, 09:20 AM   #11 (permalink)
Why do you want to drill holes? you should have 2 screws already and you need to make the flats aligned with them.
Old 08-06-2014, 12:02 PM   #12 (permalink)
No screws. I have the crown gear upgraded not the main gear hub where you have to make the flat spots.
Old 08-06-2014, 04:15 PM   #13 (permalink)
Im not sure i understand what you are talking about...
All upgraded sprung type have 2 small screws on the main gear hub "holding" the sprung sleeve
Old 08-06-2014, 07:24 PM   #14 (permalink)
That is what I am telling you.
The crown gear hub which is the top part which holds the crown gear is upgraded, so I do not have to use the cir-clip.
And the main gear hub which holds the main gear and the OWB is not upgraded, so it is either I upgrade it or drill holes in it.
Old 08-06-2014, 11:00 PM   #15 (permalink)
If the main gear part is not upgraded (not sprung type) drilling holes will not do it any good because there is no sleeve sleepage problem there.
Just lub it very well with gaui greese make sure it goes all around the needles.
But- im not really sure these parts are built to work together.. .
Old 08-11-2014, 06:35 PM   #16 (permalink)
I think it was Nasca that posted a mod for the upgrade (weird to say that yes). Anyway thread was posted here:
https://www.helifreak.com/showthread.php?t=512578
Team Empire/GAUI North America
Great Hobbies
Scott Gray Products
iKon Flybarless
Swooper6 is offline        Reply With Quote Quick reply to this message
Old 11-18-2014, 04:30 PM   #17 (permalink)
Got the 217170 one way upgrade today. Maybe it's a different version? Two flats on the hub sleeve. (Does it screw in?) No set screws. No circlip to hold it in but a collar instead.
Yuppyflyer is offline        Reply With Quote Quick reply to this message
Old 11-18-2014, 07:42 PM   #18 (permalink)
Interesting. That looks a lot like my NX7, that appears to be threaded. Can you see threads in there?
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote Quick reply to this message
Old 11-18-2014, 08:19 PM   #19 (permalink)
They changed it again?!
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 11-19-2014, 02:59 AM   #20 (permalink)
Yep left hand threaded. Looks nice.
