Old 11-14-2013, 03:34 PM   #81 (permalink)
I have one on pre-order with the motor but something is troubling me. If you do the math on what RH has published for the gears that come with it (212t main & 20t pinion), the head speed calculates very low on 6S. That's a gear ratio of 10.6:1. That gives a head speed of only 1900rpm at 85% if my calculations are right.
1070 * 22.2 / 10.6 * .85 = 1904
Maybe I'm going to want to order another pinion as that seems really low to me.
rablett is offline        Reply With Quote Quick reply to this message
Old 11-14-2013, 03:41 PM   #82 (permalink)
My choice would be 18T mod .7 pinion with the 153T mod.7 main gear
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 11-14-2013, 03:47 PM   #83 (permalink)
Yah some other guys came up with that too. Seems to be a show stopper.
If you went with the MOD .5 main gear with matching pinion would the HS be higher?
maarset is offline        Reply With Quote Quick reply to this message
Old 11-14-2013, 03:51 PM   #84 (permalink)
Yah this is weird,
This is with 212 main and 20T pinion. 2080 doesn't seem very Xxtreme LOL.
Result for calculation:
Estimated lowest voltage during flight: 20,34
Lowest RPM (due to voltage and efficiency) : 1847
Throttle 60%: 1852
Throttle 65%: 1909
Throttle 70%: 1966
Throttle 75%: 2023
Throttle 80%: 2080
Throttle 85%: 2138
Throttle 90%: 2195
Throttle 95%: 2252
Old 11-14-2013, 04:29 PM   #85 (permalink)
My only questions are price and weight compared to my ultralight logo500. I halfway expect it will be heavier than my 500 simply because it has carbon frames. Either way, it looks interesting.
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 11-14-2013, 05:28 PM   #86 (permalink)
Mikado have always provided a smaller than ideal pinion in their motor kits though. The 550SX and 500 super-combo kits show this. I'm assuming the idea is that out of the box it will fly well but not go beyond their design specifications.
On the Internet you can be anything you want.
It's strange that so many people choose to be stupid.
Jockpants is offline        Reply With Quote Quick reply to this message
Old 11-14-2013, 06:07 PM   #87 (permalink)
True
Old 11-14-2013, 06:58 PM   #88 (permalink)
Or perhaps Mikado wants us to learn some collective management
3Dmuse is offline        Reply With Quote Quick reply to this message
Old 11-14-2013, 07:22 PM   #89 (permalink)
I think they should have opted for the mod 0.7 gearing as it gives a much wider range of ratios than the mod 0.5
IF I get one, I wouldn't even bother with the mod0.5 and I would install the 0.7 from the beginning.
Old 11-14-2013, 08:13 PM   #90 (permalink)
In my case, tomorrow I am going to change my pre-order to the bare kit without motor and buy the 4015-1450 motor. At 1450kv the math for this helicopter makes much more sense.
Old 11-15-2013, 02:11 AM   #91 (permalink)
That as well.
Old 11-16-2013, 03:18 PM   #92 (permalink)
I like my 400SE because it is maintenance-free and i am over 1000 start with it...
i am very curious!
I would like to see more pictures, videos, info and experience in order to make a good decision about change from my 400se.....
May be heavier than my 400SE...???
Mikado Logo 480 - Future
Mikado Logo 600SX - Silver Line Present
Fusion 50 - CGY750 Past
Trader is offline        Reply With Quote Quick reply to this message
Old 11-17-2013, 04:10 PM   #93 (permalink)
I'm curious about the 480Xx too BUT what does it offer me, other than the driven tail, my 400SE Mod 0.7, 2600mAh 8S, Pyro 600-09, 86mm tails and 2500HS doesn't?
If the new Mod 0.5 herringbone pinions are anything like the 800Xx pinions were in the early days then availability of different pinion sizes will be an issue for some time. The 700Xx gave a few more choices due to commonality of shaft diameter of pinion between the 700Xx and 800Xx.
Regards, Jayson
Logo 800Xx Silverline, Pyro 850-40L, Kosmik 200, 14S, 157 & 256 @ 8v
Logo 400SE Silverline, Pyro 600-09, Jive 80+HV, 8S, 9660A+ 8900G @ 6v
Jays200 is offline        Reply With Quote Quick reply to this message
Old 11-17-2013, 06:37 PM   #94 (permalink)
I'm pretty sure they're using the shaft/oneway/gears from the 500 and 600. However, last time I checked they only had 2 different mod0.5 pinions for that gear.
Old 11-18-2013, 12:34 AM   #95 (permalink)
They have more than two mod0.5 pinion sizes on their website but I also think it is the same main gear as the 500 and 600, if it is then mod0.7 maybe the way to go.
SYNERGY 516
Mikado LOGO 550
Mikado LOGO 700
SMJT is offline        Reply With Quote Quick reply to this message
Old 11-19-2013, 03:43 PM   #96 (permalink)
Different tooth count than the L500 .5 mod gear so it may be smaller… we will see….
Laughingstill is offline        Reply With Quote Quick reply to this message
Old 11-19-2013, 03:48 PM   #97 (permalink)
Default Re: Logo 480 Xxtreme released in December!
tf-zuid is offline        Reply With Quote Quick reply to this message
Old 11-19-2013, 04:01 PM   #98 (permalink)
Am I missing something?
Logo 500 MOD 0.5 is 212 T
http://www.readyheli.com/MIK4060-Mai...5-p-35302.html
Logo 480 says
212 teeth, mod 0.5, herringbone main gear
Old 11-19-2013, 04:24 PM   #99 (permalink)
I'd love to review this heli since I was recently wondering if a carbon framed 400se could be built using the 600 mechanics and come out lighter than my 500. I suspect the largest difference (if I'm right) is that the Logo480xx has a much smaller and lighter canopy but I suspect the frames are heavier.
Old 11-19-2013, 04:36 PM   #100 (permalink)
Logo 480 says
I don't know what he is talking about either
SYNERGY 516
Mikado LOGO 550
Mikado LOGO 700
