Go Back   HeliFreak > R/C Helicopter Support > Audacity
Audacity Audacity Pantera Helicopters Support
Old 12-15-2013, 03:34 PM   #1 (permalink)
Default Gasser all ready for break in !
NGH 35cc gasser engine. Just need to mount it to a test stand and start breaking in!! need to buy a gas pump so I can get fuel into the tank..ROFL..
Jer
Jerry Moore, AMA #878954,TARANIS OpenTX- Pantera 600 FB - Pantera .60 FB - Takes a licking and keeps on kicking! KISSAM = Keep It Simple Stupid: Affordable, Maintainable -
Visit Early and often - http://open-txu.org
Jermo is offline        Reply With Quote Quick reply to this message
Old 12-15-2013, 05:37 PM   #2 (permalink)
Cool!
Lynx 130X, Lynx 180x, Oxy 2, Oxy 5 HF, Goblin 380, Helimax MX450 FBL, Pantera 50 Nitro, Pantera 50 electric conversion w/ quattro head, and CYE Stingray 500.
z_man_95 is offline        Reply With Quote Quick reply to this message
Old 12-16-2013, 01:23 AM   #3 (permalink)
Will that thing fit in the Pantera frame ?
Rasmus Fauske
MD700 v2 for F3C, MD 700 v2 for 3D, M5-Sport, MD600 and a few Oxys and a MSH P380 Evo
rfauske is offline        Reply With Quote Quick reply to this message
Old 12-16-2013, 03:38 AM   #4 (permalink)
It's a plank motor even if you can fit it it's not suitable for a helicopter. It would need a bigger cooling head for that.
Old 12-16-2013, 05:58 AM   #5 (permalink)
Yes, it will fit in the Pantera. *requires BBC
No it's not a "plank motor", it's a gas engine.
It requires more cooling when installed into a helicopter mostly because it's a gas engine which generates more heat and there's limited cooling on a helicopter that's moving forward.
Old 12-17-2013, 04:07 AM   #6 (permalink)
There's will it fit and will it work. Yes, it might be possible to fit it, but after that all bets are off.
The engine we've been playing with is the 17cc version, instead. That one uses a BBC conversion, (components of the NitroExpress). Meanwhile, we've got drawings of the head and it's looking more and more like we'll have to machine a custom cooling head if we're to make it work. However, other projects have taken precedence so it's on the back burner right now. I also have an OS baby gasser, the 15GT engine on hand to try as well.
Anyway, with respect to the 35cc engine Jer has, it's a pretty decent engine with an obviously inspired by nitro engine, layout. They're available from us for a little over 200 bucks, which is quite a reasonable entry into the world of gassers, don't you think?
Cheers,
John Beech - GM (and janitor)
www.promodeler.com
407-302-3361
AMA # 47381, IRCHA #745
jbeech is offline        Reply With Quote Quick reply to this message
Old 12-17-2013, 06:11 AM   #7 (permalink)
I like it. It came with an extra piston so I could move the exhaust to the rear instead of the side. I'll be breaking it in this weekend; weather permitting.
I was thinking around modifying the fan shroud and maybe adding an electric cooling fan. I've added thermocouples to my list and something to record. Another thought was to run a higher oil content for cooling. NGH says 20:1 for break in and iirc 35:1 for normal.
From other research; the gearing correlates to heat as well. It's all about finding the combination of load, gearing, cooling, fuel/oil that works.
Old 12-19-2013, 08:13 PM   #8 (permalink)
Jer
Holy cow, that looks huge. How much does it weigh?
As far as power goes, there's no replacement for displacement, so the 35cc should be quite a bit more powerful than the puny OS 15cc motor.
PRÔTOS 500 FBL "Sky Whip" | Robird G31
Goblin Speed | iKon
Old 12-20-2013, 06:07 AM   #9 (permalink)
With ignition module it's 1400g, Engine only is 1280g.
The plan is to get experience with the engine in a plank and get another one for heli after I figure out cooling. I'm debating a few ideas including a generator powering an electric fan or just a fan run directly. I like the electric idea because I can generated enough power to run an electric fan faster than a mechanical would probably run AND I get the benefit of a power bus onboard.
Old 12-20-2013, 08:50 AM   #10 (permalink)
The idea of using this engine has been kicking around in my head as well. I thought maybe with a stretch conversion, Quattro head with 710mm blades, and an electric cooling fan. Gearing it down low enough plus a new clutch assembly because I don't think ours would hold up to a 35cc engine.
www.promodeler.com
407-302-3361
Old 12-21-2013, 06:00 PM   #11 (permalink)
First 15 minutes of break-in are in the bag. Man! this is a powerful motor.
Wear gloves when starting!! The directions state that... for good reason..
Jer
Old 02-07-2014, 09:15 AM   #12 (permalink)
Jermo how is this motor holding up so far in a plank? I'm looking for an inexpensive motor for a giant big stick and don't really like the Dle 30. Also how is the nose coming out of it? We have a strict 96db at 20ft sound rule at my club and not having to purchase a aftermarket muffler is a plus.
Sent from my SCH-I605 using Tapatalk
richmurphy83 is offline        Reply With Quote Quick reply to this message
Old 02-07-2014, 07:42 PM   #13 (permalink)
I'm up for a new contract so waiting for that to finish the build. Only have 15min breakin on the motor so far. So far it's strong.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
