Old 04-06-2014, 11:55 AM   #1 (permalink)
Default Trex 500 pro DFC Servo question
I'm looking for input as which servos to use on my 500. I have both used Hitec hs5245's and slightly used Align ds515's. I read about the 5245's having a problem with the shaft hole in the case wearing out so I'm wondering what's the best to use? Thanks. J
reor is offline        Reply With Quote Quick reply to this message
Old 04-06-2014, 04:05 PM   #2 (permalink)
Have a look at the specs on each servo:
515:
http://www.helidirect.com/align-ds51...vo-p-28384.hdx
5245's:
http://www3.towerhobbies.com/cgi-bin...P?I=LXCRT0&P=8
The Hitec's only run at 4.8v and they are rather slow for a mini servo at 0.15 sec to 60 degrees.
The Align 515 maintains similar (slightly better) torque figures but is a full 30% faster since they are capable of handling 6.0v's.
Further, if you notice in the comments below on the Hitec, it requires a Hitec specific field programmer to set the failsafes on the servos. I'm not quite sure what that is, but the 515's require no such device - you just set the failsafes in your FBL/Tx settings as normal.
If the 515's aren't highly used, I would definitely go with them. I use them on my 500 FBL and they are great servos.
Be aware though, the 515's only drawback is that they are very power hungry. Most coreless servos typically are, but the 515's are even more-so.
Most internal BEC's can have power surge/brownout issues with these servos so I would advise you use an external BEC like the Castle Pro 20A. I personally use my Castle Edge 75's internal BEC at 6.0v but I also have a Scorpion backup guard going into my FBL for power redundancy.
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
DCflyer is offline        Reply With Quote Quick reply to this message
Old 04-07-2014, 07:07 AM   #3 (permalink)
Thanks for the input. I'm using a Castle Talon 90. Would I still need separate BEC with the 515's. The talon has a internal 8 amp BEC. Thx
Old 04-07-2014, 09:14 AM   #4 (permalink)
Talon has an 8A BEC, but remember the actual servo lead is only capable of delivering 5A to the FBL/receiver. It says this in the Talon's instructions but can easily be missed.
You can add/solder an extra servo lead to the Talon, to have two power leads going into the FBL - allowing for 10A of load.
OR you can run a capacitor pack or Backup guard for power redundancy.
Either way you, you should test your power setup on the bench by powering the heli/servos/FBL and satellites and applying load to the head manually while moving the sticks. You should not be able to brown out the receiver.
Test further by stirring the sticks, simultaneously moving the cyclic and rudder channels. Again, should not be seeing the Sat blinking.
Lastly, do some fast pitch pumps on the collective - again watch the sat.
If you pass those tests, i'd say you're ready for a maiden.
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
Old 04-08-2014, 04:21 PM   #5 (permalink)
Just for the info..
I've been runing the Hitec 5245's on two 500's for the past three years. No issues, even through several crashes, and have MANY sets of gears and cases just in case they need rebuilding, but havent had to yet. Granted, I am flying a FB'd heli, so the servos dont take the same hit as they do on a FBL heli. But just wanted voice my experience with them. Oh and as for speed...the 5245's on my two 500's are very quick. Almost too quick for me on my HC500.
Trex700N2E
Trex500ESPTT(PRO head and Tail )
Trex500ESP (Belted)
HC500SE ....GO TEAM FLYBAR!
Blayd is offline        Reply With Quote Quick reply to this message
Old 04-08-2014, 06:24 PM   #6 (permalink)
I'm taking the stock aligns off my 500 DFC and replacing then with Futaba BLS451's and a BLS421 on the tail. I have them on my 550 and love them.
Align: Trex 550 Pro DFC, Trex 500 Pro DFC, Trex 450 Pro DFC, Trex 250 Pro DFC, Trex 150 DFC, Blade: CX2, mSR X, 120 SR, Nano QX, 300X. Spektrum: DX6i, DX8, DX9
DWill is offline        Reply With Quote Quick reply to this message
Old 04-08-2014, 06:49 PM   #7 (permalink)
451's are standard size.....how you going to fit them onto a 500?
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
Old 04-09-2014, 07:18 AM   #8 (permalink)
I use the 5245 on my trex500 with tracx head.
I've got no problems to report. They've held up to crashes very well.
That said I put them on quite a while ago and there may be better options now.
I'm using the stock align esc so I've got to be careful with servo choice unless I want to add a Bec.
rob78 is offline        Reply With Quote Quick reply to this message
Old 04-09-2014, 07:44 AM   #9 (permalink)
Thanks for the input everyone.
