Engines and Mufflers Having problems or need advice on Engines or Mufflers? |
06-20-2015, 05:59 PM | #1 (permalink) |
YS120SRX vs YS120SR - fotos!
YS120SRX is about 5.5mm higher that YS120SR as you can see at foto. Only two different parts at SRX version - Crankcase and Cylinder Head. All other parts the same.
06-20-2015, 09:28 PM | #2 (permalink) |
The cranckshaft is also different and weighted to decrease vibrations as compared to the original 120SR.
06-20-2015, 10:04 PM | #3 (permalink) |
Crankcase, crank, head. That's it on the SRX version. Really more of a revision to fix heat and vibe issues.
"You need more rockets. Everything is better with rockets" Mike Dipalo--Synergy RC, MKS Electronics |
06-21-2015, 08:28 AM | #4 (permalink) |
I've heard it's much better tuniung than the 120SR as well. How would that be? Differences in sleeve porting...?
= Rb43 = |
06-23-2015, 11:53 PM | #5 (permalink) |
I can't say as I've never personally tuned a 120SR. I can tell you that the SRX is fairly easy to get dialed in as far as YS engines go.
The much improved cooling would certainly affect trying to hold a solid tune. I've been repeatedly told the 120SR had issues there, but again I've never had one personally so I don't feel qualified to give you a solid opinion there The 120SR and SRX both use the same sleeve part from YS last I checked.
06-24-2015, 08:23 AM | #6 (permalink) |
Once you get used to the YS120SR, tuning is not am issue anymore. I am running two of those, and from a day to another it may be a few clicks adjustment. It took me several gallons to understand that engine though.
Vibes remain high but acceptable when tuned OK. |
