Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba 14MZ - 12Z
Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum
Old 06-12-2005, 07:48 PM   #1 (permalink)
Default 14MZ Power problem on Channel 5
Hello,
I have had my radio for some time now. Actually since it first came available. I take very good care of my radio as well. Anyway Yesterday while just hovering my helicopter just diped forward. I was able to minimized the amount of damage to just the tail boom. After closer inspection after the crash I noticed that my elevator servo was the only servo that I could just trun freely with power on on the trans and receiver. I packed up and took things home.
When I got home I turned everything on and noticed that all controls except for elevator worked fine. The elevator servo was able to just turn with my hand as if it was getting no power to it. I cheked the wires and everything to make sure that it wasn't getting shorted out. I replaced it with another servo and still the same thing.
So at this point it wasn't a glitch but just that channel 5 wasn't getting any power to the servo from the receiver. Hmmmm, next I replaced the receiver crystal and still the same problem. Fine, I will just replace the receiver with another receiver. Wow, same problem. Now I'm completely confused because I have no idea what is going on. I can't say that it it the receiver or the servo's because I have replaced them both. The only thing is the Radio isn't sending a signal to channel 5. Very wierd!!!!!
This hasn't happened on the G3 receiver at all but I'm afraid to take the chance. Both previous receivers were 1028's. If anyone has any idea it would be greatly appreciated. TIA.
War
wargor is offline        Reply With Quote Quick reply to this message
Old 06-13-2005, 12:07 PM   #2 (permalink)
"Hmmmm, next I replaced the receiver crystal and still the same problem"
The G3 does not have crystal its a synthesized receiver so I'm confused by your post.
Do you have a friends transmitter to use with your G3 receiver/servos to make sure they work ok? What do you see in the Servo monitor screen? Does the bar for channel 5 move when moving the right stick?
Sounds like something in the TX is not working or set correctly. Program up a new model and try testing again.
Chuckie
Chuckie is offline        Reply With Quote Quick reply to this message
Old 06-13-2005, 04:03 PM   #3 (permalink)
Sorry if you were confused. The two 1028 receivers had the crystal replaced. The G3 receiver works fine. Either way the radio was sent in to Futaba today. We will see what they have to say. It's a friends radio so I'm interested to see what the issue is. I have two G3 receivers installed in both ships and I haven't had any issues. I also asked a few others with the radio here locally and they are wondering what's going on as well. Thanks
Old 06-13-2005, 04:26 PM   #4 (permalink)
Be sure to let everyone know what the problem was. Did you look at the servo test screen to see if it showed movement on that servo? Thanks for sharing.
Sam
blow smoke
bono1 is offline        Reply With Quote Quick reply to this message
Old 06-13-2005, 05:36 PM   #5 (permalink)
Just a little information for next time, the crystal either works or it doesn't, there is no in-between so loosing ch 5 is not the fault of the crystal.
If you had a bad servo extension that would cause the channel not to work with two rx and servos.
Let us know what Futaba says.
Chuckie
Old 06-13-2005, 06:02 PM   #6 (permalink)
I know that changing the crystal makes no difference. We were just trying to rule everything out that we could. The receivers and servo's all worked fine. We replaced receivers and servo's with new ones and still got the same results. The only thing that we could come up with is that the transmitter wasn't sending a signal to that channel.
I posted here just to see if anyone had any other suggestions. As I said before he sent in in to Futaba today with all components, so we will see what they have to say. Hell, $2200 radio they better find something and fix it. Anyway thanks for your comments guys. Will keep you posted.
