Old 02-10-2011, 11:55 AM   #21 (permalink)
nice mine are coming in the mail today so im going to be ready as long as my friend has that screw... i cant find one locally anywhere... i did find some on ebay i bought but their not going to be here by this weekend
michael88997 is offline        Reply With Quote Quick reply to this message
Old 02-10-2011, 03:10 PM   #22 (permalink)
But is this 20mm screw for the main gear?
ziper_it is offline        Reply With Quote Quick reply to this message
Old 02-10-2011, 03:27 PM   #23 (permalink)
ya its the screw that holds the main gear on the shaft
Old 02-10-2011, 04:07 PM   #24 (permalink)
not sure if it's the same length but possible to use Rave450 'shank' screws..
http://www.amainhobbies.com/product_...rce=google_ext
I think I have some spares from the Rave I had last year, I'll check compatibility
eightythree is offline        Reply With Quote Quick reply to this message
Old 02-10-2011, 04:11 PM   #25 (permalink)
So M2 x 12 would fit. I'm using the ones coming with the main shaft of my TRex.
Old 02-10-2011, 04:56 PM   #26 (permalink)
thats long enough? the one i pulled was 20mm long
Old 02-10-2011, 09:27 PM   #27 (permalink)
The screw is called out as an M2x14 (pn MSH40031). I don't think a 12mm will be long enough to fully engage the nylon insert in the locknut, and a 20mm will be too long (but wouldn't hurt anything I guess).
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 02-10-2011, 09:32 PM   #28 (permalink)
Hmm I guess they measure the threads cause mine is 20mm from tip to tip, I ordered some 20mm so they will be here sometime this week, my friend is going to let me borrow a Jesus bolt from his extra 450 so I can at least enjoy the nice weather this weekend
Everything is repaired and ready to go, once u build this heli once the repairs take half the time...
Old 02-11-2011, 05:10 AM   #29 (permalink)
Yep, M2x14 checked in the manual.
I've lost the nylon nut, so I'm using a metal one with loctite. I've already broken 3 of these screws, just the screws, and doesn't make sense for me to buy a main gear at time.
Old 02-11-2011, 08:58 AM   #30 (permalink)
Trex/Rave is 12mm, stock is 14. I checked before I installed the maingear last night and it should work.
Flip the Nylock nut around so you thread into the nylon first, or just use a regular nut like ziper it.
I used a little CA glue to hold the nut in place..
After install you can put a dab of locktite behind the nut for extra security, should be good to go!
Old 02-11-2011, 09:18 AM   #31 (permalink)
Ya I'll make it work for this weekend, I just ordered some m2x14 off eBay so I'll have those to replace next week... Just did a run up after Resetting the beast and everything runs great
Old 02-14-2011, 09:04 PM   #32 (permalink)
Is anybody using a esc that has timing settings of low med high? I have mine currently set on med and I flying a 16t on 100% tc and it doesn't seem like I have the power some have in their videos, I was going to try high cause my esc motor don't get hot at all but don't know how much my flight time will be affected
Old 02-18-2011, 08:53 AM   #33 (permalink)
Does anybody elses tail fin vib just a little? I can see mine In the air vibrating, it doesn't seem to affect the heli and I just held it in my hand and felt no vibrations,
Old 02-18-2011, 08:59 AM   #34 (permalink)
Mine is butter smooth, no vibrations.
Chris Boultinghouse
Old 02-18-2011, 09:25 AM   #35 (permalink)
So your tail fin stays perfectly straight?
Old 02-18-2011, 12:17 PM   #36 (permalink)
Yep, absolutely motionless.
Chris Boultinghouse
Old 02-18-2011, 01:06 PM   #37 (permalink)
Hmm weird, I didn't feel any vibrations and my heli flys great, beastx doesn't feel anything, guess I need to check the motor mount
Old 02-18-2011, 03:02 PM   #38 (permalink)
The carbon fins are pretty thin... maybe loosen and retighten?
Old 02-18-2011, 03:25 PM   #39 (permalink)
Ya it looks to me just the bottom half, from the top of the smaller hole or so is vibrating, since the beast doesn't act like there is a vib it makes me think it's just the fin, I could glue a popcycle stick on it to keep it from vibrating I just don't want there to be a actual vibration that causes an issue
Old 02-18-2011, 03:53 PM   #40 (permalink)
Chris, on yours, which doesn't have this problem, is that yellow tail actually made out of a yellow plastic, or did you laminate yellow monokote to the flat sides of the tail before screwing it on? Wondering if a monokote treatment might also have a positive impact on the part stiffness... sort of like foam core posterboard gets added rigidity from having two thin paper skins on either side laminated to the foam.
woodworkjkt is offline        Reply With Quote Quick reply to this message
